PC TO MITS 65907? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-15-2001, 09:19 AM - Thread Starter
Kipp Jones's Avatar
Does anyone know if I was using my pc to receive digital tv and hd broadcasts, could I output hd to my Mits for viewing or am I limited to my pc monitor? Is there a converter from the pc output to component? Would the rca vhdc-300 do the trick?
Kipp
IS THAT A REMOTE CONTROL IN YOUR POCKET OR ARE YOU JUST HAPPY TO SEE HDTV?
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline
post #2 of 3 Old 08-15-2001, 12:18 PM
ADebar's Avatar
http://209.248.228.2/grfx/9a60.gif
This is what you are looking for. This is the best model for Mitsubishi HDTV's. Here a link for more info about it.
Audio Authority
<FONT size="1">ADebar</FONT s>
<FONT size="1">Mitsubishi WT-46807 Widescreen HDTV</FONT s>
<FONT size="1">JVC XV-S65 Progressive Scan DVD Player</FONT s>
<FONT size="1">General Instruments HDD-200 HDTV Decoder</FONT s>
<FONT size="1">Time Warner - Houston HD Service</FONT s>
<FONT size="1"> My DVDs - DVD Profiler </FONT s>
Danger! Danger! Danger!
:p
ADebar is offline
post #3 of 3 Old 08-15-2001, 05:53 PM - Thread Starter
Kipp Jones's Avatar
Thanks...I thought a converter would work but was not sure.
Kipp
Kipp
Closed Thread HDTV Recorders
