HiPix vs AccessTV... Final Questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 08-20-2001, 11:53 AM - Thread Starter
mikem01's Avatar
Just to clarify, does the player app on HiPix support pause, fast forward and rewind? Or is that only on the AccessDTV unit? Also, if I really don't plan on sharing my HDTV recordings, is the AccessDTC equivelant or better in every other regard?
-MM
Mike
Mike Morrison
Microsoft Corporation
<This posting is provided "AS IS" with no warranties, and confers no rights.>
mikem01 is offline
post #2 of 21 Old 08-20-2001, 01:17 PM
PVR
PVR's Avatar
The latest HiPix software does support FF/RW/Pause.
Earlier software versions didn't have this, but
they finally added those features.
PVR is offline
post #3 of 21 Old 08-20-2001, 01:43 PM - Thread Starter
mikem01's Avatar
Thanks, then in that case I'm leaning more toward the HiPix.
Does anyone know if there is an SDK for either the HiPix or the AccessDTV? I'm assuming they don't support the Microsoft Windows Media Encoder (I usually use the WME SDK to write my own VB apps for custom recording/encoding on my NTSC capture cards).
-MM
Mike
Mike Morrison
mikem01 is offline
post #4 of 21 Old 08-20-2001, 11:42 PM
PVR
PVR's Avatar
The HiPix drivers are not recognized as standard capture devices, so (as far as I know) their application is the only easy way to control their card.
PVR is offline
post #5 of 21 Old 08-21-2001, 12:24 PM
apnar's Avatar
Just to clarify...(unless I missed a huge HiPix software update)... The HiPix supports these features when watching a recording. It doesn't support them when watching live TV (like a TiVo or Replay for example). The AccessDTV card does do timeshifting though and will allow you do FF/RW/Pause while you are watching live TV.
-apnar
[This message has been edited by apnar (edited 08-21-2001).]
apnar is offline
post #6 of 21 Old 08-24-2001, 01:35 AM
rodmanbra's Avatar
I can not believe why you people openly lie. The access DTV card does NOT have FF or RR in full screen mode. I am really PO at this product.
It also:
1) Has no SIZE adjustments in full screen mode
2) difficult to install
3) records a whopping 8 GIG plus per hr even for 480i DT
4) take 5 second to change from VHF to UHF DT channel!!
I do not believe it. The panny combo is superior with it well known flaws!
rodmanbra is offline
post #7 of 21 Old 08-24-2001, 05:34 AM
Jim Ferguson's Avatar
Sorry you can't find the &gt;&gt; and &lt;&lt; hotkeys in full-screen mode. They work fine for me.
Jim Ferguson is offline
post #8 of 21 Old 08-24-2001, 11:11 AM
rodmanbra's Avatar
Jim,
I am not impressed with your reply. The docs for access DTV do NOT state any hot keys for FF or RR.
If there is such a thing...why be mysterious about it? This kind of behavior is typical AVS. That is why you deserve ABC in 480i DT!
post #9 of 21 Old 08-24-2001, 11:21 AM - Thread Starter
mikem01's Avatar
Is it possible that you don't have the latest AccessDTV software/drivers? What version are you running?
-MM
Mike
Mike Morrison
mikem01 is offline
post #10 of 21 Old 08-24-2001, 11:53 AM
rodmanbra's Avatar
mike,
I sm using version 2.1 . The 2.0 version would not work with my diamond monster sound card. Also you will need to get a VAILID directX 8 from miscrosoft. The one itech provides has a bug.
post #11 of 21 Old 08-24-2001, 02:11 PM
I'm not in front of the PC at the moment, and I have the code memorized in the Pronto anyway, but it's something like Ctrl-&gt; and Ctrl-&lt;
post #12 of 21 Old 08-24-2001, 10:08 PM - Thread Starter
mikem01's Avatar
Pardon my ignorance, but what is a "Panny Combo"?
-MM
Mike
Mike Morrison
mikem01 is offline
post #13 of 21 Old 08-25-2001, 07:16 PM
jacmyoung's Avatar
Ok, Bra, this is new to me. What did the MS downloaded DirectX 8 fix that the ADTV DirectX 8 did not? I might want to try an MS DirectX 8 reinstall if you are right.
jacmyoung is offline
post #14 of 21 Old 08-25-2001, 08:14 PM
rodmanbra's Avatar
Two things solved my problem:
1) upgrading to 2.1. version. Thoose <u>idiots</u> at itech created a 2.0 version which did not work with my diamond monster card. I got sound error messages.
2) the direct 8.0 would not install properly. I highly recommend going to MSN and trying that. It worked perfectly.
It hard to say if any of this will help. Btw, i still can not use that upper connector! If you do not suceed go to windows safe mode. Look for any duplicate devices under my computer.
post #15 of 21 Old 08-25-2001, 10:27 PM
Rich4av's Avatar
rodmanbra,
I guess the "idiots" at itech were not aware that ATI stopped supporting the monster sound card about 1.5 years ago, and the drivers are no longer compatible with newer versions of Windows. In fact, the final drivers on the ATI web site actually are broken, as many users posted on the HTPC forum. My monster card wound up in the trash.
Heck, maybe they should make sure that all sound cards ever built work properly with ADTV because some user somewhere has a card he wants to use?
As we asked you in the HTPC forum, please watch your use of insults, especially when YOU are the one with the unreasonable expectations.
Rich
[This message has been edited by Rich4av (edited 08-26-2001).]
Rich
Rich4av is offline
post #16 of 21 Old 08-25-2001, 11:02 PM
rodmanbra's Avatar
Rich,
Itech did some other things which i can not disclose publicly. I am furious with them for technical AND personal reasons. I also want to point out the horrible behavior of these self apointed so-called computer experts. I do not deserve to be called names just for saying THE TRUTH others confirmed!
There is also big diff between a personal attack and a complaint against a faceless company. If posted under name KenF or even Richard ABIR Adams things would be different!
post #17 of 21 Old 08-26-2001, 12:30 AM
rodmannoodlebra's Avatar
rodmanbra is no avs superhero.
1 Always negative about everything and everyone
2 throws stones in glass house when should be boiling eggs
3 disrespects all avsers with condescending words like kiddies
4 paranoid thinking that wfor, cbs, hardrock, panny, bob, AVS mods, HOA, PBS, HDTVGALAXY and now Itech are all out to ruin HDTV experience for rodmanbra.
5 needs to learn lesson of golden rule, treat other as you want to be treated
6 forgets that people work for companies and don't like to be called idiots.
FLBra is bad karma, Left Coast Bra is good Karma
Itech/HiPix keep making rocking HDTV products, forget and ignor negative bad karma FLBra. All that bad Karma going to get you FLbra, Bad Karma = bad HDTV.
The real BRA
rodmannoodlebra is offline
post #18 of 21 Old 08-26-2001, 01:53 AM
ChrisW6ATV's Avatar
mikem01-
A "Panny combo" is the Panasonic TU-DST50 or TU-DST51 HDTV set-top box (they are the only ones with IEEE1394 ports that I know of) along with a Panasonic PV-HD1000 D-VHS VCR. This VCR records/plays regular VHS Hi-Fi, but also has an IEEE1394 port that can be connected to the boxes mentioned above, and will then record and play HDTV. About US$2500 for both when they came out, as I recall, but now discontinued. You can buy a HiPix and a pile of big hard drives for that kind of money, and I really enjoy my HiPix.
Chris
Chris
"It's [expletive] lame to watch Jaws, a film that uses the 2.40 ratio as well as any ever produced, in the wrong format on HBO." -Steven Soderbergh, Oscar-winning director
ChrisW6ATV is offline
post #19 of 21 Old 08-27-2001, 07:24 AM
Andrew C. Lipka's Avatar
Yes, but the "Panny combo" records off of the satellite, so HBO-HD, SHO-HD, etc. can be recorded. Not so for HiPix/AccessDTV.
Andrew C. Lipka is offline
post #20 of 21 Old 08-27-2001, 08:42 AM
gridleak's Avatar
The Panny Combo requires the Dish5000/modulator to record off satellite, as does the HiPix.
-Roger
Analog -- Always out of adjustment.
Digital -- Always one more bug.
-Roger
gridleak is offline
post #21 of 21 Old 08-27-2001, 10:20 PM
Rich4av's Avatar
I have a question for those of you with the Pany or other HDTV boxes: Are you still experiencing audio dropouts?
Before I got the ADTV card, I tested the Mits HDTV box (by Hughes) and it had a lot of dropouts. ADTV had them too. But, after some time and with the new software releases, I experience very few dropouts.
I was wondering if the broadcast stations had fixed their signal and the commercial boxes are now also experiencing few audio dropouts, if any, for OTA reception?
Rich
Rich
Rich4av is offline
Closed Thread HDTV Recorders
