HD 100 and Panny Digital Camcorder - AVS Forum | Home Theater Discussions And Reviews
Old 09-25-2001, 04:59 AM - Thread Starter
pgnewarkboy's Avatar
I have the Panny HD 1000 and STB setup. I just purchased a Panasonic PV-DV951 digital camcorder with a firewire out connection.
Is it possible to output from the camcorder to the HD1000 then show the tape over the STB. I have called Panasonic and they are basically clueless about this issue-as well as many others.
Toxic Sludge Is Good For You
pgnewarkboy is offline
Old 09-25-2001, 11:24 AM
gridleak's Avatar
The digital stream from a DV camcorder is output from a DV encoder. A DV decoder is required to restore the video, and a Panny STB does not have such a decoder.
-Roger
Analog -- Always out of adjustment.
Digital -- Always one more bug.
-Roger
gridleak is offline
