Weird new problem with my HD1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-05-2001, 01:49 PM - Thread Starter
Pericles's Avatar
Ok, this is a new really weird problem that just developed with my PV-HD1000 unit. I can no longer record HD content if I just press the REC button on the front of the unit, or just press REC on the remote. However, it does record fine when I use the DVHS menu option in the Set Top box and use the record button on the screen.
Anyone seen this before and has a solution to resolving this issue?
"I fear, from the experience of the last twenty-five years, that morals do not of necessity advance hand in hand with the sciences." --Thomas Jefferson to M. Correa de Serra, 1815. ME 14:331
Pericles is offline
post #2 of 9 Old 10-05-2001, 03:29 PM
Bill's Avatar
Quoted: 69 Post(s)
Liked: 50
I think there is a setting in the VCR setup that causes this.
Bill is offline
post #3 of 9 Old 10-05-2001, 06:34 PM
gridleak's Avatar
Pericles,
Is the input on the recorder set to digital? The display should show a "d" next to the time readout. I'm not absolutely certain but I think the STB forces the recorder into digital input mode if recording is started from there.
-Roger
Analog -- Always out of adjustment.
Digital -- Always one more bug.
-Roger
gridleak is offline
post #4 of 9 Old 10-06-2001, 12:01 PM - Thread Starter
Pericles's Avatar
gridleak,
indeed, there is a 'd' to the right of the display yet no recording. Thanks for the input though. I guess i'll have to keep using the set top box to initiate recording..is not that big of a deal.
Originally posted by gridleak:
Pericles,
Pericles is offline
post #5 of 9 Old 10-06-2001, 04:09 PM
gridleak's Avatar
OK, next thing I would try is a different (preferably shorter) iLink cable. When you press the record button on the recorder the STB should respond with a screen message "DVHS Recording". If not, then the STB didn't get the command from the recorder to start transmitting the iso stream, and you will record black.
If you get the message "DVHS Recording" and you still record nothing then you are definitely in the Twilight Zone.
-Roger
-Roger
gridleak is offline
post #6 of 9 Old 10-14-2001, 02:57 AM
J_Nemeth's Avatar
Originally posted by Pericles
gridleak,
My two pvhd1000s display the "d" to the right, even when they are in analog mode. Make sure the green "DVHS" light is lit on the left side of the unit.
Jay
"Can I please just watch this the way it was meant to be seen?"
J_Nemeth is offline
post #7 of 9 Old 10-15-2001, 02:28 PM
Bill's Avatar
Quoted: 69 Post(s)
Liked: 50
Check the "VCR lock" feature in the manual. Try toggling it off and on and off.
Bill is offline
post #8 of 9 Old 10-15-2001, 06:57 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 596
Your record switch could be worn out. Try pressing it harder. These cheap switches can be trouble.
Glimmie is offline
post #9 of 9 Old 10-16-2001, 11:37 AM - Thread Starter
Pericles's Avatar
Is not the button...it doesn't work when i initiate a record through the remote too. Again, the VCR does start to record but no recording.
Bill, I will look at the lock feature..i have no idea what it is. I will pull the manual out and take a look. Thanks :)
Pericles is offline
Closed Thread HDTV Recorders
