Mits HD dish and directivo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-06-2001, 06:00 PM - Thread Starter
argo's Avatar
Is there any way I can connect my HD dish to a non hi def receiver (philips6000) with directivo AND my Mistubishi400 hd receiver at the same time.
I'd like to use tivo, even if it's just for non hi def channels. I'm very new to this, but I like to do things myself.
thanks
Sony XBR65X930d
Sony HT NT5
Apple TV Gen4
TWC/Spectrum DCX3600-M cable box
Samsung UBD-K8500
Logitech Harmony 650
argo is offline
post #2 of 4 Old 10-07-2001, 12:20 AM
Dexter1's Avatar
I may be missing something here, but your Hi-Def dish should have four outputs( a 4x4 multiswitch). You should be able to connect directivo(two outputs at most) and a Mits hi-def(one output) at the same time no problem. If you are getting channels 199 and 509 then you have the 4x4 multiswitch and connecting both directivo and the Hi_def reciever should be no problem. If you do not recieve the Hi-def channels then you might not have the right dish?
Dexter1 is offline
post #3 of 4 Old 10-07-2001, 09:00 AM - Thread Starter
argo's Avatar
Sorry if I'm not providing all the info. I'm very new to this.
Yes. I receiver 199 and 509. My dish is so high on my roof I haven't been able to get up there to look at how the installer did it.
If you wouldn't mind another elementary question...
If indeed there is a multiswitch (I assume it's on the roof not under the house or something), do I just need to get up there with more cable? Should I replace the multiswitch with a larger one?
Do you know of a url with very specific directions for connecting a dish? I know how to do the wiring of the receiver.
(pretty much)
Thanks for your help, every bit of info is appreciated.
Sony XBR65X930d
Sony HT NT5
Apple TV Gen4
Samsung UBD-K8500
argo is offline
post #4 of 4 Old 10-08-2001, 12:29 AM
Dexter1's Avatar
The multiswitch should be on the back of your dish. All you need is more cable. You might consider a bigger multiswitch if you plan on adding more directivo's, but the one you have now should serve you just fine. I don't know of a url, but I have the same dish setup and the multiswitch is very clearly labeled. It's not hard just get up there and take a look.
Dexter1 is offline
Closed Thread HDTV Recorders
