8300HD and External SATA - It Works!! - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #541 of 9066 Old 08-24-2005, 07:07 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Originally Posted by davehancock View Post
Pepar,
Taking the high road or low road is regionally oriented. Cable (TW) here has been very much taking the high road - but they have been having a significant success with their Digital Phone offering (and significant package deals). The local phone company and the SATs have been taking the low road in a desperate attempt to compete.
I'm tempted to switch back to SAT and the local phone with DSL - but the ONLY thing holding me back is the 8300HD with external 250GB drive (what this thread is all about).
So, you see a connection between the strength of one's technology offerings and the tactics one employs in marketing same? From the scenario in your market, TWC has a hot hand and is being high-minded in their marketing, while the other two slog away to maintain the status quo. Tools of the trade, I guess.
I seriously considered leaving cable and going SAT. My programming choices were pretty much a wash cost-wise from CATV to SAT, so I stayed with the devil I knew. Hi-def and HD-DVRs sealed it. At least for now.
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
post #542 of 9066 Old 08-24-2005, 07:09 PM
vegggas's Avatar
The decryption keys for stored programs are located in the ram of the STB for first use, then it handshakes with the headend for continued usage. If you try to use your DVR after it has not been connected to cable for a while, it will no longer play back. You may get about 4 hours (+/- 2 hours?) of usage from stored content before everything times out and it becomes un-useable.
I do not have an NDA with SA, so this is conjecture based on the STB field and cable security general awareness. I do not specifically know exactly how the encryption/decryption process works, based on any STB manufacturers hardware or software platform.
Had to put that in...
vegggas
vegggas is offline
post #543 of 9066 Old 08-24-2005, 07:10 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Originally Posted by CANNON-FODDER View Post
Thanks veggas & pepar, that was what I was looking for.
I guess there is probably no way to have constantly expiring codes without re-encrypting the stored information. But having a static key coming from each account does not seem less secure than the static key in each box. I guess they could hold the key only long enough to actively decode the stored file, then make the DVR handshake to get it again, but there does not seem much point over the static solution.
v/r,
C-F
We think you should write them a letter. We're sure they will see the impecable logic of your position and make the change post haste.
pepar is offline
post #544 of 9066 Old 08-24-2005, 07:12 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
vegggas
pepar is offline
post #545 of 9066 Old 08-25-2005, 07:32 AM
CANNON-FODDER's Avatar
Quoted: 189 Post(s)
Liked: 83
I sent them an e-mail yesterday and the fellow seemed excited during the call-back, talking about eureka, simple changes, briefing packets to management, maybe a bonus.
Then this morning's call-back was slightly incoherent: management reads foam?, pepper?, sarcasm? Killed the momentum?
I honestly didn't know what to make of it...
:P
v/r,
C-F
CANNON-FODDER is offline
post #546 of 9066 Old 08-26-2005, 03:25 PM
owenrutz's Avatar
Won't cable card II make the encryption issues more user friendly?
owenrutz is offline
post #547 of 9066 Old 08-26-2005, 07:34 PM
rbienstock's Avatar
Has anyone been able to get a SATA drive to work on a Passport box yet?
Robert
rbienstock is offline
post #548 of 9066 Old 08-27-2005, 07:07 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
I don't think so. The SATA ports are not yet activated on Passport-equipped units. However, I am about to buy an inexpensive Firewire drive to try as the DIAG info says "always activate Firewire" as the Firewire status. Being supported (by the cable operator) may be one thing and activated yet another. If the Firewire drive doesn't work, I'll use it with my laptop for external storage. In fact, even if it DOES work, it'll go with the laptop as I buy TWO 500GB Firewire drives to connect to the TWO Firewire ports.
pepar is offline
post #549 of 9066 Old 08-30-2005, 05:18 PM
BenSanford's Avatar
Originally Posted by DSperber View Post
Just tonight replaced the Seagate 400gb (ST3400832AS) I originally purchased with a Maxtor Maxline III 300gb (7L300S0). So far, 100% of the performance problems and glitches I've had with controlling "live" TV (both SD and HD) as well as playing back recordings (both SD and HD) seem to have disappeared completely!...
I just today read through all of the thread (2nd time for much of it) and after looking at all the options, etc. -- put my order in for the Cruz cable (2 meter) @ roughly $25 with shipping, and from NewEgg:
EXT SATA ENCLSR E-POWER EP-301SA - Retail (Qty=1,Price=$33.85)
HDD MAXTOR|16M SATA 7200 7L300S0 % - OEM (Qty=1,Price=$157.00)
Extended Warranty Fee: $0.00
Subtotal: $190.85
TAX: $0.00
Shipping and Handling Charge**: $9.98
Total: $200.83
Total with the cable will be ~$225
I paid about $20 extra for the higher-end 300gb Maxtor drive that DSperber suggested with the 5 yr. warranty. I figured that it's worth the money if it's quieter, and the extra warranty won't hurt.
(Newegg has the other 300gb Maxtor SATA drives for about $132 or so on their Labor day special).
Hopefully I'll have everything received, installed, and working before I leave for vacation on Sept 13th.
Will post results in a week or so - Cox SARA Fairfax, VA
BenSanford is offline
post #550 of 9066 Old 08-30-2005, 10:00 PM
Robbo's Avatar
I ordered the same exact items as you last Wednesday and they arrived yesterday (of course the Maxtor drive last week at Newegg was $12 more expensive--Doh).
Took me about 1 minute to install the drive in the enclosure. I just picked up my SA8300HD yesterady and will install the 8300 and the drive this weekend.
XBL Gamertag: Robbo67
Robbo is offline
post #551 of 9066 Old 08-31-2005, 05:22 PM
HDugan's Avatar
My eyes are bleed from reading today...
Please catch me up...
Where is the best place to buy the 8300HD and External SATA ?
How is the return policy?
Are they the cheapest?
Do any store-chains sell these.
Have a Nice Day!
HDugan is offline
post #552 of 9066 Old 08-31-2005, 06:08 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Huh? Buy them? How much *did* you read?
pepar is offline
post #553 of 9066 Old 09-01-2005, 08:33 AM
HDugan's Avatar
...more specificly written...buy the external drive for the 8300HD.
Have a Nice Day!
HDugan is offline
post #554 of 9066 Old 09-01-2005, 08:53 AM
tony57's Avatar
See: Maxtor QuickView Expander - 160GB External Drive
and: Maxtor QuickView Expander - 300GB External Drive
Froogle the part numbers to get add'l prices.
tony57 is offline
post #555 of 9066 Old 09-01-2005, 05:04 PM
cblackstone's Avatar
MAXTOR 300GB SATA Hard Drive from newegg.com
Mapower MAP-H31SS-01 SATA Enclosure from newegg.com
Sonnet Technologies SATA Cable from macmall.com
Everything works great. Here's the diagnostic menu info
SARA Version v1.87.16.1
HDD Info: Maxtor 6L300S0
Capacity 279 GB
Partition Info: Partition Size 259 GB, Free Space 259 GB
The Serial ATA Enclosure is really nice. Brushed aluminum, super easy install, and very well made
If there's any other info I can provide, holler.
cblackstone is offline
post #556 of 9066 Old 09-01-2005, 10:07 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Sorry to have snapped at you. Currently, the largest eSATA drive is 300GB. But soon there will be 500GB drives from Seagate. And there are eSATA RAID solutions that hit 1.6 terrabytes - and are absurdly priced for anyone but the most well-heeled. There are many choices and soon there will be many more, so it is not possible to point you to one drive from one vendor and say it's the best. AT least imho.
pepar is offline
post #557 of 9066 Old 09-02-2005, 05:29 AM
BenDover's Avatar
not sure why you say the largest esata drive currently available is 300gb...i have 400gb and i believe the hitachi 500gb drives are out ...
BenDover is offline
post #558 of 9066 Old 09-02-2005, 09:27 AM
Quoted: 189 Post(s)
Liked: 83
He was probably speaking of the largest drive with eSATA cabled enclosure, and not the largest bare SATA drive. But, product announcements and press releases are always coming out...
v/r,
C-F
post #559 of 9066 Old 09-02-2005, 09:29 AM
HDugan's Avatar
I'm not a techie and get a bit confused with this.
This product is easy to identify as complaint with my 8300HD Cablevision box because it's advertized as such.
http://www.maxstore.com/product.asp?sku=2663284
But when I got into my local PC store I tend to get lost in the selection process. There's a lot of things called ~External Hard Drives~ but the box literture is a bit convoluting to me and I don't want to buy something that ultimately won't work for my purposes. That's why I'm putting my faith in the experts here.
I'm looking for clear alternatives to the Maxtor. They might be easy for you to pick but I'm foggy on this stuff.
A list of other model#'s that would simply plug into the 8300HD and work with a simple reboot would be greatly appreciated.
Have a Nice Day!
HDugan is offline
post #560 of 9066 Old 09-02-2005, 09:32 AM
davehancock's Avatar
Quoted: 111 Post(s)
Liked: 60
It didn't appear to me that pepar snapped, or owed any sort of apology. It seems that people somehow expect to get instant, FREE, answers on the Internet, and can't take the time to sort through what is already written.
Dave Hancock
davehancock is offline
post #561 of 9066 Old 09-02-2005, 09:45 AM
tony57's Avatar
There is no other vendor at this time other than Maxtor that provides a simple plug-n-play solution.
tony57 is offline
post #562 of 9066 Old 09-02-2005, 10:22 AM
HDugan's Avatar
WOW touchy. A visitor can't ask a question...who made you king of the sand box?
I do thank Tony57 for summing up what I couldn't figure out after indeed reading 19 pages. You just saved me time, money and headaches.
On page one ~other~ external drives are introduced into the thread. Talk goes to ports, cables, etc. I just got more and more confused. ~I am not a techie~.
More and more threads at AVSForum use summations, usually by the FIRST poster. This is a useful tool, especially when the topic strays a bit. Some thread are REAL BIG...years big.
My major criteria for visiting...
Was this plug and play the only model? (ANSWERED)
What is recommened Software version or requirements on 8300HD?
Does this software version vary from Cable co to cable Co?
Have a Nice Day!
HDugan is offline
post #563 of 9066 Old 09-02-2005, 10:30 AM
BenSanford's Avatar
The above is correct - The Maxtor unit designed specifically for the 8300 is the only really simple (one item to buy) plug-n-play solution.
However, as noted in many previous messages - the solution this thread started with is "almost" as simple. An external SATA enclosure, a SATA drive, and the proper cable from Crus or other sources, saves a few bucks, and offers more choices in hard drive size, warrantee period, etc. Plus you can always move the drive to a PC if your needs change, etc.
Several people have indicated the specific hardware items they purchased, and I would suggest buying off the net (I bought mine from newegg and got very prompt delivery). Often the people at the local computer stores are more interested in selling you what they have on hand rather than what you might really need.
If your Cable system used the "supported" software then it should be fairly simple from there. If it doesn't use the right software, then even the Maxtor box won't help.
post #564 of 9066 Old 09-02-2005, 10:56 AM
tony57's Avatar
FYI, when this thread was started, the only way to add storage was to 'build-your-own', as the Maxtor QuickView Expander was not yet available (or even known to become available).
Also, the QV expander will work with the 8300, but not for all cableco's. This is because not all cableco's software enable the SATA port (i.e., while SARA (used by cablevision) works, the PASSPORT software won't)
tony57 is offline
post #565 of 9066 Old 09-02-2005, 11:04 AM
tony57's Avatar
Yes, good point, I initially neglected to mention that the 8300 will work with the Maxtor QV ONLY if the STB's software enables the SATA port (i.e. cablevison's SARA allows an external drive, but cable co's that use PASSPORT with the 8300 will not).
tony57 is offline
post #566 of 9066 Old 09-02-2005, 11:34 AM
BenDover's Avatar
I thought I saw a Seagate over at Newegg the other day...
BenDover is offline
post #567 of 9066 Old 09-02-2005, 11:42 AM
tony57's Avatar
Good. I new that they were developing something along the lines of the Maxtor QV, but I didn't know that it was out yet.
Do you have a link?
Tony
tony57 is offline
post #568 of 9066 Old 09-02-2005, 11:57 AM
BenDover's Avatar
Do you have a link?
Tony
Oops, my bad...senior moment...or is it a blonde moment since i don't really consider myself a senior...
anyhow, what i saw was a number of buslink models offered at compusa...sorry
BenDover is offline
post #569 of 9066 Old 09-03-2005, 10:33 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Sometimes my information is a bit out-dated and technology moves fast. 300, 300, I have three hundred, do I have 400, 400, going, going, I have 400, do I have 500 . . .
pepar is offline
post #570 of 9066 Old 09-03-2005, 10:38 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
This "expert" says skip the local PC store and buy online. Most online vendors have clear, concise information about each and every item they sell. Whether you like to read very little or delve in and study (what to some would be esoterica) every last detail, the info is there. My experience with B&M vendors is that they either give you no information or mis-information.
pepar is offline
Reply HDTV Recorders
