Sony DHG-HDD250/500: Official Thread - Page 976 - AVS Forum | Home Theater Discussions And Reviews
 28Likes
Old 07-08-2014, 06:43 PM
JoeKustra's Avatar
Quoted: 731 Post(s)
Liked: 298
Originally Posted by speedlaw View Post
I have Cablevision. They pass HD signals as 2.1, 4.1, etc. They pass local channels too, (public access) but with intentionally bizarre numbers (99.124, 99.185). They come in clear QAM, only the OTA channels. So, even though analog is gone, and the Cable Co is using this to make sure you now have to rent a box for $8 per month forever per set, you will probably still get clear QAM for the OTA channels. Everything else is scrambled. If you get the HD with Cablecard, you get 702, 704, etc, but if you hook up the QAM tuner, you get them as 2.1, 4.1, etc. We cut all CATV service, keeping phone and internet....but we still get the OTA channels in clear QAM. I think the FCC requires this in most markets, save NYC and a few other cities.....sorry.
My TiVo won't work on the "free" QAM channels, because it can't match the guide and the 2.1 or 4.1, and you can't trick the guide into using the OTA guide.....whereas the Sony will do this.
Short answer, most folks will still get clear OTA via QAM even if they shut off cable, provided they still have some service to the home. I cut the cord last week, but with OTA (which is good for my sony boxes and the Tivos) and Hulu plus for the three cable shows I actually watched.
QAM is used for cable. OTA broadcast digital uses 8VSB modulation. the two are the same frequency from 2 - 13.
My Tivo Premiere Series 4 will perform manual recordings of clear QAM but the guide needs a cable card.
The 2.1 or 4.1 are probably PSIP virtual channels like your 700 and 704. Note that the 700 is a display issue and the clear QAM frequency is the physical location. You can verify a station's frequency with Wiki by using its call letters also. Sometimes they are the same.
JoeKustra is offline
Old 07-09-2014, 12:37 PM
KerryNY's Avatar
Originally Posted by WS65711 View Post
I always found that the DHG's with CableCards were much more prone to spontaneous resets than those without CableCards. YMMV
That was certainly the case for me. The major resets and .13 firmware eliminated most of the instability, but almost every time a new channel line-up was downloaded to the CableCard, I'd still get an automatic reset.
- Kerry
TiVo Premiere w/2TB internal upgrade and Lifetime Service. Sony DHG-HDD250 retired in 6/13: CableCARD, 1.2.13 firmware, reset weekday & time as needed with 147412356 code. (further time adjustments by the "Izzy method")
KerryNY is offline
Old 07-18-2014, 03:45 PM
Lucetius's Avatar
I was one of the early adopters. Unit #81 . HDD-500. Haven't used it for many years. I'm moving and need to find it a home. I'm in the L.A. area $50 to anyone who's interested. it's in great shape, remote, manual, etc.
send me a PM if interested.
Dietrich
Lucetius is offline
Old 07-31-2014, 02:01 AM
CleCakYngMfd's Avatar
Quoted: 345 Post(s)
Liked: 62
Reset Update:
Longest between updates. 2 months!
Still Slick Sailing along.
KerryNY likes this.
- Pj
My 'Review/Comments' and Settings for the 2016 Vizio P50-C1.
CleCakYngMfd is offline
Old 08-02-2014, 10:59 AM
qz3fwd's Avatar
Quoted: 310 Post(s)
Liked: 129
A brand new 250 sold on eby yesterday for $91!
I bid $20, but already have 2 so no need for another...unless someone reverse engineers the TVGuide protocol and someone figures out hot to feed the DHG guide data...
qz3fwd is online now
Old 08-02-2014, 02:04 PM
P Smith's Avatar
Quoted: 405 Post(s)
Liked: 249
I did some work on that, but see my recent answer in DTVpalDVR/CM7000/DVR+ threads why it's not feasible.
P Smith is offline
Old 08-03-2014, 12:12 PM
qz3fwd's Avatar
Quoted: 310 Post(s)
Liked: 129
I meant a seperate gizmo (device) which would "create" EPG data and mux it into the signal the DHG receives, but I guess that this would require a QAM / ATSC modulator which would likely be cost prohibitive yet not require any changes to the Sony hardware nor software? I was thining of a plug and play solution where you connect it inline between the wall coax outlet and input coax on the sony, hook up a ethernet cable, and use a webpage to setup the device (supplying your zip code) and thats it. One can dream.
Old 08-03-2014, 03:01 PM
Aleron Ives's Avatar
Quoted: 1458 Post(s)
Liked: 1158
You can buy a functional DVR for far less than the cost of the modulator necessary to get the DHG working, so there isn't much need to dream in that regard.
Aleron Ives is offline
Old 08-06-2014, 07:10 PM
smf_sony's Avatar
The cognoscenti may be able to find your post from the above information but the rest of us poor clucks need a link. please post a link that we can click on.
smf_sony is offline
Old 08-24-2014, 05:35 PM
mickinct's Avatar
Quoted: 188 Post(s)
Liked: 901
please someone send me link to how to start a manual recording on the dhg I want to record the EMMYS thanks.
MickinCT
mickinct is offline
Old 08-25-2014, 02:41 AM
izzy900's Avatar
Quoted: 26 Post(s)
Thumbs up
Originally Posted by mickinct View Post
please someone send me link to how to start a manual recording on the dhg I want to record the OSCARS thanks.
click link, download users manual (PDF) page 74, Nuff said.
https://docs.sony.com/release/DHGHDD250-500rev2.pdf
izzy900 is offline
Old 08-25-2014, 04:04 AM
mickinct's Avatar
Quoted: 188 Post(s)
Liked: 901
thanks
MickinCT
mickinct is offline
Old 08-30-2014, 04:52 AM
HoustonPerson's Avatar
Funny Clock News
We still use the Sony when we need to catch a "third" show and it still works ok. Our unit was always stable with TVGOS active and now it can be finicky and can sometimes lock up.
AFAIK every since the TVGOS went away, so did the clock on the face panel --:--.
During the last 2 -3 months the clock has come back with each power interruption; but with the wrong time.
Now I notice the clock is just almost exactly two hours off (1 hour and 55 minutes off) from the correct time. There is no information on the "info" screens as to where it is coming from? But the clock face does light up in less than 24 hours after most power outages.
I forget which year it is on, either 2000 or 2004 I think?
HoustonPerson is offline
Old 08-31-2014, 03:09 AM
Quoted: 345 Post(s)
Liked: 62
Talking
My experience with taming the instability issues is when I finally wiped-out the TVGOS patches. This means the Front Panel Clock will never come back, and you'll have Smoooooooooth Sailing 99% of the time.
So it appears you still have the 'patches' in there, which can keep instability issues going. Perhaps setting the zip code to all zeros may also calm things down without 'deleting' the patches, yes Izzy?
My resets bring up 1/1/2004. Some other units apparently bring up some other year(s).
- Pj
Old 08-31-2014, 07:26 AM
KerryNY's Avatar
Re: Funny Clock News
Interesting... is this the first case we've known (after the loss of guide signals) in which the front panel clock had been gone for months, and then returned?
- Kerry
KerryNY is offline
Old 08-31-2014, 09:03 AM
mabuttra's Avatar
Location: Wichita, KS OTA (w/optional cable connection)
Liked: 32
- Kerry
Shortly after TVGOS went away, my front panel clock came back once after losing it. It happened when my 250 crashed and rebooted. I was never able to duplicate that though. I even tried entering the 3923784866 'Generate Exception' code multiple times. That code always causes a reboot. I really think the clock coming back was just a fluke.
I believe the front panel clock dashes out when it has invalid data. Usually the TVGOS system will give 'permission' for the system to set the front panel clock from the TVGOS clock when TVGOS has received the proper GMT time and offset data. Giving the front panel clock valid data again. Unfortunately without TVGOS the TVGOS system is never allowed to send valid clock data to the front panel, so the time stays dashed. I believe it is feasible that during a major crash, the system could misfire allowing the front panel clock to be set.
Mark
mabuttra is offline
Old 08-31-2014, 01:13 PM
smf_sony's Avatar
Unable to find your reference
Please post a link that anyone can follow.
smf_sony is offline
Old 08-31-2014, 06:02 PM
KerryNY's Avatar
We might need something to happen with the Van Allen belts along with a planetary syzygy to reboot under the perfect conditions to bring back the FP clock.
Or one of Joe's tapes. ;-)
KerryNY is offline
Old 08-31-2014, 06:20 PM
Jed1's Avatar
Quoted: 72 Post(s)
Liked: 50
Actually I think that may translate into "one of Joe's tapes".
"You lose it in here you're in a world of hurt"
Jed1 is offline
Old 08-31-2014, 06:41 PM
TheRatPatrol's Avatar
Quoted: 54 Post(s)
Liked: 36
Wow I can't believe some of you are still using these.
I got rid of my two 2 years ago.
TheRatPatrol is offline
Old 08-31-2014, 07:18 PM
JoeKustra's Avatar
Quoted: 731 Post(s)
Liked: 298
Still cooking. Tape used twice a year to set the time and date. Record once a week now, but that will jump to three times in a few weeks. Two TiVos do most of the work.
Old 09-01-2014, 05:29 AM
mabuttra's Avatar
Liked: 32
I haven't used mine in about 15 months. It has been unplugged for the last 8 or 9 months. My one TiVo handles 98% of the recording, with a DTVPal used as an overflow recorder, but it has also been unplugged for the last 3 months. With the new fall season starting soon, I'll plug the DTVPal back in if I need it.
Mark
mabuttra is offline
Old 09-01-2014, 05:35 AM
mickinct's Avatar
Quoted: 188 Post(s)
Liked: 901
I used mine to record emmys then transferred to PC via HDMI to media player KDLINKS720.
MickinCT
mickinct is offline
Old 09-02-2014, 05:00 PM
qz3fwd's Avatar
Quoted: 310 Post(s)
Liked: 129
Sadly-I actually have 2 brand new never opened 250's siting in storage now for several years! Now they are paperweights...
Luckily I only paid ~$100/each not $1000 or whateve the original selling price was...
Old 09-02-2014, 05:10 PM
mickinct's Avatar
Quoted: 188 Post(s)
Liked: 901
Same here I had six of these never paid top $$ for any but resold before the crash as high as 600.00 for ea.
MickinCT
mickinct is offline
Old 09-02-2014, 06:14 PM
teeitup's Avatar
Quoted: 107 Post(s)
Liked: 43
Was that the closeout price from the Sony Outlet or Circuit City back a few years? Probably not many NIB 250's out there anymore.
I bought and sold my 250 on ebay. Went the Moxi DVR route and haven't looked back.
teeitup is offline
Old 09-02-2014, 06:58 PM
Quoted: 54 Post(s)
Liked: 36
Remember when the 500's were going for $250 at Tweeter? They went quick. Thats where I got my two from.
Old 09-02-2014, 08:41 PM
qz3fwd's Avatar
Quoted: 310 Post(s)
Liked: 129
Nope. Good old ebay...
Old 09-08-2014, 10:56 AM
speedlaw's Avatar
Quoted: 34 Post(s)
Got my two from the Sony outlet store back when I saw on this very list that they'd hit the remainder racks. I went through four or five at the sony outlet store before I got two that worked...luckily work isn't far away-and I've scored other things there, like a top line ES receiver for $285.00. I paid $250 for each one. The sales folks there had no idea what they were. This was prior to analog shutoff...
Had I known, I would have fought for the pretty HDD 500 (gold trim, very nice !!) on the display shelf.
These two grey boxes, prior to Rovi shutoff, saved me a bloody fortune in renting the SA 8300, the crappiest cable box in the world. They were cranky with cablecard, but the solution was to get the apparently only remaining single stream card at Cablevision. Overall, when PBS and then CBS carried a Rovi stream, in the NY DMA they were pretty stable.
I was never too annoyed at the various TVGOS stupidities, as I knew they were a first batch beta, and once Tivo lawyered them up, they shut down production...as a radio geek, it was more a challenge. For the normal buyer who hasn't memorized this forum, knows that Skiffspace isn't a comic book, and has mastered the (clearly leaked) command codes, the returns must have been immense. I was amazed Sony dropped the .21 update....
I'm still using two of them to feed SD Trintrons downconverted OTA HDTV via RGB output. Recording has gone Tivo, and the Cable has since been cut. I thought a $6 per month sports fee was a bit much, for a guy who DOES NOT WATCH SPORTS. At all. Straw, Back, Camel, etc.
(The tivo streams decently, so the WAF remains high) The late production SD sets look really good with the downconverted signals, and for bedroom/office, are leagues ahead of paying $8 x 2 per month forever for cable boxes. (When all my neighbors tossed out the old SD sets, I waited for the cherry Trinitron....and it eventually turned up-an almost unused 2006 (last production run ?)
I will always wonder what the HDD 1000 would have been like. The Sony boxes, while cranky with TVGOS, are solidly built. I dread the day the HDD crashes, as I don't think Sony still fixes them.
Does it still tune with a dead HDD ?
Hmmm.
In Vienna we sit, in late night cafe. Straight Connection, on T.E.E.
speedlaw is offline
Old 09-09-2014, 07:57 AM
KerryNY's Avatar
I think it wouldn't even boot with a completely dead HDD. But it might still work as a tuner with a partly damaged drive, as long as the boot sector and a few other critical areas are still good.
- Kerry
KerryNY is offline
sony dhg-hdd250/500 , vizio m401i-a3 40" hdtv
taboola here
