New moto 6412 with HDMI and SATA - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 1929 Old 08-30-2005, 07:14 AM
erics's Avatar
jc - I was wondering the same thing myself - I was thinking of trying to call Motorola, but I couldn't find the support number - they have zero documentation on the new box.
erics is offline
post #92 of 1929 Old 08-30-2005, 05:40 PM
DaveFi's Avatar
Quoted: 81 Post(s)
Liked: 36
Originally Posted by jc1455 View Post
Does anyone know if the 6412's SATA connector is supposed to be SATA I or SATA II? I checked the Motorola site but didn't see any info on the phase III.
I would bet it would be I, but you never know- they seemed to have gone all out this time around.
It would be nice if we could buy our own boxes with Comcast soon. I wouldn't mind shelling out $400 for this thing, it definitely seems worth it, especially if they enable SATA support.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
post #93 of 1929 Old 08-30-2005, 06:29 PM
SneakyPete's Avatar
Hey Guys,
I've had my 6412 phase III box for about 2 weeks now. A few observations.
1. The tuner is slower than on my previous 6412 (w/ the DVI port). There is also a noticeably longer audio delay when changing channels. Audio lags behind video by about 3 seconds. I personally find this annoying.
2. There is a built-in fan on the bottom of the unit, which is very quiet. It cannot be heard, even when standing directly in front of the unit.
3. Even with the cooling fan, the phase III units seem to run a little hotter than on all my previous 6412 units (w/ DVI port).
4. Other than the simplicity of the HDMI port (providing both video and audio to my plasma), I find little or no improvement over my previous 6412 units.
I'm actually on my third phase III box. The first two had some PQ issues when using the HDMI port.
Haven't tried the SATA port. However, I seriously doubt Comcast would enable this connection to its customers.
Pete
SneakyPete is offline
post #94 of 1929 Old 08-30-2005, 06:41 PM
scanpa's Avatar
Warning,
if someone does try a external HD, be warned, the 6412 STB will format both the internal & the external drive.
Comcast of Lebanon PA.
scanpa is offline
post #95 of 1929 Old 08-30-2005, 09:55 PM
DaveFi's Avatar
Quoted: 81 Post(s)
Liked: 36
Originally Posted by scanpa View Post
Warning,
So have you actually tried it?
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #96 of 1929 Old 08-31-2005, 12:49 AM
km
km's Avatar
Can someone with a 6412 Phase 3 on Comcast with Iguide confirm whether the 30 second skip still works?
km is offline
post #97 of 1929 Old 08-31-2005, 07:15 AM
Walter Lambert's Avatar
The new Phase III 6412 does have the 30 second skip.
Walter Lambert is offline
post #98 of 1929 Old 08-31-2005, 09:15 AM
km
km's Avatar
Thats good to hear! Elsewhere it was reported that firmware 10.10 kills 30 second skip (presumably on a phase 2). Since the phase 3 is reported to run 12.18, I wondered.
It would seem that the 10.10 report is either a provider/guide issue, or the phase 3 12.18 is in a different development line.
km is offline
post #99 of 1929 Old 08-31-2005, 10:58 AM
SneakyPete's Avatar
"The new Phase III 6412 does have the 30 second skip."
Didn't realize I have this functionality on my phase III unit (firmware 12.18). What button activates this on the remote?
Pete
post #100 of 1929 Old 08-31-2005, 11:18 AM
erics's Avatar
SneakyPete - you have to program it - search the 6412 w/Iguide thread for the instructions. I attached it to one of the PIP buttons which are unused. I made the other one into cable box un-mute which is needed when a recording starts when the box is off (also in the other thread).
erics is offline
post #101 of 1929 Old 08-31-2005, 11:47 AM
Keenan's Avatar
Quoted: 2216 Post(s)
Liked: 2007
How to program the remote for 30, 60, 90, 120 (and
more) Second Skip
Create a 30 second skip using the following
directions:
1) Press the "Cable" button at the top of the remote
to put it into
Cable Box control mode.
2) Press and hold the "Setup" button until the
"Cable" button blinks twice.
3) Type in the code 994. The "Cable" button will
blink twice
4) Press (do not hold) the "Setup" button
5) Type in the code 00173 for 30 second Skip.
6) Press whatever button you want to map the skip
to.
Next, you create a macro using your new 30 second
skip:
1) Press and hold down the "Setup" button until the
light blinks twice.
2) Press 995.
3) Press the key you want to assign the X second
skip to.
4) Press the button that you have used for the 30
second skip x times.
(2 times for 60 seconds, 3 times for 90 seconds, and
so on.)
5) Press and hold the "Setup" button until the light
blinks twice to
exit programming.
X = 30, 60, 90, 180, etc.
How to program the remote to control the mute on the
cable box instead of the tv.
1. Press the cable button
2. Press and hold setup until it blinks twice then
let
go
3. Press 994
4. Press setup and release
5. Press 00141
6. Press the mute button
Clear the Memory & HD
1. DCT6412 should be turned on
2. Press Cable, Power off, ok/Select, to bring up the
Diagnostics Page
3. With diagnostics page showing press Replay (15-sec
rewind), DVR, DVR, DVR, Live.
4. 6412 now should show "Clr" in the LED display.
5. Press ok/Select to proceed with the reset (and
presumably Exit to cancel).
6. The 6412 should now reset and download Your account
settings & Guide data from the Local headend."
Keenan is offline
post #102 of 1929 Old 08-31-2005, 12:39 PM
scanpa's Avatar
The following is NOT the facory reset, it is only the Clear the Memory & HD.
Diagnostics Page
If anyone needs a copy of the 6412 installer setup guide, please pm me with your email addy.
scanpa is offline
post #103 of 1929 Old 08-31-2005, 12:56 PM
thedvdguy's Avatar
Has anyone experimented swapping out the existing HD with a larger one?
For instance, does anyone know if the contents of a factory fresh existing 6412 HD could be completely copied to a new (larger) HD to obtain a larger amount of recording space? The original drive could then be stored in a safe place should the box ever need to be returned to Comcast.
Is this at all possible?
I know there are tools available that allow you to replace your existing TiVo drive with a larger drive, so what about this box?
thedvdguy is offline
post #104 of 1929 Old 08-31-2005, 01:15 PM
Keenan's Avatar
Liked: 2007
Diagnostics Page
Okay, I corrected the post. I think I got that from you, no..?
I post that whenever someone asks one of the questions...can you PM me with the factory reset? That way I can have all of the info in one spot.
Keenan is offline
post #105 of 1929 Old 08-31-2005, 01:42 PM
scooterboy's Avatar
There's a big difference between upgrading your tivo (and invalidating its warrantee) and opening up the 6412. Specifically, you OWN the tivo. You do not own the 6412 - you rent it.
So people would much prefer to find out that the SATA connection will work with an external drive and that the cable company will allow the expansion, rather than violate their contract by opening up the box. Don't forget that the 6412 is a two-way communication device. If you mess with it, they may be able to detect that quite easily.
But if you're volunteering to give it a go, please keep up posted!
"If you're not passing anyone, get the hell out of the passing lane!"
scooterboy is offline
post #106 of 1929 Old 08-31-2005, 01:59 PM
thedvdguy's Avatar
Yeah that is why I am hesitant about opening it up, even to just take a peak at the insides. I wish I could just buy the box instead of renting it, like I did with my TiVos. Once the 90 day warranty was up...it was open season. ;-) I was calculating my weekly HD recording and its going to be tight with only 15 hours of time. In the past with my upgraded SD TiVos I would get behind on some shows by as many as 4 or more episodes. Now I'll have to make sure I watch everything pretty much righ away or I'll run out of room very quickly.
Would someone please try this so I know if I should hound Comcast for a phase 3 box when I sign up. If I had the box and an external SATA drive I'd give it a shot, but unfortunately I don't . From what I've read, it sounds like the firewire port is only for backing up, not for extending the storage space.
I know, that's another reason why I am very hesitant about ever opening the box when I do get it.
Nope, not gonna be the guinnea pig on this one
post #107 of 1929 Old 08-31-2005, 02:17 PM
scanpa's Avatar
From what some of the Comcast techs have told me, they have tried a External SATA HD and it works, it did cause both of the HD, internal & External to be formated.
Thats all I know.
scanpa is offline
post #108 of 1929 Old 08-31-2005, 02:21 PM
DaveFi's Avatar
Quoted: 81 Post(s)
Liked: 36
Thats all I know.
When I see it I'll believe it.
As for opening up a rented box, be prepared to pay big fines or even lose your cable service permanently.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #109 of 1929 Old 08-31-2005, 02:47 PM
Keenan's Avatar
Liked: 2007
Thats all I know.
Excellent, now all I need is the new box...they're being bench tested for deployment in the SF bay area right now....
Keenan is offline
post #110 of 1929 Old 08-31-2005, 08:16 PM
jc1455's Avatar
SneakyPete - In your post you said you were on your 3rd phase III box due to PQ issues. What kind of issues did you have. On mine HD looks fine but the rest of the stations (digital and analog) seem odd. It's like maybe they have slightly blurred the image to hide noise (not that you'd need to do that on digital stations but I can see how it might help analog ones.) I notice it mostly on people's faces. Not horrible but I noticed it after swapping out the Phase II for a Phase III.
Other issues.
1. The tuner does seem a little slower. I notice it most when repeatedly pressing FF or RR. Sometime 15 seconds go by and then suddenly it catches us with the button presses I made. The Phase II did this too but it seems a little worse.
2. The fan is very quite...how quite? I didn't even know it had one until SneakyPete's post. Actually I noticed the hard disk chirping is quiter in the Phase III than the Phase II.
Wish I knew where to get an external drive with a SATA drive connectior to try out on the machine.
jc1455 is offline
post #111 of 1929 Old 08-31-2005, 08:17 PM
SneakyPete's Avatar
Erics & Keenan, Thanks for the great tip & instructions for programing the skip function on the remote. Very useful. I love this forum!!!
Pete
post #112 of 1929 Old 08-31-2005, 09:31 PM
mr2828's Avatar
Does the new RF output on these phase 3s just provide a pass through of the cable signal, or is it a modulated output that shows whatever the 6412 is displaying on its other outputs?
mr2828 is offline
post #113 of 1929 Old 08-31-2005, 09:32 PM
SneakyPete's Avatar
jc,
The issues I had were mainly with PQ on the HD channels (specifically Discovery HD). I thought the first two phase III boxes were defective, because I was getting some jitter and alot of jaggies on Discovery HD when outputting 1080i from the box. Changing the output setting to 720p helped but did not eliminate the problem. However, the 720p setting made the PQ on all other HD channels a little softer than with 1080i (at least on my particular display... Panny 50PX50U).
By comparison, the PQ on all HD channels was simply amazing on my previous generation 6412 (w/ the DVI port) with both the 1080i and 720p setting (with the slight edge going to the 1080i setting). I was just not seeing the same jaw dropping PQ from newer phase III units.
It wasn't until I got my third phase III box that I realized there was/is a broadcast issue with Discovery HD (as reported by others in the forum). Nevertheless, the jitter and jaggies are almost completely gone with my third phase III, even with the desired 1080i setting. Also, I am now getting the same amazing PQ with both the 1080i and 720p setting.
Other issues I had with the first two phase III units were
1. the box would self activate its mute function
2. occasionally, the remote would freeze and then 5-10 seconds later, the box would recognize & execute all the buttons/functions I pressed while the remote was frozen. This still happens on my third phase III box, but not nearly as often.
I did not notice much difference in the standard digital or analog channels between the older 6412 and phase III... probably because I was so focused on the HD channels.
Hope this helps.
Pete
post #114 of 1929 Old 09-01-2005, 12:04 AM
thorr's Avatar
Quoted: 42 Post(s)
Liked: 29
This is not first hand information, but a guy at work told me that his buddy replaced the hard drive inside his 6208 or the next model up (I can't remember which) with a larger drive and it automatically formatted the drive to the same size as the original drive, but it does work. You can't get more space, but you can archive hard drives.
thorr is offline
post #115 of 1929 Old 09-01-2005, 06:17 AM
hphase's Avatar
I apologize if this has been mentioned before, but be careful about "archiving" programming, either on the internal drive or the external SATA drive.
SA told me that with their box, because of the copy protection security features, if you have to change out you DVR box any content recorded with the old box WILL NOT PLAY through the new box. The security keys are different. There's no provision to change the key numbers
I'm not sure if the same thing will happen with Moto boxes. I don't have SATA on my unit.
I can see why this would be required by Hollywood (mass duplication of digital content on SATA drives) but it sux that you can't change the key in YOUR replacement box so that content recorded BY YOU can still be played.
hphase is offline
post #116 of 1929 Old 09-01-2005, 08:53 AM
DaveFi's Avatar
Quoted: 81 Post(s)
Liked: 36
Geez guys! Stop posting assumptions and somebody just try the thing. It's pointless until then.
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
DaveFi is offline
post #117 of 1929 Old 09-01-2005, 11:43 AM
Keenan's Avatar
Liked: 2007
I guarantee you, I soon as I get my hands on one I'll be trying it, I still can't believe nobody has tried it yet.
Keenan is offline
post #118 of 1929 Old 09-01-2005, 11:45 AM
scanpa's Avatar
Your Cable Head-end might not have that function enabled for there users Yet.
scanpa is offline
post #119 of 1929 Old 09-01-2005, 12:34 PM
QZ1
QZ1's Avatar
Can someone summarize the differences among the three phases of 6412 DVRs?
And approximately when they were each released.
QZ1 is offline
post #120 of 1929 Old 09-01-2005, 12:39 PM
Keenan's Avatar
Liked: 2007
The Phase III has not been released in the SF bay area yet, they are in the warehouse though, one of the posters in the SF Comcast thread works for Comcast and is keeping us up to date on the progress of getting them on the street. He was going to bench-test a Phase III with a SATA drive and get back to us. If it works for him it should work throughout the bay area, hopefully.
Keenan is offline
Reply HDTV Recorders
