New moto 6412 with HDMI and SATA - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 1929 Old 09-16-2005, 07:26 AM
flyersfan's Avatar
The fan in my Phase III unit is whisper quiet. The same can not be said for the hdd itself... it chatters quite a bit. Sometimes I pause what I'm watching just to let the hdd catch its breath.
mr2828 - it sounds like you got a bad unit.
I have noticed one disturbing trend. If I'm recording an HD channel, the other tuner seems to be dropping frames while watching another HD show. This doesn't happen all the time, but it has happened often enough for me to take notice. If this sort of thing is resolved by a firmware update, I may never see it since my cable co. (RCN Lehigh Valley) doesn't seem interested in pushing down updates.
flyersfan is offline
post #182 of 1929 Old 09-16-2005, 12:13 PM - Thread Starter
WiFi-Spy's Avatar
Quoted: 352 Post(s)
Liked: 672
you might have a signal power issue.
Tyler Pruitt - Technical Liaison at SpectraCal
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #183 of 1929 Old 09-16-2005, 01:38 PM
flyersfan's Avatar
Seems unlikely since it was recording during the times I noticed frames dropping. As soon as the recording on the other tuner finished, the picture was perfect. I've also checked signal levels and both tuners are good.
post #184 of 1929 Old 09-16-2005, 02:09 PM
Keenan's Avatar
Quoted: 2205 Post(s)
Liked: 1981
Were you recording on tuner 1 and watching live TV on tuner 2? You could still have a signal power issue. When the recording was over did you swap tuners to see if the live picture on the channel that was recording was okay?
Keenan is offline
post #185 of 1929 Old 09-16-2005, 03:10 PM
skijackz's Avatar
It was asked before but never answered. Because the 6412 is a two-tuner STB, can you use it for PIP and more importantly, HD PIP?
I see that you have one HDMI port so you would probably have to use a Component out (no DVI?)
skijackz is offline
post #186 of 1929 Old 09-16-2005, 03:52 PM
scanpa's Avatar
No.
The same Video signal is sent to all Outputs at the same time. The PIP buttons on the remote are for your TV/Monitor PIP (if you have that option).
Comcast of Lebanon PA.
scanpa is offline
post #187 of 1929 Old 09-16-2005, 04:04 PM
bobm's Avatar
Originally Posted by scanpa View Post
No.
Does this hold true for the PIII boxes? They at least have chipset support for 2 HDTV PIP. Don't know if the bussing to the connectors and the software is there or planned.
bobm is offline
post #188 of 1929 Old 09-16-2005, 05:19 PM
Keenan's Avatar
Liked: 1981
Concerning the capabilities of the Phase III box, I think it boils down to what Comcast wants to support/deal with. The box itself seems to be a very capable one for a multitude of functions.
Keenan is offline
post #189 of 1929 Old 09-16-2005, 06:49 PM
phsteele's Avatar
Originally Posted by keenan View Post
How to program the remote for 30, 60, 90, 120 (and
more) Second Skip
Create a 30 second skip using the following
directions:
1) Press the "Cable" button at the top of the remote
to put it into
Cable Box control mode.
2) Press and hold the "Setup" button until the
"Cable" button blinks twice.
This may be a stupid question, but the remote that came with my 6412 doesn't have a setup button. I don't see a model number on the remote but it is a Motorola product. Along the top are four device buttons (audio, DVD, TV, and Cable). Where should the Setup button be located?
phsteele is offline
post #190 of 1929 Old 09-16-2005, 07:26 PM
Keenan's Avatar
Liked: 1981
If it doesn't look like this one then I don't know what to tell you, I have no experience with anything else.
Keenan is offline
post #191 of 1929 Old 09-16-2005, 08:50 PM
alleng's Avatar
Thank you folks for the information. I now have quick skip on my cable HD DVR.
alleng is offline
post #192 of 1929 Old 09-17-2005, 05:12 AM
phsteele's Avatar
Mine looks exactly like the one on the Motorola site. I did some more checking and it's the DRC800 remote. Check out the picture on page 13 of the online manual. The manual is URMD2.pdf (Sorry, I'm a new poster so it's not letting me include URLs).
phsteele is offline
post #193 of 1929 Old 09-17-2005, 10:53 AM
Keenan's Avatar
Liked: 1981
I just looked at that remote and I don't know anything about it, someone else here might though.
http://broadband.motorola.com/catalo...?ProductID=392
Motorola - Template
Keenan is offline
post #194 of 1929 Old 09-17-2005, 11:11 AM
mr2828's Avatar
I used to have one of those with the very first 6412 I got last year. You don't want it - there is no way to program the 30-second skip on it, plus it is not as ergonomic to use/hold as the silver remote, and also I think the IR emitter in it may be a bit less powerful because I remember having to aim it very directly at the 6412.
Call and try to get them to agree to swap it out for a silver one, or if that won't work then take it back to your local Comcast office and play dumb and tell them it's broken and you need a new remote.
mr2828 is offline
post #195 of 1929 Old 09-17-2005, 11:22 AM
QZ1
QZ1's Avatar
My opinion is that even the silver remote is not so good. I used it for a while, it is not intuitive. Better to get a Harmony, which ever model you choose, it will be a much better layout. If you think you will be good at detailed programming, (I learned on the fly), then I recommend a Home Theater Master.
QZ1 is offline
post #196 of 1929 Old 09-17-2005, 11:48 AM
phsteele's Avatar
I actually use the MX-500, but there's no way I'll be able to program a key on that one unless I have a remote that sends out the correct signal. I could then use learn to program a key on the MX-500. I'll ask my local cable provide to see if they can supply the newer remote.
phsteele is offline
post #197 of 1929 Old 09-17-2005, 04:33 PM
phsteele's Avatar
A quick question. Could somebody with the silver Motorola remote post it's product number? I need to know what to ask my cable company for. Thanks!
phsteele is offline
post #198 of 1929 Old 09-17-2005, 06:00 PM
km
km's Avatar
There were some earlier posts discussing PIP, hoping to get different program streams out of different output ports. We know the 6412 by design puts out the same stream on every port.
However, what about the more standard question about whether the 6412 Phase 3 can compose a single output from two streams with one "pip'd" in a corner of the other. I believe the MS Ultimate TV competitor to Tivo did this. I also believe its been established that the Phase 2 didn't have the necessary hardware support.
Does the Phase 3 have the necessary hardware, and does the IGuide that runs on it support this?
km is offline
post #199 of 1929 Old 09-17-2005, 11:44 PM
TheRatPatrol's Avatar
Quoted: 67 Post(s)
Liked: 59
I can't believe they didn't put a bigger hard drive in this unit. 15 hours for HD is nothing. With the size of hard drives today they could have easily put a in a bigger HD. What were they thinking?
Does cable use MPEG2 or MPEG4 to deliver its HD content? If its MPEG2 and they switch to MPEG4, could they get more content on the hard drive?
TheRatPatrol is offline
post #200 of 1929 Old 09-18-2005, 04:00 PM
QZ1
QZ1's Avatar
It is actually claimed to be 12-20 hours, apparently depending on the birate. Once, someone was actually able to get 23 hours of HD on it.
QZ1 is offline
post #201 of 1929 Old 09-19-2005, 12:17 PM
bkozlowski's Avatar
Originally Posted by km View Post
Does anyone actually know what Comcast's plan is for increasing DVR disk storage?
They conceivably could do it with usb or firewire drives on any phase of 6412, or require a phase 3 and do SATA, or just provide units with larger internal drives. They could allow user supplied external drives, or force you to rent one from them.
Have they ever said which of these options they are going to actually do?
I just got a second DVR (a Phase III) and the manual that came with it was for a DCT6412 and a DCT6416, a 160 Gb version.
-b
bkozlowski is offline
post #202 of 1929 Old 09-20-2005, 08:26 AM
snowcat's Avatar
Quoted: 56 Post(s)
Liked: 63
My older 6412 was killing all my recordings in the middle (very annoying), so I got it replaced yesterday with one of the phase 3 boxes.
I have noticed two improvements.
1. Analog channels look better. This box is hooked up to a 27" analog CRT, but it didn't seem as sharp as it is does now (connected via S-video).
2. The fast foward function is much faster than before. Even at FF4, the old 6412 seemed to take forever to get through a 30-minute program. This new one got through 30-minutes in about 2 minutes.
I have another older 6412 hooked up to my HDTV, but I don't want to replace it yet since I only have a DVI-HDMI cable.
snowcat is offline
post #203 of 1929 Old 09-20-2005, 10:02 AM
abroadst's Avatar
Just got my 6412 phase III today from RCN here outside Boston. It has firmware 12.13.
Any thoughts on how to enable 30-second fast forward with this remote? It's different than any of the Comcast remotes described here. They gave me a Contec Synergy V universal remote. Model RC-U62CDR. (Picture attached)
Also, anyone know how to tell if SATA is enabled on RCN's system without buying an external HD and trying it?
abroadst is offline
post #204 of 1929 Old 09-20-2005, 12:33 PM
LYU370's Avatar
Looks an awful lot like an OFA/UEI remote. Try following the same procedure as described in this thread.
Andy
Not a single Monsterously over hyped cable to be found in my system.
LYU370 is offline
post #205 of 1929 Old 09-20-2005, 01:06 PM
abroadst's Avatar
Except there's no "Setup" button.
D'oh!
abroadst is offline
post #206 of 1929 Old 09-20-2005, 01:39 PM
Keenan's Avatar
Liked: 1981
D'oh!
What does the mode button do?
It does look a lot like the Comcast remote..
Keenan is offline
post #207 of 1929 Old 09-20-2005, 03:31 PM
SilverHemi03's Avatar
If your's is dark charcoal it's most likely a DRC 800 and not programmable like mine
Check the manual attached:
DRC800_User_Guide.pdf 193.958984375k . file
SilverHemi03 is offline
post #208 of 1929 Old 09-20-2005, 05:03 PM
abroadst's Avatar
On the RCN-provided remote you press the mode button and then one of the "one-touch power" buttons, like "DVD" for example. This switches the meaning of the play button, for example, to mean "play the DVD" as opposed to "play the DVR recording." There are several other buttons, like the volume that might have an ambiguous meaning without knowing which mode you're in. Like should the TV volume go up, or the cable box volume, or the "Audio" device, a.k.a. the receiver. Mode disambiguates. Without pressing "Mode" first the buttons labeled "DVD," "Audio," et cetera act as power buttons.
The remote is programmable, and I have a manual, but I can't figure out how to set up a macro.
abroadst is offline
post #209 of 1929 Old 09-21-2005, 04:44 PM
QZ1
QZ1's Avatar
You are correct, but, if need be, you can buy a very inexpensive ($15 ?) OFA remote at Radio Shack or elsewhere, and program the Motorola STB code into it, and bingo you have the 30 Sec. Skip that can be learned into the HTM MX-500 or other model. BTW, the silver remote is a OFA produced for Comcast. Of course, Harmony has the Skip in a number of it's 6412 profiles, for those that have one of their remotes.
QZ1 is offline
post #210 of 1929 Old 09-21-2005, 09:25 PM
number2withacoke's Avatar
Even with it turned off the fan wont stop running. HELP!
number2withacoke is offline
Reply HDTV Recorders
