Time Warner Cable Navigator - Page 633 - AVS | Home Theater Discussions And Reviews
 166Likes
post #18961 of 18974 Old 04-07-2015, 05:09 PM
phildaant's Avatar
Quoted: 485 Post(s)
Liked: 155
Originally Posted by therealjustin View Post
All better now, thankfully. I contacted TWC on Twitter and they replied that there was an outage in my area.
It lasted from 2:30am to 11:30am
I hope you asked for credits for that nine/9 hours!
kjpjr likes this.
phildaant is offline
post #18962 of 18974 Old 04-10-2015, 07:36 PM
G1Ravage's Avatar
Haven't been here in a while.
FiOS will soon be available in my apartment building. Not sure I want to give up NY1 and The Weather Channel, though.
Time Warner Cable - New York City - Flushing, Queens
Scientific Atlanta Explorer 8300HD
Formerly Passport Echo 2.6.002
MDN 3.3.0-9-ptv (3.Dev)
G1Ravage is offline
post #18963 of 18974 Old 04-10-2015, 07:43 PM
phildaant's Avatar
Quoted: 485 Post(s)
Liked: 155
Lucky you. I would get FIOS to dump TWC for faster Internet. I care not for The Weather Channel and NY1 (whatever that is).
post #18964 of 18974 Old 04-10-2015, 07:52 PM
davehancock's Avatar
Quoted: 67 Post(s)
Liked: 48
Originally Posted by phildaant View Post
Lucky you. I would get dump TWC for faster Internet. I care not for The Weather Channel and NY1 (whatever that is).
As someone who has had both TWC & FiOS, let me tell you that FiOS is not all that great. It has worse software (harder to use, prone to have problems with software "upgrades", etc.
What IS good, is that the G1Ravage is now in a position to negotiate better terms with TWC.
Dave Hancock
davehancock is offline
post #18965 of 18974 Old 04-17-2015, 12:21 PM
chaswms's Avatar
Just posted this at Time Warner Cable Direct (https://www.dslreports.com/forum/timewarnerdirect):
For the past two days, Search on the STB ("B" on remote) is NOT returning HD channels (digital channel + 1000 in market) for all results. Previously, a search would return analog channel, digital channel and HD channel (e.g. USA is SD 33, SD 201 and HD 1201). It seems like TWC may have made a change such that only 33 and 1201 are returned, perhaps since 33 & 201 just point to the same channel. It also appears, though, that programs on some of the SD channels are mistakenly marked as HD. E.g., searching for a program on CBS should return SD 7 & HD 1007, but only channel 7 (with the program marked as HD) is returned by the search.
Please note that while we have one of your earlier iterations of channel numbers grouped by genre, we do not have your latest version, nor does our configuration automatically provide the HD channel. So that functionality shouldn't be causing the issue (unless it's partially and incorrectly implemented in our market).
Please look into this and let me know when the problem is resolved.
ODN 7.3.1_6, Cisco 8742HDC
chaswms is offline
post #18966 of 18974 Old 04-20-2015, 10:55 AM
stuart628's Avatar
Quoted: 13 Post(s)
I have the cisco 8742 and also the cisco HD box (not sure of model number) and the volume out on these boxes seem REALLY low...When I am watching HDTV my pioneer vsx 822k needs to be turned to around 55 for volume to be able to be at a good level, when using the xbox one or any other source I can go down to 40...thats a big difference and the sound just isnt as "filling" on the cable box....anyone else have this issue? any fixes?
stuart628 is offline
post #18967 of 18974 Old 04-20-2015, 03:36 PM
danki6x's Avatar
Quoted: 16 Post(s)
Liked: 33
Verifying the obvious first. You have turned the volume up on the box (not just the TV)? Sometimes the remote is set to only adjust the TV volume so use the buttons on the box initially to get what you want. /Dan
danki6x is offline
post #18968 of 18974 Old 04-21-2015, 06:17 AM
stuart628's Avatar
Quoted: 13 Post(s)
Dan the 4742HDC does not have buttons on the front, and the HD Dvr does but I did check and the volume buttons do nothing. Are they suppose to?
post #18969 of 18974 Old 04-21-2015, 01:55 PM
in past when a 8742 setting for audio was set to narrow - sound was lower than when it was set to normal or wide.
bgrpph is offline
post #18970 of 18974 Old 04-21-2015, 05:54 PM
danki6x's Avatar
Quoted: 16 Post(s)
Liked: 33
My 4642 does adjust volume on the front. The 8742 DVR has volume on the front but do not seem to move while the channels do work. I could not find a setting either for volume changing. Must have been my previous DVR that I moved the volume before resetting the remote to only do the TV. Not sure if an unmodified remote will adjust volume on the 4742 you have.
/Dan
danki6x is offline
post #18971 of 18974 Old 04-22-2015, 01:57 PM
stuart628's Avatar
Quoted: 13 Post(s)
/Dan
that gave me an idea, I have a onkyo remote and tried that, and it did not change volume, but I see in settings where volume is fixed and there is no way to change that, also I did change sound to narrow and that helped a bit, but still not very loud..oh well.
post #18972 of 18974 Old 04-24-2015, 04:54 PM
mfogarty5's Avatar
Quoted: 59 Post(s)
Liked: 47
It looks like navigator will live a little longer now that the merger with Comcast isn't going to happen.
Does anyone have the TWC "enhanced" 6 tuner DVR? If so, can non-DVR boxes pause live tv or does trick play functionality only work for recorded programs?
phildaant likes this.
mfogarty5 is offline
post #18973 of 18974 Old 04-24-2015, 05:41 PM
BWX
BWX's Avatar
Quoted: 38 Post(s)
Liked: 64
Damn this P.O.S. Navigator to hell and the people who "program" it. The bane of my TV watching life.
Samsung SMT-H3272 - Nav.7.1.2.1
SA 8300HD (no C) *AZiO ENC311SU41* eSATA- WD black- 1TB - it works!-
-8300HD no more because TWC deliberately made it unusable in my area! :-/ :-(
BWX is offline
post #18974 of 18974 Unread Today, 11:02 AM
ncmikey's Avatar
I was given a procedure a couple years back here in Greensboro NC that enabled me to back up and restore the series manager settings on my Samsung SMT3272 DVRs. I seem to have misplaced this procedure. Is there someone who knows what I am talking about and can provide it to me?
Bear in mind it only backs up and restores the series manager settings. It does not do anything for recorded programs.
Thank you
ncmikey
TWC Signature Home 2-SMT3272 DVR, ODN 7.3.1_5
ncmikey is online now
Reply HDTV Recorders
