FusionHDTV5 RT Gold channel mapping issue with Comcast - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-14-2007, 09:45 AM - Thread Starter
Xavier's Avatar
I got the FusionHDTV5 RT Gold RT and the channel it tunes to are not same as the ones from the guide.
For example. the card tunes (QAM) Fox 13 to channel 810 when it should be 113.
I could manually fix all the channels but there is probably a better way.
Xavier is offline
post #2 of 2 Old 06-21-2007, 08:56 AM
squee0's Avatar
I have the same issue, the numbering is all whacked, and there's no way to give the numbers some sort of station name, also do you have issues where the same channel will change numbers, like sometimes ABC Family is one channel number and then I come back later and its another number (usually its like 448 and then 449) this makes it a pain in the ass to record.
Also have you had any problems with the .tp streams that it records... when i run it though mpeg2repair i get a whole lot of warnings, and sometimes the commercials come in encrypted and screw up the whole stream... Is there a better card...
I just came across this one apparently its a dual tuner and uses Ethernet for transmission so it doesn't need any PCI slots
http://store.snapstream.com/hdhr.html
Thanks & have a wonderful day.
squee0 is offline
Reply HDTV Recorders
