Comcast - Motorola DCH Set Top Box - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 645 Old 04-23-2009, 05:36 PM
Orbert's Avatar
Another option might be to "play" the DVR recordings you want to save, but direct the output to a video capture device connected to your PC, and save them as .avi files (or whatever other options might be available). Pinnacle makes a device that takes your standard red-white-yellow RCA and feeds it to your PC via USB, where the proprietary software converts it to files on your hard drive. You can then view them on your PC, burn them to disc, etc.
That may be a bit more trouble and/or expense than you're willing to go through to save some DVR recordings, but it is an option, and may actually be feasible if you already have the hardware and software.
Orbert is offline
post #632 of 645 Old 04-24-2009, 10:34 AM
ak3883's Avatar
You can do this, but the much easier way to just buy a basic $99 DVD Recorder that records from composite line inputs. Way easier than setting up software, drivers, adjusting quality settings, etc etc. You don't have as much flexability in creating custom menus and such, but if you are looking to just get material off the DVR onto a DVD, a standalone DVD recorder is probably the easiest way.
Of course this is only for SD, and any HD material played back would be recorded in widescreen format/SD...
ak3883 is offline
post #633 of 645 Old 04-24-2009, 12:21 PM
Orbert's Avatar
Ha, yeah, I guess you could do that, too.
It didn't occur to me because I already do have the Pinnacle setup, which I use to transfer my old VHS home movies to DVD, but I edit them on the PC first, and of course PCs these days all have DVD burners. Stuff from right off the cable box is probably fine going to a standalone DVD recorder.
Orbert is offline
post #634 of 645 Old 05-02-2009, 03:08 PM
jjbenetti's Avatar
Does anyone know of using an Ipod device 0r iphone connected to the usb connection and able to play audio/ video via the DCH 3416?
John J.
jjbenetti is offline
post #635 of 645 Old 05-02-2009, 03:13 PM
bicker1's Avatar
I haven't heard of any DCH-series boxes with their USB ports enabled for data transfer.
bicker1 is offline
post #636 of 645 Old 05-03-2009, 10:22 AM
SlipJigs's Avatar
I go the iPhone AV cable from Apple and just hook it in to one of the TV inputs - works fine.
SlipJigs is offline
post #637 of 645 Old 05-03-2009, 04:53 PM
beichst's Avatar
Hello. I am a newbie to the AVSForums.
Is this the correct forum/thread to ask a question regarding capturing and converting .ts content from my Comcast DCH STB down to my pc for DVD editing using CapDVHS and HDTVtoMPEG? If not, can someone please help direct me to the correct forum/thread?
Thank you.
beichst is offline
post #638 of 645 Old 05-11-2009, 06:00 PM
B.R.'s Avatar
Anybody know how big the DCH100 is.
B.R. is offline
post #639 of 645 Old 05-11-2009, 10:53 PM
Clint S.'s Avatar
Quoted: 48 Post(s)
Liked: 0
Thank you.
Since no one has answered, you may want to start a new thread, or ask in this thread if it's one of those models.
God Bless,
-Clint
Clint S. is offline
post #640 of 645 Old 05-11-2009, 11:17 PM
Ken H's Avatar
Thank you.
Start here:
http://www.avsforum.com/avs-vb/showthread.php?t=403695
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #641 of 645 Old 11-20-2009, 11:07 AM
smack518's Avatar
Hi guys,
I have a DCH-3216 from Comcast in Center City Philadelphia. I just purchased a IR->bluetooth device which needs to draw power from an always on USB port (the ones on the ps3 won't work because they are not powered when the ps3 is off). Does anyone know if the USB ports are activated from Comcast in Philly? Again, I don't need any data, I just need power.
And if they are not given out powered, can I call Comcast and ask them to activate the ports, or is that something that needs to be done at the factory?
Any help would be much appreciated.
smack518 is offline
post #642 of 645 Old 11-20-2009, 11:14 AM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
Originally Posted by smack518 View Post
Hi guys,
I just paid $1.39 to Solve my Always-On Charging Problem
drhankz is offline
post #643 of 645 Old 11-20-2009, 11:58 AM
smack518's Avatar
I appreciate the link, and it looks like a good cheap solution. Should I take that to mean the usb ports are NOT powered?
smack518 is offline
post #644 of 645 Old 11-20-2009, 12:28 PM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
I'm not 100% sure - I don't trust USB ports for power.
drhankz is offline
post #645 of 645 Old 11-21-2009, 03:30 AM
Clint S.'s Avatar
Quoted: 48 Post(s)
Liked: 0
Yeah, 5v and only 500mA.
God Bless,
-Clint
Clint S. is offline
Reply HDTV Recorders
