Will this work with my setup??? (Mitsubishi HS-HD2000U) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-23-2007, 01:30 PM - Thread Starter
Analyzer52's Avatar
Want to get an HD VCR to record OTA programming (no cable). I have a Set Top Box and CRT Toshiba, will I be able to record with this VCR in HD? LG LST-4200A (Set Top Box) and Toshiba 34HF85 (CRT TV)
This is the decription I saw for the product for sale from the seller but not sure if my setup has what is needed to hooked it up, the seller is say it will work with any HD setup is that true? Thanks in Advance.
Product description from seller:
Mitsubishi introduces the new Model HS-HD2000U
a D-VHS HDTV VCR.
This state-of-the-art VCR combines the new D-VHS standard for recording high definition and standard digital signals with all of the quality and performance of a premium S-VHS VCR. It receives its high definition signal in digital form through an IEEE 1394 network connection to an integrated HDTV or IEEE 1394*equipped HDTV receiver
Analyzer52 is offline
post #2 of 3 Old 01-23-2007, 02:53 PM
timecop's Avatar
Your LST-4200A has no firewire out, therefore no, it will not work with the mitsu DVHS.
Generally, D-VHS will only record high-def from a firewire source.
LST-3410A, on the other hand has firewire out and would work.
timecop is offline
post #3 of 3 Old 01-23-2007, 03:44 PM - Thread Starter
Analyzer52's Avatar
Thanks that is what I thought he looked to be trying to just make the sale I'll look into getting a different set top box.
Reply HDTV Recorders
