DVHSTool Alternative? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 02-01-2007, 05:43 PM - Thread Starter
tridens's Avatar
I am capturing HD content via firewire from a Motorola 6208 HDTV-Tuner. DVHSTool is nice, but are there any alternatives? I would really like to be able to break the capture file into chunks so that I don't have single 10+ GB files.
Any suggestions are appreciated! Thank you.
tridens is offline
post #2 of 12 Old 02-01-2007, 09:24 PM
timecop's Avatar
CapDVHS allows splitting, I think, but what's your aversion to 10gb+ files?
timecop is offline
post #3 of 12 Old 02-01-2007, 10:44 PM - Thread Starter
tridens's Avatar
I get bluescreen when I try to view them.
tridens is offline
post #4 of 12 Old 02-01-2007, 10:55 PM
timecop's Avatar
Sounds like time for windows reinstalll, I have number of 30-50gb files without any problems...
timecop is offline
post #5 of 12 Old 02-01-2007, 11:32 PM - Thread Starter
tridens's Avatar
Fresh install of Vista as of 20 hours ago.
tridens is offline
post #6 of 12 Old 02-02-2007, 08:06 AM
Person99's Avatar
Liked: 125
Neither of these can yet handle 5C encryption correct?
Dave
Person99 is offline
post #7 of 12 Old 02-06-2007, 04:41 PM
HDHTPC's Avatar
No, you basically can't record anything 5C encypted using a windows PC.
The player app that comes with the DVico Fusion ATSC tuner cards has the ability to record from IEEE1394 devices as well. (It can also decode AAC audio from Japan BS D-VHS tapes)
HDHTPC is offline
post #8 of 12 Old 02-06-2007, 04:49 PM
timecop's Avatar
Too bad Media Player Classic can do that as well, and without any external filters.
What I'd like to have is some tool thats faster than murdoccut for cutting MPEG2/AAC streams - have not found anything as usable as womble mpeg wizard is for MPEG2/AC3...
timecop is offline
post #9 of 12 Old 02-06-2007, 05:14 PM
gridleak's Avatar
DVHSTool does allow splitting. Go to menu/DVHS/Settings/File Segment Size.
-Roger
gridleak is offline
post #10 of 12 Old 12-16-2008, 10:29 AM
thestewman's Avatar
Quoted: 330 Post(s)
Liked: 109
Can anyone explain this error when trying to install DVHSTool
DVHSTool is not allowed to run on Win6.0 - Install aborted
thestewman is offline
post #11 of 12 Old 12-16-2008, 11:03 AM
Person99's Avatar
Liked: 125
Windows 6.0 is Vista (also known as Longhorn). Basically, the installer is telling you they don't support Vista.
Person99 is offline
post #12 of 12 Old 12-16-2008, 11:22 AM
thestewman's Avatar
Quoted: 330 Post(s)
Liked: 109
Thanks for the prompt reply
Reply HDTV Recorders
