HD DVR - watch recorded HD on SDTV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-09-2007, 05:50 PM - Thread Starter
afx
afx's Avatar
i'll be getting a 4250hd or 4200hd; not sure which yet, but i don't think it's relevant anyway.
will i be able to record in the hd shows (in hd) and watch them on a sdtv? i don't always have access to the hdtv.
on another note, can this hd dvr also record sd channels (in sd, of course)?
thanks.
afx is offline
post #2 of 3 Old 02-09-2007, 07:06 PM
maharg18's Avatar
Yes, it will downconvert the signal so you can watch it on your standard TV. It will be able to record all SD channels as well.
maharg18 is offline
post #3 of 3 Old 02-09-2007, 07:43 PM - Thread Starter
afx
afx's Avatar
thanks very much for verifying that.
afx is offline
Reply HDTV Recorders
