SA 8300hd/dvr.. IR/RF compatable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-09-2007, 02:11 PM - Thread Starter
crod1's Avatar
hey guys, im looking at remotes right now. ive been trying to find out if the
scientific atlanta 8300hd/dvr is RF compatable?
if not, i noticed it has an IR plug in the back , (im assuming i could us an IR repeater?)
which would be fine, but somewhere else on this forum a member said in his area the IR plug doesnt work. anyone know anything about this to help me?
thank.s
crod1 is offline
post #2 of 7 Old 04-09-2007, 02:41 PM
sddave's Avatar
The 8300HD is not RF Compatable.
The IR Jack on the back is an output, and probably is not active.
Dave
sddave is offline
post #3 of 7 Old 04-09-2007, 03:29 PM - Thread Starter
crod1's Avatar
so.. am i basically screwed in trying to hide the box??
is their anything i can do?
crod1 is offline
post #4 of 7 Old 04-09-2007, 04:16 PM
archiguy's Avatar
Quoted: 3932 Post(s)
Liked: 4080
Not at all. Since I have 2 SA8300's which, of course, use the same code set, I use RF to control them independently. I use a URC MX-800 remote (IR & RF capable) and a RF basestation (MRF-200) that feeds IR commands to each device with a small, wired "emitter" that's stuck onto the display window of the DVR. You'll need to do something similar, but it's no big deal. Just make sure you get the right remote (one that's both IR and RF capable).
archiguy is online now
post #5 of 7 Old 04-09-2007, 06:02 PM - Thread Starter
crod1's Avatar
does the wired emitter plug into the IR port on the dvr? the only part you lost me on is the emitter.
oh , wait a minute. the "emitter" sticks on the front of the box, is wired into the RF basestation? ...
do the emitters come with the RF basestation.?
crod1 is offline
post #6 of 7 Old 04-10-2007, 06:16 AM
archiguy's Avatar
Liked: 4080
The emitters are little wires that plug into the back of the RF basestation (they're included). They stick onto the display window of the 8300 and transmit a low-level IR signal that no other component can see. It's the easiest and simplist solution to this problem of multiple devices using the same code set that I've seen. I've been doing it for years; works great.
post #7 of 7 Old 04-10-2007, 01:26 PM - Thread Starter
crod1's Avatar
thanks. you solved my problem....
crod1 is offline
Reply HDTV Recorders
