Mitsubishi DLP TV and Intellasys/Indigita/Cinemavu IEEE1394 HD DVR Units - AVS Forum | Home Theater Discussions And Reviews
post #1 of 82 Old 06-08-2007, 09:18 PM - Thread Starter
bwall23's Avatar
Is there anyone successfully using these (record & playback) IEEE1394 firewire DVR's?
I'm having a problem that may seem trivial, but believe me, it's a major frustration.
WD-xx831 - Is anyone else having problems with firewire IEEE1394 record/playback?
Mitsubishi WD-57831, WD-65831, WD-73831
Do any owners of the above sets have this problem?
What are you using for your firewire (IEEE1394) recorder?
I've been unable to resolve the problem dealing with Mitsubishi.
Intellasys (INDIGITA / CinemaVU) says "The dropped audio is a decoding issue with the Mits TV" and I haven't received any more than that from them.
Here's the problem...
The problem is that I'm experiencing audio dropout when playing back recordings made via firewire from the TV.
Here's all the detailed info regarding the problem.
5.1 audio problem
My problem is with Surround Sound (Dolby Digital 5.1) losing LFE (low frequency effect) component and sound drops out for a second or two intermittently when playing back 1080i (Discovery-HD, UHD, MHD, NBC, PBS, etc.) firewire recordings, 720p (FOX, ESPNHD) are fine. BELIEVE ME, IT"S A MAJOR ANNOYANCE.
Watching the program while it's being recorded doesn't exhibit the problem.
Source for recording is the WD-57831 thru NetCommand out firewire, and the inputs are;
1) Comcast digital cable into ANT1 w/Motorola v04.21 cablecard
2) Comcast digital cable directly into ANT2
3) OTA antenna into ANT2
Happens whether I'm using my Windows XP PC w/Firebus driver, an RCA DVR2080 or a CinemaVU C-VU500 HD-DVR (INDIGITA AVHD-500) to record/playback via firewire.
Have tried 6 new S400 6p-4p firewire cables from 3 to 15 feet long.
Dolby 5.1 (AC3) signal is being output from the TV digital audio out to a Sony HT-DDW830A/V receiver, coax digital audio in and sent to it's 6 surround sound speakers.
The A/V receiver works fine with multi-channel, DD & DTS sound output from my DVD player and also from the TV while recording content with DD 5.1.
Have tried 2 different cables for digital audio from the TV to the A/V receiver. They both work fine while viewing the program being recorded and also work fine from my DVD player to the A/V receiver. i.e. the cables are good.
If I tell my A/V receiver to output (downmix to) stereo instead of Dolby 5.1, I don't have the problem.
If I use the TV's built in stereo speakers, I don't have the problem.
If the recorded program is not in Dolby 5.1, I don't have the problem.
I've tried disabling TVGOS while recording and playing back and also disconnecting every input except firewire while playing back and it doesn't help.
Installed new firmware (V33+ 008.02) shipped from Mitsubishi 03/22/2007 and that didn't help.
Split the cable in to ANT1 & ANT2. Memorized ANT2 channels and using ANT2 recorded NBC-HD 1080i w/Dolby 5.1 for 25 minutes. No dropouts during recording. Playback has audio dropouts. It's not the cablecard since that's only active on ANT1 input.
I put cable back to ANT1 w/cablecard and attached my indoor OTA antenna to ANT2. Recorded HEROES NBC 1080i w/Dolby 5.1 30 minutes from OTA, then 30 minutes from cablecard. When playing back the OTA recording, sound does NOT dropout. Cablecard recording sound played back DOES dropout. Tried again with TONIGHT SHOW, same thing. OTA played back does NOT dropout, cablecard played back DOES dropout.
The sound dropouts do not occur in the same place in the recording as evidenced by rewinding and playing back where it drops the first time.
bwall23 is offline
post #2 of 82 Old 06-09-2007, 12:17 AM
timecop's Avatar
This is definitely a problem with a TV , and not the AVHDD recorder. They're just dumb bit-buckets and do NOT process the digital stream recording in any way whatsoever besides encrypting it + writing to disk.
Keep bothering Mitsubishi about it.
timecop is offline
post #3 of 82 Old 06-09-2007, 06:35 PM - Thread Starter
bwall23's Avatar
I agree on principal that it should be a bit for bit copy of the stream, but if you look at the unit specs it states it handles PID filtering and time-stamping, so it does actually manipulate the stream.
PID filtering for demultiplexing transport streams
Time-stamping of recorded content Allows for demultiplexing of multi-program cable and satellite transport streams.
I would love to hear from someone else using this recorder, or an RCA DVR2080 (not an older OEM version) that can verify they don't have the issue I'm seeing.
bwall23 is offline
post #4 of 82 Old 06-09-2007, 06:55 PM
timecop's Avatar
I have both DVR2080 and 2160, but I'm not using it with that particular TV.
I don't have any kind of audio or video dropouts though.
timecop is offline
post #5 of 82 Old 06-09-2007, 07:31 PM - Thread Starter
bwall23's Avatar
Are you attached to an HDTV (if so, which?) or an STB?
Also, I ONLY have the problem with 1080i w/DD 5.1 recorded from cable, not OTA and only see it when playing back.
I also assume you're in Japan which uses different broadcast standards over cable than the U.S does, ISDB-C vs. DVB-C or OpenCable, correct me if Wikipedia is wrong.
Comcast cable in my area uses Motorola DC-II, so I have to assume their head-end equipment is Motorola.
I just want to get this problem resolved, as the whole reason for purchasing this setup was to record & playback HDTV.
bwall23 is offline
post #6 of 82 Old 06-10-2007, 07:47 AM
timecop's Avatar
TV.
I've used the box to record satellite HD and terrestrial HD broadcasts.
You're correct regarding different broadcast system. The audio is also AAC, not AC3. However 5.1ch does playback without a problem. TV is a 2005? I think model Sharp LC5 37" lcd.
Anyway, better if some Mitsubishi WD-57831, WD-65831, WD-73831 owners poke at this thread, it's unlikely my random babbling is going to improve your situation. Maybe if you changed thread topic to mention mitsubishi TV's youd get more people looking at it.
timecop is offline
post #7 of 82 Old 06-10-2007, 09:31 AM
CKNA's Avatar
It is the TV. It makes no difference what standard is used as Transport Stream is very similar on all standards. BTW in US cable tv only uses ATSC OpenCable standard, no DVB-C here. Also DCII on cable is used for encryption and nothing else. I have Mistubishi LCD with firewire and RCA and Toshiba AVHDD. I do not get audio dropouts but I get occasional video glitch. Mitsubishi makes great TV's but they always seem to have problem with QAM recording. Earlier Mitsu TVs would not demux channels from QAM and output the whole stream and people could not record it at all.
CKNA is offline
post #8 of 82 Old 06-10-2007, 12:33 PM - Thread Starter
bwall23's Avatar
CKNA, thanks for the reply. I will continue to followup with Mitsubishi on the issue.
bwall23 is offline
post #9 of 82 Old 06-24-2007, 11:19 PM - Thread Starter
bwall23's Avatar
My set's been in the shop for a week, so the local shop can troubleshoot with Mits help, and they say they'll start looking at it in 2 days... Why did they need it last Saturday?
bwall23 is offline
post #10 of 82 Old 07-02-2007, 11:51 PM - Thread Starter
bwall23's Avatar
Still in shop and no news yet, Hmmmm....
bwall23 is offline
post #11 of 82 Old 07-05-2007, 10:23 PM - Thread Starter
bwall23's Avatar
Heard from shop, then Mits today... local shop got DM module in on Monday and might get a chance to put it in today and see if it fixes it...
bwall23 is offline
post #12 of 82 Old 07-26-2007, 07:13 PM - Thread Starter
bwall23's Avatar
Was in the shop for over a month while they tried 2 new DM modules which made the problem worse, so it's still not fixed. Waaiiting to hear back from Mits 2nd level...
bwall23 is offline
post #13 of 82 Old 08-02-2007, 11:07 PM - Thread Starter
bwall23's Avatar
Called Mits 2nd level support today and my contact was not there. I think they know about this problem and are stalling until my one year warranty runs out or until they've sold all of these sets. Their support is pitiful. They don't return calls and when you email Consumer relations you get an automated reply stating someone will contact you within 2 business days. It's never happened.
Anyone have a recommendation on a new 1080p set that actually records/plays over firewire without problems?
bwall23 is offline
post #14 of 82 Old 08-28-2007, 06:46 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
Surely not the Samsung DLP's!
You can only record the first sub channel.
The set is in a full 'on' state including the lamp.
bwall23; you have a PM.
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #15 of 82 Old 08-30-2007, 02:09 PM
UMD_Terp's Avatar
as far as I know, the only new sets that will have firewire are the new Mitsubishi Diamond DLPs... good luck getting Mitsubishi to fix anything. If it is broken, they won't fix it... period.
I'd get an HD-DVR with firewire and call it a day. I gave up a while ago on getting my Mitsubishi TV to properly do anything over firewire.
UMD_Terp is offline
post #16 of 82 Old 09-01-2007, 10:55 AM - Thread Starter
bwall23's Avatar
The problem I have is when using any 3 of my HD-DVR's with firewire.
bwall23 is offline
post #17 of 82 Old 09-01-2007, 03:57 PM
UMD_Terp's Avatar
So you cannot dump from the DVR straight to the AV disk? That should work. Makre sure you take the TV out of the chain though. It may not work at all if you still have the TV somewhere in the 1394 chain. Connect the AV disk directly to the DVR and then try.
UMD_Terp is offline
post #18 of 82 Old 09-02-2007, 03:06 PM - Thread Starter
bwall23's Avatar
I can't take the TV out of the firewire chain since it's the only controller/hub. I only have the following in the firewire chain;
FirewireHDDVR(AVDISC)<---TV--->FirewireHDDVR(AVDISC1)
You must not have read my first post here because it sounds like you're thinking I have a cable STB. I don't.
What firewire devices do you have and how can you dump direct from an STB to an AVDISC with nothing to control them???
bwall23 is offline
post #19 of 82 Old 09-02-2007, 09:50 PM
UMD_Terp's Avatar
sorry, I didn't see that the TV tuner was your only source.
UMD_Terp is offline
post #20 of 82 Old 10-14-2007, 01:13 PM - Thread Starter
bwall23's Avatar
Mits 2nd level called me August 20th stating my firewire HD-DVR's (same Indigita brand Mits uses for demos) must be incompatible with the TV. I asked which ones are compatible. They said their "expert" is on vacation and would get back to me on that.
It's been 2 months and I haven't heard from them.
I returned my newest (Indigita AVHD-500) unit to Indigita to get a broken LED fixed and they loaded the latest (9/28/07) firmware on it. I still have the same audio dropout issue.
Is it the Mitsubishi WD-57831, the Indigita AVHD-500 or Comcast cable???
bwall23 is offline
post #21 of 82 Old 10-15-2007, 06:58 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
I sold my Samsung 5088 and picked up a 57732. I briefly tried one, then both of my AVHDDs' (RCA 2150) and the set reconized both and both appeared to record a test progran. I just watched a minute of each just to confirm they worked. Didn't listen to them as I forgot about your issue. I do have a program setup for tonight and will evaluate that.
Off subject, I hate to admit it but the Mits doesn't hold a candle to the Sammy PQ wise. What Home Theater magazine said about the Mits I will have to agree with (at least PQ wise). It faired the 2nd lowest just ahead of a Olevia 565H. Too bad they don't test the user interface or the most basic feature of any TV, the tuner.
http://hometheatermag.printthis.clic...partnerID=3830
post #22 of 82 Old 10-15-2007, 11:13 PM - Thread Starter
bwall23's Avatar
Look forward to hearing the results of your test recording.
Why did you dump the Sammy?
They reviewed a Mits 731. I had one and sent it back. I think the 732's and 831's are definitely much better than the 731. I did notice poor black levels on the 731, my 831 doesn't have that problem.
bwall23 is offline
post #23 of 82 Old 10-16-2007, 11:26 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
Mostly useless function of the 1394/TVGOS feature.
Between the set turning the lamp on while doing a AVHDD record (when no one is watching or at home),
not being able to record any sub channel above '.1' (can record 1.1, but can't record 1.2 for example),
thevideo menu buried seven button pushes deep,
the service menu erasing all the user settings and
a flimsy plastic case that 'creaks' when it get warm.
The 731 didn't have the iris. The 732 & the 832 does along with a half a dozen other features most sets don't have.
post #24 of 82 Old 10-19-2007, 10:58 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
I recorded a few programs off cable and OTA and after watching just parts of all of them, I had no audio breakup.
Actually, considering everything, the procress went fairly well. Other than the fact it is all too easy to delete a program you already watched, since there isn't a 'are you sure' confirmation screen.
post #25 of 82 Old 10-19-2007, 11:12 PM - Thread Starter
bwall23's Avatar
You also have Comcast cable? I only get the audio dropouts with the Mits Digital Coax out attached to my A/V surround system when playing back a 1080i recording in DD 5.1 that was recorded from Comcast cable. All OTA recordings, all cable 720p recordings and all cable recordings with DD 2 don't have a problem.
bwall23 is offline
post #26 of 82 Old 10-20-2007, 04:12 AM
timecop's Avatar
You have a 500gig indigita disk image?
timecop is offline
post #27 of 82 Old 10-20-2007, 06:18 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
This is on TW. That seems to be a somewhat limited situation.
How about that same audio off the TV directly (internal speakers)?
post #28 of 82 Old 10-20-2007, 07:04 PM - Thread Starter
bwall23's Avatar
Oh yah. It's on my USB thumb drive
bwall23 is offline
post #29 of 82 Old 10-20-2007, 07:14 PM - Thread Starter
bwall23's Avatar
My original post at the beginning of this thread: http://www.avsforum.com/avs-vb/showt...8#post10744858
5.1 audio problem
bwall23 is offline
post #30 of 82 Old 10-21-2007, 07:57 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
Too much info to remember it all.
Ok, how about trying another receiver?
Reply HDTV Recorders
