Official AVS TiVo HD Topic! - Page 151 - AVS Forum | Home Theater Discussions And Reviews
Old 06-01-2011, 06:52 PM
Kelson's Avatar
Quoted: 1952 Post(s)
Liked: 1147
Originally Posted by Jim Miller View Post
I'm using TiVo Desktop with an HDXL to transfer via the original wireless dongle to a very fast HTPC. It's pretty painfully slow.
Using kmttg I get a max sustained transfer rate of 14-15 Mbps (TiVo HD). There is a trick to use to get max speed. Set both tuners of the TiVo to dead-air channels. The TiVo won't record dead-air channels which frees up the processor for the transfer. A TiVo network transfer is not just a simple bit-blitz. The recording is stored on the HDD as separate A & V transport streams; the processor has to mux them together into an MPEG-2 file on the fly before sending it out over the wire, so the transfer is bound by the processor. The Premier uses a higher power chip; the transfer rate is much faster.
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
Old 06-01-2011, 07:50 PM
Jim Miller's Avatar
Kelson thanks for the info.
Unfortunately the TiVo is barely alive and won't put up a picture. It still responds to TiVo desktop requests to my surprise. So I can't mess with the tuners. Once the last transfer is complete it goes to the big RMA in the sky.
Jim
Jim Miller is offline
Old 06-02-2011, 06:01 AM
jjeff's Avatar
Quoted: 692 Post(s)
Liked: 246
In that case I'd try pulling the RF cable from the Tivo. Without a RF source it should have no channels and would act like it's tuned to dead air??? worth a try.
jjeff is offline
Old 06-02-2011, 07:17 AM
Hyrax's Avatar
Quoted: 91 Post(s)
Liked: 46
jim
As commented, transfers on the TivoHD are slow even when wired Ethernet is used. One (and perhaps the only) way to improve speed is to set both channels to a station where there is no signal. That way you should be able to transfer in under 2x.
Hyrax is offline
Old 06-02-2011, 07:21 AM
Paul_S's Avatar
kmttg has a config option called "autoTune" which uses the telnet connection to tune both tuners to unused channels to speed up transfers. The speed up comes from the fact that the TiVo doesn't have to write the LiveTV buffer on the disk when the tuner is parked on an invalid channel. The reduction in load on the CPU and disk from not having to write the LiveTV buffer speeds everything else up.
I use two unused channels on my system (ch 888 and 889) in my kmttg config for this purpose.
Other than that, you're not gonna get much faster transfer speeds out of your TiVoHD unit, as it has the slowest network performance of the HD, Series3, and Premiere units. I routinely see transfer speeds of 45Mbps from my Premiere.
Paul_S is offline
Old 06-14-2011, 12:49 PM
mborland's Avatar
Nobody ranting yet on the Premiere Q.....
mborland is offline
Old 06-14-2011, 04:46 PM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
Only 'ranting' will be when it becomes available and at what price and to what parts of the country - AND if TiVo makes it actually economical to upgrade existing boxes.
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
Old 06-14-2011, 05:08 PM
Jim Miller's Avatar
So far TiVo has said availability will be through service providers only, e.g. Comcast, et. al.
Jim
Old 06-25-2011, 06:43 PM
JackLA's Avatar
I own a Tivo Series 3. I recently installed a Western Digital My DVR Expander. When I check the available desk space using kmttg, kmttg does not see the external hard drive. Is this normal or should kmttg be able to also see the My DVR Expander? Also, the My DVR Expander is noisy. Is this normal?
JackLA is offline
Old 06-26-2011, 07:51 AM
gwsat's Avatar
Quoted: 2190 Post(s)
Liked: 2426
I have had a 1TB WD My DVR Expander connected to my S3 for four months and it has worked as advertised and has been as silent as a stone. I suspect, therefore, that your noisy one is not operating normally. I don't use kmttg so can't address that part of your question.
HT setup: Sony 75XBR X940D UHD HDR TV; Kaleidescape Strato Movie Server 6 TB; Yamaha RX-A3060 AV receiver; Crestron Control System; Hsu VTF-3 MK3 Turbo subwoofer, 6 Hsu HB-1 Bookshelf speakers, 1 Hsu HC-1 Center speaker, 4 Focal ICW8 in-ceiling Atmos speakers; Oppo UDP-203 4K HDR BD player; Mac Mini HTPC. TiVO Bolt 1TB DVR; TiVo Premiere Elite 2 TB DVR
gwsat is online now
Old 06-26-2011, 01:01 PM
spocko's Avatar
Kmttg doesn't know the storage capacity of your Tivo. It it adds up the total size of the recordings on the Tivo, and if that size exceeds the current disk capacity setting, then it increases the disk capacity to that value. So if you let your Tivo fill up, then kmttg be able to provide an accurate storage capacity number.
You can also manually enter a number if you don't want to wait for your Tivo to fill up. 90% of your total disk capacity should be a reasonable starting point. If/when your Tivo fills up, then kmttg will be able to update it to the actual storage capacity, which is probably a little more than 90%.
The reason the storage capacity is less than the total disk capacity is because the Tivo needs to reserve some space for the operating system, live TV buffers, etc. Also, kmttg displays disk space in MiB, where hard disk manufacturers rate capacity in MB (http://en.wikipedia.org/wiki/Mebibyte).
spocko is offline
Old 06-26-2011, 02:36 PM
JackLA's Avatar
I have gone into kmttg and manually entered a number equal to 90% of the total combined disk space. The pie chart now looks correct. Thanks for the tip.
JackLA is offline
Old 07-06-2011, 02:22 PM
zebrafetish2000's Avatar
Hi all! I am absolutely brand new to Tivo. So new, that I don't own one yet. I currently own an OTA HD DVR (not well known) called a DTV Pal. It works ok, but only gets about 24 hours of guide info and it's hard to find what you want.
I am seriously considering buying a refurb $79.99 Tivo premiere (from tivo dot com ) and giving it a shot for 12 months. At $20 a month, it's a lot more than I am paying.... which is nothing.
Do many of you use Tivo with OTA signals? Do you see any advantages? Disadvantages?
ALSO, and very importantly, I have a media room with an extensive setup of 5.1 Channel speakers, Denon receiver, large 1080 P projector, etc.
How is the quality of the video and audio using a Tivo premiere?
Thanks!!!
zebrafetish2000 is offline
Old 07-06-2011, 02:27 PM
StuJac's Avatar
Thanks!!!
No advantage or disadvantage with ota vs cable or fios providing you have a strong signal. Anything less gives a less than desirable effect.
TiVo will output to your system very well; it has in my system for about 11 years. I would consider investing in a lifetime sub if you can do it.
Pan 46PZ85U, Marantz SR5003, TiVo Premier, TiVoHd + 1tb, A2 (fs), PS3, Pan DMR E-95 (fs), JVC DVD-A, Polk & Infinity, Harmony One
StuJac is offline
Old 07-06-2011, 02:41 PM
jjeff's Avatar
Quoted: 692 Post(s)
Liked: 246
I'm OTA only along with dial-up guide and I couldn't be happier. I have the older Tivo HD which I added lifetime from day one. The ~$550 total was kind of hard to swallow but I have no regrets whatsoever! The Tivo guide along with Season Passes and wishlist recording are great.
jjeff is offline
Old 07-06-2011, 05:23 PM
a68oliver's Avatar
Since the Premiere records the signal digitally, it is an exact copy of the broadcast signal. This results in no degradation. Assuming you have an adequate signal, you should see no difference between live broadcast and Tivo recordings.
Alan Oliver
Tivo user since May 2000
a68oliver is offline
Old 07-07-2011, 12:12 PM
snowghost's Avatar
Quoted: 20 Post(s)
Thanks!!!
I'm so happy with OTA that I canceled cable. It has been a hobby of mine to record OTA broadcasts of Late Night Musical Guests in 1080i 5.1 surround on my TiVo and either burn them to DVD or convert them for Apple TV. I've got over 60 hours of HD live performances from some great bands.
TiVo OTA has been a great value for the money.
"The best long distance runners eat raw meat, run naked and sleep in the snow."
snowghost is offline
Old 07-26-2011, 08:23 AM
Thanks all for the TiVo buying advice. My refurbished premiere box should be here on Thursday. I found the www.musicobsessed.com website helpful for the late night tv musical guests lineup mentioned earlier. Thanks again!
Old 08-11-2011, 02:19 PM
DigitalAV's Avatar
Quoted: 68 Post(s)
Liked: 30
Hello there!
I want to set up a streaming (and/or push-pull) server for my parents, who have two TivoHDs (one TivoHD and one Series3), so I plan on using StreamBaby and/or pyTivo. The media will be standard-def DivX and high-def MKVs (720p & 1080p).
What kind of system would I need to build that's beefy enough for on-the-fly encoding/streaming of the above?
TIA!
DigitalAV is offline
Old 08-11-2011, 05:21 PM
valley_nomad's Avatar
I just download the Tivo app (v1.5(3148)) into my new iPad2. But the app couldn't detect my Tivo HD on the network. Did any one experience the same problem and know the way to make it work?
valley_nomad is offline
Old 08-11-2011, 06:50 PM
L David Matheny's Avatar
Quoted: 17 Post(s)
Liked: 31
I've never used an iPad, but I think there's a TiVo setting somewhere that needs to be changed. It might be under Settings / Remote, CableCARD, & Devices / Network Remote Control.
L David Matheny is offline
Old 08-11-2011, 07:48 PM
DigitalAV's Avatar
Quoted: 68 Post(s)
Liked: 30
Originally Posted by DigitalAV View Post
Hello there!
TIA!
Here's what I've put together at newegg:
AMD Athlon II X2 250 Regor 3GHz Dual-Core CPU
MicroATX mobo w/ Radeon HD 4200 IGP
4GB DDR3 1333
Good enough?
Old 08-12-2011, 05:27 AM
Liked: 651
You don't need much, that's plenty powerful. I run streambaby and pyTivo on an old Athlon X2 4400 with a couple GB RAM and Win7 and it works fine, never have issues, don't even think it takes more than 20% CPU when running ffmpeg. How are your parents going to put the files on the server for streaming?
slowbiscuit is offline
Old 08-12-2011, 07:03 AM
DigitalAV's Avatar
Quoted: 68 Post(s)
Liked: 30
I'm doing it for them and am ripping their DVDs and Blu-rays as we speak. I just wanted to be sure the above system would be good to go for on-the-fly 1080p mkv streaming. I'll most likely do StreamBaby rather than pyTivo, since I've already encoded some mkvs that aren't true 1920x1080 or 1280x720 (removed the black bars for 2.35:1 rips).
Old 08-12-2011, 07:52 AM
Wryker's Avatar
Quoted: 134 Post(s)
Liked: 52
1080 mkv's can stream on a non-gb ethernet connection?
Wryker is offline
Old 08-12-2011, 12:29 PM
Charles R's Avatar
Liked: 540
Sure. Using a Boxee Box I could stream them (without issue) via a Mac Mini USB hard drive.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
Old 08-12-2011, 08:39 PM
ClemsonKev's Avatar
Just got Verizon FIOS last week. I like it so far, but we have the whole house DVR and the two secondary STB's won't SKIP and REPLAY like the main DVR will........ any suggestions?
thanks!!!
Kevin
ClemsonKev is offline
Old 08-13-2011, 04:44 AM
StuJac's Avatar
Are these Verizon dvr's? If so, you are in the wrong group and most in his group don't care about this issue.
StuJac is offline
Old 08-24-2011, 01:30 PM
Hi all, thank you again for the TiVo buying advice. I do like my Premiere. 6 months of Hulu Plus came free with the new box. I must admit, that it's pretty sucky. The picture quality is fine, and the nuts and bolts/ UI is okay, but the content selection is absolutely crappy.
Does anyone use Hulu Plus on their TiVo box? I know that Hulu dot com has much more additional content, but they cannot stream it through devices that connect directly to TVs like TiVo boxes. Does anyone have a way around this that they have actually set up effectively? I am somewhat familiar with Playon, but it is worth the $80 and wear and tear on my PC to have this complicated network of devices running all the time? I also have an XBOX360, but again, this is aging and I'm worried about using it exclusively for watching Hulu or Playon.
Any suggestions would be great!
Ps. I just dropped Netflix, I'm disgusted that they think they can raise their prices 39% and expect no one to bat an eye.
Old 08-25-2011, 11:07 AM
gwsat's Avatar
Liked: 2426
An HTPC is all I can think of that would work. That way, you feed a computer's video directly to your HD display. I use a Mac Mini connected via HDMI to my HD display and it has been outstanding for the purpose. Nevertheless, I have never felt the need to subscribe to Hulu Plus.
I dropped Netflix even before the price increase because of the company's policy of passing over newly released BDs of either catalog titles of movies or TV series. I then resubscribed to Blockbuster, which has been doing an excellent job since Dish bought BB's assets. By the way, BB does buy a very high percentage of newly released BD editions of classic films and TV shows.
gwsat is online now
