Official AVS TiVo HD Topic! - Page 161 - AVS | Home Theater Discussions And Reviews
post #4801 of 4825 Old 09-08-2013, 06:43 PM
a68oliver's Avatar
You should be able to tell if your neighbor has a subbed or unsubbedd box by going to Messages and Settings and looking at Account and System Information - System Information screen. Account status will indicate if she has lifetime service or not. Perhaps she doesn't remember the purchase details.
I do not have Verizon, but I think the Tivo will still need a cablecard so that it can map the channels correctly. Otherwise, it won't know where to tune for channel 504, etc.
Surely someone here with Verizon understands this better than I and can chime in.
Alan Oliver
Tivo user since May 2000
a68oliver is offline
post #4802 of 4825 Old 09-11-2013, 01:58 PM
Charles O's Avatar
Quoted: 44 Post(s)
Liked: 42
I don't have Verizon either, but with a cable card the channels will map to what the lineup from Verizon is...at least it works that way with Cox which is what I have.
Charles O is offline
post #4803 of 4825 Old 09-12-2013, 04:21 AM
JohnMc's Avatar
Works that way on FIOS too.
JohnMc is offline
post #4804 of 4825 Old 02-03-2014, 12:16 PM
bahist17's Avatar
After many years of faithful service - my TivoHD is rebooting itself a few times a day.
I hope I can salvage it.
bahist17 is offline
post #4805 of 4825 Old 02-03-2014, 12:56 PM
Kelson's Avatar
Quoted: 671 Post(s)
Liked: 516
There's only two things that usually go wrong with these. The HDD or, less frequently, the power supply. If I were you I would try replacing the HDD with a 1TB AV drive.
On the other hand, are you sure you are not having power glitches?
- kelson h
The bitterness of poor quality lasts long after the sweetness of the low price is forgotten . . . life is too short to drink bad wine
Kelson is offline
post #4806 of 4825 Old 02-03-2014, 02:11 PM
Hyrax's Avatar
Quoted: 16 Post(s)
Updating the drive is an excellent idea, and not all that difficult. If you don't want to work on it yourself, I think weakness can check the TivoHD out and repair it for you, and update the HDD. I've never had them do anything for me, but I've heard they're good at this sort of thing.
Hyrax is offline
post #4807 of 4825 Old 02-04-2014, 09:05 AM
Liked: 281
The HDs have known power supply issues because of bad caps, would be worthwhile to open it up and see if any of them are bulging.
slowbiscuit is offline
post #4808 of 4825 Old 02-04-2014, 10:11 AM
Kelson's Avatar
Quoted: 671 Post(s)
Liked: 516
Really? I've honestly never heard of that, do you have a reference? My HD has been chugging along for 5 yr with the original drive.
- kelson h
Kelson is offline
post #4809 of 4825 Old 02-04-2014, 10:29 AM
scsiraid's Avatar
Check out the TiVo community forum. Lots of examples of TiVo's with failing caps. My S3 (original OLED) had the problem... several caps had swollen and began to leak electrolyte. Symptom was rebooting and failure to complete boot process. Changed out the swollen caps and all was fine. Got mine from MCM Electronics.
scsiraid is offline
post #4810 of 4825 Old 02-04-2014, 01:14 PM
Kelson's Avatar
Quoted: 671 Post(s)
Liked: 516
^^ thanks. I got my HD in 2009. I thought all the bad chinese electrolytic caps had been flushed out of the supply chain by then.
- kelson h
Kelson is offline
post #4811 of 4825 Old 02-05-2014, 11:30 PM
spocko's Avatar
Unfortunately not. I also got my Tivo HD in 2009, and after less than 3 years in service, I discovered that it had bulging/leaking caps in the power supply.
spocko is offline
post #4812 of 4825 Old 02-06-2014, 06:22 AM
Hyrax's Avatar
Quoted: 16 Post(s)
Before you think about changing the HDD in your failing TivoHD, you should be able to get Tivo to exchange it for a premiere. It will cost you something in the range of $150 or so, but they will transfer your lifetime subscription. I was going to do that last October, until they noticed that I'd put in a bigger hard drive.
Hyrax is offline
post #4813 of 4825 Old 02-06-2014, 07:46 AM
jjeff's Avatar
Quoted: 196 Post(s)
Liked: 107
Before calling them could you just put the stock drive back in? I upsized my HDD to 1TB almost day one but kept the old drive, wonder if I just put it back in before requesting a exchange how that would go?... Note my HD is still going strong with no outward signs of bad caps but because of it's location I won't be removing it unless it quits.
jjeff is offline
post #4814 of 4825 Old 02-06-2014, 07:51 AM
Hyrax's Avatar
Quoted: 16 Post(s)
They know if you ever changed the drive. I had a 1 TB drive in my TivoHD for 5 years, then it died, so I put the original drive back in. I'd had the original drive in for 6 months before I called them and they still knew.
Edit: My TivoHD was dying so I asked them what to do. Tivo tech support actually suggested calling weaknees to get it repaired.
jjeff likes this.
Hyrax is offline
post #4815 of 4825 Old 02-10-2014, 11:39 AM
AVS Club Gold
wilsonsoohoo's Avatar
Hyrax,
Is this some kind of promotion I should refer to if I talk to them? I had considered replacing my HD with a Premiere, but was put off by having to buy another Lifetime service.
wilsonsoohoo is offline
post #4816 of 4825 Old 02-10-2014, 12:09 PM
Hyrax's Avatar
Quoted: 16 Post(s)
I simply called their sales people and asked them what I should do with a TivoHD that had died. They said that if their Tech Support people thought the problem was a hardware failure they could do an exchange. They were the ones who made the suggestion for the exchange. It was when I talked to tech support that I ran into the 'you put your own hard drive in the unit' roadblock. If I'd never done that I would have gotten a 2 tuner, 500 GB, Premiere. I've no idea if they still have any 2-tuner models available for this. The 4-tuner Premiere models all require cable.
Hyrax is offline
post #4817 of 4825 Old 02-10-2014, 12:38 PM
Wryker's Avatar
Quoted: 41 Post(s)
Liked: 33
Originally Posted by wilsonsoohoo View Post
Hyrax,
If you're going to get a new one get the Roamio - for the few $ more it's worth it from the reviews on the Premier boxes.
"..where you will never find a more wretched hive of scum and villainy."
Wryker is offline
post #4818 of 4825 Old 02-10-2014, 02:17 PM
AVS Club Gold
Thanks for the information, Hyrax and Wryker.
post #4819 of 4825 Old 02-26-2014, 10:11 PM
bahist17's Avatar
Thanks for the tips Hyrax, Kelson, and everyone else.
Guess I will open it up and take a look at the power supply.
I have never upgraded anything inside - only added a My DVR Expander via eSata a few years ago.
bahist17 is offline
post #4820 of 4825 Old 02-28-2014, 02:19 AM
AVS Club Gold
When I opened up my S3, one of the big capacitors (701?) was bulging badly. It was easy to replace, though.
post #4821 of 4825 Old 11-11-2014, 07:21 PM
Edllguy's Avatar
Quoted: 45 Post(s)
Triple post, sorry pressed to many times
Edllguy is online now
post #4822 of 4825 Old 11-11-2014, 07:21 PM
Edllguy's Avatar
Quoted: 45 Post(s)
Double post, sorry
post #4823 of 4825 Old 11-11-2014, 07:24 PM
Edllguy's Avatar
Quoted: 45 Post(s)
Is there any tivo deals thread around here? Like Black Friday deals?
post #4824 of 4825 Old 11-12-2014, 05:24 AM
Liked: 281
post #4825 of 4825 Unread Today, 06:28 PM
JoeM's Avatar
Bear with me as I'm new to this and I haven't read thru the previous 160 pages. I've obtained two TivoHDs. On one the subscription ran out. On the other one the power supply/motherboard was bad. So I took it's hard drive and put it on the Tivo that had the subscription run out and Sys info says it has Lifetime subscription. Is this legit ? Will this pass Guided Setup as I want to use a working Tivo for OTA without monthly dues.
JoeM is online now
Reply HDTV Recorders
