W-VHS video cassettes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-30-2001, 07:47 AM - Thread Starter
wcp45's Avatar
Does anyone know where I can purchase JVC W-VHS videocasettes? The company from whom I purchased my JVC recorder tells me they no longer have access to the tapes, and that JVC does not sell them directly to consumers. I hope they are wrong on the latter account, or that someone knows of a different source.
wcp45 is offline
post #2 of 6 Old 10-30-2001, 11:30 AM
Glimmie's Avatar
Quoted: 760 Post(s)
Liked: 625
Well, JVC probably doesn't sell anything directly to consumers. They use dealers. And since you live in LA, finding these tapes should be easy. There are many professional video supply houses in this market to feed the studio business.
Try Video Tape Porducts in Glendale (818). They are a large tape supplier. Check the Hollywood yellow pages too. Some of these little companies even offer 24/7 service but you pay!
Also try www.tapewarehouse.com. They seem to have everything at the best prices.
Glimmie is offline
post #3 of 6 Old 10-30-2001, 11:52 AM - Thread Starter
wcp45's Avatar
Glimmie, thanks for the leads. My dealer wasn't able to help at all.
wcp45 is offline
post #4 of 6 Old 11-01-2001, 03:11 AM
rudolpht's Avatar
wcp45,
I use TapeResources, www.taperesources.com
Good prices on Digital S tapes, cheaper & better qual than W-VHS yet compatible.
The 64 tape is just under 2 hours & 104 tape is just under 3 hours in WVHS machines. Unfortunately "just under" is not geood enough for things like Band of Brothers that generally go OVER the hour mark.
Also got the head cleaner which was highly recommended (but have not used yet).
DS64-F FUJI D421 DS-64 DIGITAL-S
DS104-F FUJI D421 DS-104 DIGITAL-S
DSCLN-J JVC DCL5AU DIGITAL-S CLEANER
Tim
Tim
Selling Anthem PVA7.
STABILITY + Superior audio (SC09-TX) + Incredible picture (VPL-VW200) + good integration.
rudolpht is offline
post #5 of 6 Old 11-01-2001, 09:16 AM - Thread Starter
wcp45's Avatar
RudolphT,
The prices on the tape-resources cite are much cheaper than the W-VHS quotes I have been getting. Thanks for the tip. I have never used a Digital-S tape. Is the quality actually better than W-VHS? Is there any quality difference between the Fuji and JVC tapes? I have a JVC machine, so I would probably lean toward the JVC tape if prices were equal, but the Fuji tapes cost substantially less.
wcp45 is offline
post #6 of 6 Old 11-02-2001, 02:37 AM
rudolpht's Avatar
I would do a comnparison on the same content, but I think you'll find the Fuji tapes above equal or better the JVC tapes. Given cost, and Don Landis has made this point before, WVHS copying gets expensive. These quality tapes take a little bite out of the expense.
Tim
Tim
rudolpht is offline
Closed Thread HDTV Recorders
