Motorola 34xx &64xx DVR "Official Thread" - Page 25 - AVS Forum | Home Theater Discussions And Reviews
post #721 of 2061 Old 04-23-2008, 11:43 AM - Thread Starter
CharterJames's Avatar
Originally Posted by QZ1 View Post
Not ironic at all, because the Boxes MSOs are using are two-way, while TV manufacturers still only have a one-way standard to use. Once there is a two-way standard in place, several, if not all, TV manufacturers will implement it. Several have already committed to implementing tru2way through CC in TVs.
My understanding is they already had 2 way standards in the cablelab specs
Views & opinions stated here are strictly those of Me and not Charter Communications.
I no longer work in Tech Ops as such I can only advise & suggest.
CharterJames is offline
post #722 of 2061 Old 04-23-2008, 12:47 PM
RockyMountainD's Avatar
Couple of interesting reads (from last summer):
CableCARD 2.0: What's the hold up?
CableCARD 2.0 is ready
RockyMountainD is offline
post #723 of 2061 Old 04-23-2008, 01:00 PM - Thread Starter
post #724 of 2061 Old 04-23-2008, 02:40 PM
DCT6416UIIIuser's Avatar
Nice answers guys, thanks. I will basically tell my son to not focus on cable card ready TV
DCT6416UIIIuser is offline
post #725 of 2061 Old 04-25-2008, 09:13 AM
QZ1
QZ1's Avatar
Well, even if so, they haven't been able to implement it as of yet.
QZ1 is offline
post #726 of 2061 Old 04-26-2008, 07:15 PM
bm196's Avatar
Given a choice, better sound by hooking digital optical from Moto 6416 to surround sound system, or use digital optical from TV set to surround sound system?
bm196 is offline
post #727 of 2061 Old 04-26-2008, 09:05 PM
maggiefan's Avatar
Connect your Motorola box directly to your surround receiver, not the TV. Most if not all TV's don't output the surround signal from the inputs, only from their own tuner. If you use the optical output of the TV, you'll only get stereo.
Larry
maggiefan is offline
post #728 of 2061 Old 04-29-2008, 01:48 PM
KoRn's Avatar
Motorola DCH-6416 with Charter cable. Did we just receive a slight update or some thing with the box? I noticed when changing the channels. Certain channels shows a ondemand option. You click it and it takes you to ondemand and the network that the tv show is on.
KoRn is offline
post #729 of 2061 Old 04-30-2008, 05:51 AM - Thread Starter
That's a new VOD option - it allows customers to directly tune to a channel's associate VOD sub category - for Example if you're on Comedy Central it will jump directly to the Comedy Central selection.
My market was a beta test for that - the only downside is you've got to be carefull when you hit info that you don't hit the left or right arrow and accidently hit the OnDemand option
post #730 of 2061 Old 04-30-2008, 02:48 PM
jonwww's Avatar
It's funny how different features hit different cable co's at different times (or even within the same company). We at Comcast have had this VOD access from the channel for a few years now.
Just my 2¢
Jon
jonwww is offline
post #731 of 2061 Old 04-30-2008, 07:12 PM
themant's Avatar
Quick question - I have RCN cable and am using the Motorola 6416 III running the Passport Echo. If I hit menu twice it brings up the settings page. One of the settings is video. I get the main options - 1080i, 720p, etc. But for each of the main options there are sub options. For example, 1080i can be:
1080i Sidebar 4:3 Pic
1080i Stretch 4:3 Pic
1080i Preserve 4:3 Pic 480p
1080i Preserve 4:3 Pic 480i
Can anyone tell me what the differences are between these modes?
themant is offline
post #732 of 2061 Old 04-30-2008, 10:10 PM
dattier's Avatar
Quoted: 110 Post(s)
Liked: 51
It seems fairly logical: if you have the main video output setting on 1080i but you're trying to display a 4:3 broadcast, how would you like the box to handle it?
1. Pillarbox it (add vertical bars on the sides to fill a 16:9 screen) and upconvert the result to 1080i?
2. Stretch it horizontally to fill a 16:9 screen and upconvert the result to 1080i?
3. Pillarbox it and deinterlace it to 480p?
4. Pillarbox it and display it in 480i?
Those are just guesses, but that's how I'd read the selections.
dattier is offline
post #733 of 2061 Old 05-01-2008, 05:30 AM
themant's Avatar
Makes sense to me, but I wish there was some explanation in the manual or the RCN tech support reps had a clue.
So, if you had a 1080p set, which option would you choose?
Same question if you had a 720p set (obviously start with 720p instead of 1080i, but what about the rest - there are 4 options for 720p as well.)?
I don't like stretch so that's out. I'm guessing for best quality don't choose the last 2 options either. Why would someone choose either of those options?
themant is offline
post #734 of 2061 Old 05-01-2008, 08:05 AM
dattier's Avatar
Quoted: 110 Post(s)
Liked: 51
I'd choose #1 myself.
Why would someone choose either of those [last two] options?
Perhaps such a person is watching on a 480i or 480p television and the box does a better job of downconverting than the TV does.
dattier is offline
post #735 of 2061 Old 05-01-2008, 09:05 AM
#1 or #4.
#1 uses the STB to convert; #4 lets your TV do the conversion. Try them both on an SD channel and see what looks best to you.
post #736 of 2061 Old 05-01-2008, 05:20 PM
snotbottom's Avatar
I haven't finished reading ahead to see if this has already been answered... but I had this problem too with our QIP6416. Adjusting the "screen position" in the TVG menu fixed it. Not sure why, but it did.
If you're seeing only the corner of the picture instead of the compressed picture the first thing I'm thinking of is something wonky in the box - if a powercycle doesn't fix the problem you can try something more drastic, however I don't like to give that technique in the open as it can be abused to get around PIN codes etc.
PM me for that trick (given our earlier converstations it wouldn't suprise me if you've already power cycled it) - I'm thinking either something went bad in the firmware or there's some sort of hardware problem preventing the compressed picture.
snotbottom is offline
post #737 of 2061 Old 05-01-2008, 08:26 PM
dvdmth's Avatar
That is the correct solution. The "only seeing the corner of the screen" bug occurs when the menu screen's position is too far to the right, giving the box too little real estate in the corner to do its video shrinkage magic. To fix, go to screen position setup and nudge the position to the left a couple of pixels or so.
User error. Replace user.
dvdmth is offline
post #738 of 2061 Old 05-02-2008, 09:04 AM
cypherstream's Avatar
Is there a "Native" resolution selection in Passport DCT? I know there is in Passport for the Scientific Atlanta / Pace boxes. RCN should of pushed Passport DCT 3.0 out now.
cypherstream is offline
post #739 of 2061 Old 05-02-2008, 12:29 PM
themant's Avatar
No "Native" resolution unless I'm missing something just the options I listed.
RockyMountainD - by 4 I guess you mean the one that has 480i in it. Why choose that instead of the 480p?
themant is offline
post #740 of 2061 Old 05-02-2008, 12:30 PM
bicker1's Avatar
If I remember correctly, there was some difference between the two, having to do with closed captioning, maybe???
bicker1 is offline
post #741 of 2061 Old 05-02-2008, 06:43 PM
Keeps the signal "native" to your set. To me, the STB doesn't do a very good job with the de-interlacing.
post #742 of 2061 Old 05-03-2008, 02:28 PM
motoman's Avatar
My Moxi box just fried today and TWC doesn't have any replacements. I got the DCH3416 box and hooked it up a little while ago. One quick question is can you change the display to show the time and not the channel number? That's all I've run accross for now. All the guide info is loading now so I'll get some seroius watching tonight.
Looking forward to a larger HD and HDMI so I'll see how it all works out. Don't have much choice right now
Jim
motoman is offline
post #743 of 2061 Old 05-03-2008, 02:47 PM
I can on my DCT 6416 and have read the features are the same. It is in the set up menu.
post #744 of 2061 Old 05-03-2008, 03:08 PM
motoman's Avatar
I'll check it out tonight. I kept trying to get into the setup menu but nothing would happen when I tried it.
Jim
motoman is offline
post #745 of 2061 Old 05-03-2008, 06:46 PM
dattier's Avatar
Quoted: 110 Post(s)
Liked: 51
Yes.
Press Menu twice on the remote to get to the box's Main Menu; then select Setup and Cable Box and Front LED Display.  (Names are from memory, as the box is on another story of the house, and while I just went there to check, I may be remembering things wrong after having come back to the computer.)
dattier is offline
post #746 of 2061 Old 05-03-2008, 10:37 PM
motoman's Avatar
Got it. Thanks for the help. I thought the settings button on the remote would get me there but I finally figured it out. I had the Moxi box for so long I forgot how some of the menu systems worked on this type of box.
Thanks again.
Jim
motoman is offline
post #747 of 2061 Old 05-04-2008, 05:15 PM
Thanks again.
Jim
Sorry, I forgot about the double click on the menu button. That is kind of a bad way to get there, but so be it.
post #748 of 2061 Old 05-04-2008, 05:23 PM
I have the DCT6416 III set up to "not display adult titles" That works fine. If one click on anything "adult" that is all that is displayed.
However, if I go to ON DEMAND, and they click on any of the available sources, not only are the titles displayed, but the program description does not leave much to the imagination.
Personally, this is not a problem, but when the grandkids visit and want to play the TV it is a problem. Am I not encoding something properly to prevent this, or is the setup to not show titles basically a waste of effort?
post #749 of 2061 Old 05-04-2008, 07:37 PM
dattier's Avatar
Quoted: 110 Post(s)
Liked: 51
If you don't like pressing the menu button twice, you can press it once, cursor left or right to select Main Menu from the quick menu bar, and then press OK.  That gets you to the same place as pressing Menu twice.
dattier is offline
post #750 of 2061 Old 05-05-2008, 06:02 PM
Originally Posted by dattier View Post
If you don't like pressing the menu button twice, you can press it once, cursor left or right to select Main Menu from the quick menu bar, and then press OK.* That gets you to the same place as pressing Menu twice.
Oh, yes, I knew there was another way, but calling it the TV guide on the short menu threw me off
Reply HDTV Recorders
