Pace CableCARD HD Boxes (TDC779X, TDC778X and DC757X) - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 1068 Old 01-23-2008, 06:59 PM
Col_Klink's Avatar
Originally Posted by Col_Klink View Post
lindend, I fully understand "Its not a complete test run and should not be considered an endorsement of the product". That being said. Any chance you can tell me what Brand/Model/Size of drive you have installed in that Nexstar 3? I could always make use of it somewhere else if problems develop. Thank you. We could consider it an independent test from Iron Colonel Labs lol.
Got the nexstar 3 Monday, popped a 200 GB seagate in it I had laying around, and have not had a single issue yet. Seems to be working fine, knock on wood.
Col_Klink is offline
post #272 of 1068 Old 01-24-2008, 08:53 AM
aukevin's Avatar
I just received the TDC779X from Mediacom and I cannot get the PIP to work. This box has that capability doesn't it (it's listed on the specs for the box on Pace's website), and there is a PIP On button on the Mediacom remote that came with the cable box. Could the cable company have deactivated the PIP for some reason? Is there some special setting that I might not have set? I didn't see anything about it. When I press the PIP button on the remote, nothing happens.
I have the box connected through component cables to my TV. Is there anything I could try?
Also, is the HDD size on this box 160GB like the Pace 775 model? I didn't see it listed in the specs.
aukevin is offline
post #273 of 1068 Old 01-24-2008, 09:16 AM - Thread Starter
lindend's Avatar
The hardware has PIP capabilities, but TV Guide does not support PIP functionality at the current time.
Yes, its 160GB. The feature set of the 779 is functionally identical to the 775 with the exception of the CableCARD in place of embedded security.
Linden
Pace Americas, Inc. (note the views expressed here are my own and not necessarily those of Pace).
lindend is offline
post #274 of 1068 Old 01-24-2008, 10:27 AM
aukevin's Avatar
Thanks a lot. That sucks about the PIP though. Thanks!
aukevin is offline
post #275 of 1068 Old 01-24-2008, 01:17 PM
aukevin's Avatar
My TV doesn't have a CableCARD slot, so I don't know much about that technology, but I thought the CableCARD's purpose were to replace cable boxes? So what is the CableCARD functionality on a cable box like the 779X? I guess I just don't get what the CableCARDs do then.
aukevin is offline
post #276 of 1068 Old 01-24-2008, 02:02 PM - Thread Starter
lindend's Avatar
No. CableCARDs are a removable conditional access technology. They are supported in a variety of devices including TVs and set top boxes.
They enable you to watch encrypted content (besides other things). In embedded boxes, there is equivalent technology on the system board. This chip is not removable and/or replaceable. The CableCARD is theoretically removable and hot pluggable.
The FCC wanted to foster competition and portability. To the end user, there should be no functional difference between embedded solution and a CableCARD solution.
Linden
lindend is offline
post #277 of 1068 Old 01-25-2008, 02:06 PM
jhaveri's Avatar
Hi:
I have Pace 778X for a couple of weeks. Everything was working fine until two days ago. It stopped displaying guide - saying info not available. This also stopped all DVR functions. I called the tech a couple of time. Power cycling down dows not help. He can not even update the box from his end. They will send tech to my home sometimes next week. Meanwhile, is there anything I can do to get the Guide and the DVR function back.
Thanks for any help in advance.
jhaveri
jhaveri is offline
post #278 of 1068 Old 01-25-2008, 04:10 PM
SCEvan's Avatar
New problems with my replaced box, if some of you remember I had my pace dvr replaced because it was squeaking. But now I am having re-occuring problems with the new one. First problem is sometimes (not always) if I rewind live tv watch a clip, then return the live tv the picture constantly has colored pixels and I have to change the channels to fix it (not very nice when watching sports). Second problem (which is happening right now) is there will suddenly be some sort of frame rate issue, the picture will jitter about every 3 seconds and I have yet to find a fix but it goes away eventually, still a nuisance.
SCEvan is offline
post #279 of 1068 Old 01-25-2008, 11:59 PM
kculp's Avatar
Does anyone have any experience with the Slingbox Pro and the TDC779X ? I've searched the forum at Sling Community and this was the only concentrated thread of PACE users. Sling works fine getting video out to my remote computer stations (I have 3), but can't seem to find the IR codes. Sling setup has a couple PACE DVR models, but none of those work. I am an experienced Sling user, this is just a new setup with this DVR (previously was slinging with a Moto box). Anyway, with the PACE, I've moved the IR transmitter around on the front screen thinking I was missing a "hit" but if someone knows where the lens is that might help (but in general I think there should be another set of codes that need to be transmitted).
kculp is offline
post #280 of 1068 Old 01-26-2008, 02:58 AM
Col_Klink's Avatar
Happened here, the frame rate thing, on the first 778 Armstrong gave me after 1 week. When I tried rebooting it locked up and just kept trying to format the drive. You probably need a new one.
post #281 of 1068 Old 01-27-2008, 05:58 AM - Thread Starter
lindend's Avatar
What firmware release are you on?
Linden
lindend is offline
post #282 of 1068 Old 01-27-2008, 07:29 PM
SCEvan's Avatar
I dont have a clue what firmware im on, could you tell me how to find it? and i figued out a "fix" i have to completely power down the box (unplug from wall) then it will work fine, but then my guide takes forever to retrieve all the data again.
SCEvan is offline
post #283 of 1068 Old 01-28-2008, 05:28 AM
fullwave2's Avatar
I picked up the 778X this weekend to replace my Moto DVR so now I have 2 775's and the new 778X. I seem to be having the same issue that BillKen posted about a while back in post #12 on this thread. It seems that spontaneously I'm losing the premium channels (anything other than basic cable). It's happened twice yesterday after setting up and activating the box. I had to pull the plug on the box as it was frozen on the blank screen with the message that "You are not authorized for this service - Contact your cable provider".
I searched through this thread and didn't see a resolution. Sorry, but didn't write down the SW version. I can get that tonight. I'm on Buckeyecablevision out of Toledo Ohio if that helps. Thanks.
fullwave2 is offline
post #284 of 1068 Old 01-28-2008, 04:21 PM
ScienceMan's Avatar
Got my 750 GB external Seagate HD replaced. This time I mounted it in a cooler location with a direct SATA connection to avoid overheating. I think the Nexstar 3 enclosure is fine for smaller / low-power disks, but don't want to take the chance of burning another one up in that enclosure. Since the enclosure only provides power and a direct eSATA connection anyway, I found another solution to do that with better cooling.
I still feel that this is not the best choice for a disk for this type of add-on to storage for the Pace CableCARD HD boxes, but right now do not have the change to try out other drives, like the Hitachi CinemaStar low-power streaming-optimized ones that I think would be a better choice. In any case, it would be nice to have the option of migrating files directly from one drive to another for purposes of being able to change out the disks without losing content. Lindend, can this be a feature request for a future firmware update?
Finally, it seems that the disk is very frequently written to, at least with some series recordings programmed in. With a plain-vanilla SATA drive like this, I hear the heads move all the time, and it is pretty annoying. It would be better if this were controllable, or if the Pace boxes had some sort of buffer to cut down on this type of head movement, as it can't be good for the drive at all (optimized or not). What options can we or you pursue to reduce head movement due to TV Guide updating, series recording checking, etc.? This noise happens even when no other activity like recording or playback is happening on the Pace box.
Thanks for your attention.
ScienceMan is offline
post #285 of 1068 Old 01-28-2008, 04:24 PM
fullwave2's Avatar
Software version is 9.65 if that helps.
post #286 of 1068 Old 01-28-2008, 07:04 PM - Thread Starter
lindend's Avatar
I'll add it to the request queue.
I'm afraid this is working as designed. TVG records 24/7 unless you are in standby. The reason you don't notice the internal drive as much is its optimized for DVR applications.
Linden
lindend is offline
post #287 of 1068 Old 01-29-2008, 04:56 AM
fullwave2's Avatar
I guess even Lindend is stumped. I was hoping to find some help on this forum but that doesn't appear to be the case.
post #288 of 1068 Old 01-29-2008, 10:58 AM
ScienceMan's Avatar
A solution might be to change some of the logic used to select the destination for recording. Most people add an external disk to gain recording capacity. Right now you direct all traffic to the disk with the largest amount of unused space, I believe. An optimization that might work for most people would be to always use the internal disk for TVG, and use the disk with the most unused capacity for bulk recording.
post #289 of 1068 Old 01-29-2008, 11:06 AM - Thread Starter
lindend's Avatar
No, not stumped, just very busy. Please give me at least a few hours to respond before assuming I've given up (remember, I'm not in tech support).
Anyways, it sounds like your CableCARD has not been properly paired and/or validated. A phone call to the right CSR should fix it.
Linden
lindend is offline
post #290 of 1068 Old 01-29-2008, 11:28 AM
Roginator's Avatar
How about this idea similar to, what?, ReadyBoost? on Vista-equipped computers..
Have a place where you can plug in a 2 or 4 GB memory stick to handle the repetitive disk-thrashing work.
Roginator is offline
post #291 of 1068 Old 01-29-2008, 05:21 PM
SCEvan's Avatar
Ok either my Pace DVR is possessed or my provider is doing some sort of maintenance because my box just turned off and on itself about 6 times :|
SCEvan is offline
post #292 of 1068 Old 01-29-2008, 07:32 PM - Thread Starter
lindend's Avatar
Unfortunately, there is no such thing as a bulk recording. Sorry, I can't get into design decisions and rationales in a public forum but there are sound technical reasons for the current implementation.
We have however heard your requests/suggestions on this topic.
Linden
lindend is offline
post #293 of 1068 Old 01-30-2008, 11:18 AM
Chudman's Avatar
Originally Posted by Chudman View Post
I just came to cable (Armstrong) from DirectTV, and have a few questions about the TDC778X:
1. Is there a special cable to connect the external SATA drive? The one I use on my motherboard won't plug into the Tahoe port.
2. Can I set up the program menu to only show those channels I subscribe to? This was a great feature of my TIVO.
3. Is there a way to jump forward or back during playback? My TIVO could let me go in increments either way, and also instantly go to the beginning or end without having to FF or REW and wait a long time.
Help will be appreciated!
Any takers?
Chudman is offline
post #294 of 1068 Old 01-30-2008, 12:27 PM
ScienceMan's Avatar
I'll take this one:
You need an eSATA cable. This is essentially just a SATA cable with keying and shape arranged to plug in to an external connector. If your external disk is also in an eSATA enclosure, it is likely that this cable came with the enclosure.
post #295 of 1068 Old 01-30-2008, 12:30 PM
ScienceMan's Avatar
Now for this:
You only get the channels included in your cable provider's package, no doubt, but what I think you are saying is that you'd like to suppress listing of channels not of interest to you. Whether or not you are saying that, I would like to have this feature also. (I don't want to see listings for certain channels that have programming I never watch.)
post #296 of 1068 Old 01-31-2008, 12:49 AM
WhatHappend's Avatar
Now for this:
I get listings for all channels the Cable company has whether or not I pay for them. It really sucks having to scroll through all the channels that I don't get. When you select them the Pace tells you to press info to get ordering information. My SONY DVR with cable card lets me hide channels that the Cablecard detects so I don't have to deal with them.
I second the feature request to let the user hide channels or at least auto-hide all channels that the user is not authorized for.
WhatHappend is offline
post #297 of 1068 Old 01-31-2008, 01:35 PM - Thread Starter
lindend's Avatar
The channels shown in the guide are controlled by the Electronic Program Guide (EPG) which is TV Guide in this case. Sorry, but this code is contributed by another company (TV Guide) and we can't modify it.
The most effective means of impacting the future software road map of TVG is to contact your cable company and let them know that you'd like to see that feature added.
Linden
lindend is offline
post #298 of 1068 Old 02-01-2008, 07:04 AM
rockman1_1's Avatar
I also agree this would be a nice feature.
One way to accomplish this might be to add a favorites group within TVG and only include channels you want to see (or in this case the ones you subscribe to). I don't believe there is a quick short cut on a remote to get to a specific favorites list. If you have a fancy programmable remote, you could probably program a macro to get you to the list in one button press.
rockman1_1 is offline
post #299 of 1068 Old 02-01-2008, 08:59 AM
Chudman's Avatar
Now for this:
You are correct. I only want to see those channels I select. I'll let my cable company know my vote for this feature.
Also, thanks for the eSATA cable reply. I'll try it out.
Chudman is offline
post #300 of 1068 Old 02-01-2008, 09:04 AM
Chudman's Avatar
Is there a way for us to upgrade the firmware on the 778X ourselves, or do we have to replace it through the cable company?
Chudman is offline
Reply HDTV Recorders
