Dish ViP722 DVR Best HD DVR on the market! - Page 13 - AVS Forum | Home Theater Discussions And Reviews
post #361 of 650 Old 12-10-2009, 04:48 AM
KRUZNBY's Avatar
If you have an antenna hooked up and are not recording 3 things, you can change the channel to one of the bonus local channels that show reruns of Magnum PI or something before you even turn on the TV. The other option I have used is to hold my hand up to cover my vision on the right side and obviously have the TV muted. I too think there should be an option to disable live view when some or all of the tuners are active.
KRUZNBY is offline
post #362 of 650 Old 12-10-2009, 12:38 PM
bflip1080's Avatar
Just got my ViP722k installed about an hour ago, but now i am back at work waiting to go home and play. I am excited to start using this new DVR. I moved into a new house and got rid of my old HD-DVR(and comcasts crappy macroblocked hd channels) and after almost two months without TV, it is about time.
Quick question, I have searched a little but can't find the answer: Can I plug in a 1TB external hard drive and be able to use 750GB since that is the supposed max compatible with this receiver? Or do i need to have an external hard drive with a max of 750GB for it to work at all? Thanks in advance!
Beauty, thy name is KURO.
bflip1080 is offline
post #363 of 650 Old 12-10-2009, 12:44 PM
bobby94928's Avatar
Liked: 369
1 TB works just fine as long as it is a single disc. You are going to need to pay the one time charge to be able to use it though.
Bobby
bobby94928 is offline
post #364 of 650 Old 12-10-2009, 12:47 PM
bflip1080's Avatar
Awesome, thats good to know. Thanks!
Yeah, totally worth the $40 to have a TON of storage. Time to start recording.
Thanks again Bobby!
post #365 of 650 Old 12-13-2009, 02:29 AM
alokeprasad's Avatar
Quoted: 42 Post(s)
I just bought an new receiver and 7.1 speakers. The 722 is connected to this via HDMI connector.
What are the settings to use on the 722 for best audio and picture?
Aloke Prasad
alokeprasad is offline
post #366 of 650 Old 12-13-2009, 08:51 AM
bobby94928's Avatar
Liked: 369
For audio, Dolby Digital/PCM.
For video you have two choices, 1080I and 720P. Try each one and see which one looks best to you and leave it there.
Bobby
post #367 of 650 Old 12-13-2009, 12:38 PM
Quoted: 42 Post(s)
Whats the difference between DD and DD/PCM settings?
post #368 of 650 Old 12-13-2009, 05:42 PM
bobby94928's Avatar
Liked: 369
If you use just DD, you will not get any sound on programming that is not DD encoded.
Bobby
post #369 of 650 Old 12-13-2009, 08:44 PM
Quoted: 42 Post(s)
That's strange.. I picked DD only, but I still get stereo sound on channels that I *know* are not DD (like some international channels). The receiver correctly switches to a DD-type setting for most "American" channels.
post #370 of 650 Old 12-14-2009, 06:28 AM
primetimeguy's Avatar
Quoted: 556 Post(s)
Liked: 359
DD is often time only stereo, 2.0.
primetimeguy is offline
post #371 of 650 Old 12-18-2009, 09:40 AM
saumil's Avatar
Aloke Prasad
Connect the sat box to receiver using HDMI cable and Audio using optical audio connection. At the Receiver keep the surround settings to Neural for best 7.1 effects, IMHO.
saumil is offline
post #372 of 650 Old 12-18-2009, 09:53 AM
Quoted: 556 Post(s)
Liked: 359
Don't need optical for audio since you get that with HDMI.
Neural is personal preference, chose your surround mode as you wish.
post #373 of 650 Old 12-18-2009, 10:19 AM
Quoted: 42 Post(s)
Any settings on the 722 besides 1080i and Dolby+PCM?
I am using HDMI to connect the two devices.
post #374 of 650 Old 12-18-2009, 10:21 AM
Quoted: 556 Post(s)
Liked: 359
That should do it, you're all set from the 722 side of things.
post #375 of 650 Old 12-29-2009, 06:09 PM
manchest7's Avatar
My 2 year contract with dish ends in May, and I'll own the 722 to keep because it will be all paid for. Will I be able to use the 722 as a DVR for OTA channels without having a subscription to DISH? I have looked around, but couldn't find the answer.
manchest7 is offline
post #376 of 650 Old 12-29-2009, 06:13 PM
Quoted: 42 Post(s)
Whats the difference between 722 and 722x?
Is there any Dish STB DVR which feeds 2 HD signals to 2 HDTV?
post #377 of 650 Old 12-29-2009, 06:13 PM
Quoted: 556 Post(s)
Liked: 359
Just because your contract is up does not mean you own the 722. Unless you paid for it upfront, you are just leasing it and it must be returned if your contract expires.
It will not work without a contract for OTA only.
post #378 of 650 Old 12-29-2009, 06:20 PM
manchest7's Avatar
No, over the course of two years, the DVR is paid for according to the Dish installer. If I were to cancel Dish before the two year contract ends, then I would have to return the DVR according to what he said. Anyways, if it will not work without a contract for OTA only, what will it work for? I think you are saying that it won't work at all, but need some clarification.
post #379 of 650 Old 12-29-2009, 06:29 PM
bfdtv's Avatar
Dish Network and DirecTV both maintain ownership, although they rarely ask customers to return the DVR after two years. But per your subscriber agreement, they could ask you to return the DVR.
Dish Network and DirecTV DVRs do not function at all without a satellite subscription. DVR functionality is not available unless you pay the DVR fee.
bfdtv is offline
post #380 of 650 Old 12-29-2009, 06:35 PM
manchest7's Avatar
That's odd about being given false information. Well, I guess there's no point to own the box if I couldn't use it without paying fees to Dish anyways. I guess either a HTPC or running windows media center + PS3 media server to a PS3 would be my best bet then without buying something like a moxi DVR.
Thanks for the replies guys.
edit: The 722 box was paid for upfront. It's not being leased.
post #381 of 650 Old 12-29-2009, 07:56 PM
darthrsg's Avatar
Location: Barrel of Burning Trash On A Cold Skid Row Street
Quoted: 2093 Post(s)
Liked: 2524
Explain to me why some options are grayed out like say in a group of recordings the "delete group" option is grayed out. Also why can I not cancel a recording on tuner 2 without using the tuner two remote in dual mode?
darthrsg is offline
post #382 of 650 Old 12-29-2009, 08:27 PM
Quoted: 556 Post(s)
Liked: 359
In dual mode each tuner is treated as an entirely separate entity, so it assumes you don't want someone on TV1 messing with what is going on with TV2.
Grayed out just means that option is not available for use based on various circumstances, such as maybe there is an open file (playing or recording) in the group.
post #383 of 650 Old 12-29-2009, 11:41 PM
bfdtv's Avatar
You paid the $350-$450? If so, then you "own" the unit, but the only benefit is you (a) are never asked to return the unit, and (b) do not have need a two-year programming commitment. Only leased DVRs require the two-year programming commitment. These DVRs still require a satellite subscription and DVR fee to function.
Note you do not own the unit if you paid $99-$199. That's the standard, upfront lease fee charged to existing Dish and DirecTV customers.
bfdtv is offline
post #384 of 650 Old 12-30-2009, 03:03 PM
Quoted: 42 Post(s)
Bump!
post #385 of 650 Old 12-30-2009, 03:16 PM
Quoted: 556 Post(s)
Liked: 359
Bump!
722k is newer version of 722. 722 has built in OTA tuner. 722k OTA is an optional module with two tuners so you can record 2 OTA channels at once.
No Dish box will feed HD to TV2. Only option is to use it in single mode and connect one TV via HDMI and the other via component....both always watching the same channel.
post #386 of 650 Old 12-30-2009, 03:17 PM
bfdtv's Avatar
There's no such thing as the 722x. I assume you mean the 722K.
The K version uses a newer, much faster CPU that can support future enhancements like this 16:9 HD UI; the CPU in the older 722 model is limited to 16:9 SD UI. It does not include a single, built-in OTA tuner like the ViP722; it supports a ~$40 OTA module with two OTA tuners. The K version can record four different channels at the same time (2 sat, 2 ota) when you add the optional ~$40 OTA module.
No.
bfdtv is offline
post #387 of 650 Old 12-30-2009, 04:23 PM
Quoted: 42 Post(s)
Thanks for the info. It doesn't seem worthwhile to upgrade from 722 to 722k.
How can Dish get away with STB that supply only one HD output! Most all 2nd TV are HD in households.
It seems like a trivial add-on to the 722, as the 722 already has 2 HD tuners and has the horsepower to record 2 HD streams. Is it a big deal to output 2 HD streams?
post #388 of 650 Old 12-31-2009, 09:31 AM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
In short, yes it is that hard. Most DVRs only supply only 1 output period, so Dish it actually ahead of the game in that respect. Then there is the problem of distributing the HD signal to the second TV. Lots of options here, but none are inexpensive.
Ted
ncted is offline
post #389 of 650 Old 12-31-2009, 10:46 AM
Rick_R's Avatar
The problem with two HD outputs isn't technical. They could make the TV2 output to be an ATSC output easily. The problem is that this output would be unencoded so that anything broadcast on the satellite could be recorded. The content providers would shut down Dish Network if they did this.
Rick R
Rick_R is offline
post #390 of 650 Old 12-31-2009, 04:14 PM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
Rick R
That is one of the ways in which it would be expensive.
ncted is offline
Reply HDTV Recorders
