Dish ViP722 DVR Best HD DVR on the market! - Page 18 - AVS Forum | Home Theater Discussions And Reviews
post #511 of 650 Old 05-20-2010, 02:15 PM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
Originally Posted by lsilvest View Post
Actually, the 722 isn't that efficient for disk space. I have 76 hours of HD, 12 hours of SD and 15 HD hours available on the 750GB drive, which calculates to about 8GB per hour.
My HTPC OTA HD Mpeg-2 recordings (1080i and 720p) using BeyondTV average around 6GB per hour.
Are you referring to the internal drive or an external one? The internal one in the 722 is 500GB with a certain portion reserved for the 1080p on-demand content (100GB iirc). When I transfer recordings to my external drive, a half-hour show will generally be 2-2.5GB and an hour-long show is ~4.5GB. It also depends greatly on the content. Action movies for instance take up a lot more space than a dialog-centric drama.
Ted
ncted is offline
post #512 of 650 Old 05-20-2010, 03:05 PM
lsilvest's Avatar
Ted
My bad. It's the internal drive. I honestly thought the 722 had a 750GB drive and the 622 a 500GB. If it's only 500, then roller11's facts are way off (must have watched a D* commercial). Most of my recordings are movies and some concerts from Palladia.
lsilvest is offline
post #513 of 650 Old 05-20-2010, 04:25 PM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
Yep. The 722 has a 500GB drive and the 622 has a 320GB. In both cases a significant portion is reserved for on-demand content. The 922 has a 1TB drive.
Ted
ncted is offline
post #514 of 650 Old 05-21-2010, 10:13 AM
lsilvest's Avatar
I've had something strange happen with my 722 recently. When turning it on, I get no picture or sound. All of the menus, info, etc. work fine. I have to reset the unit, then everything is back to normal. What's really weird is that it's only happened twice, both times in the last week, and both times early Thursday evening. Each time it happened, a recording was taking place and the recordings were perfect (I waited to reset until after the recordings were done). I have OTA hooked up to the unit and there was no picture or sound on any of those channels either.
Obviously there's a glitch in the software, but wondering if anyone else has had this happen and if it may be a precursor of unit failure.
lsilvest is offline
post #515 of 650 Old 05-21-2010, 10:22 AM
darthrsg's Avatar
Location: Barrel of Burning Trash On A Cold Skid Row Street
Quoted: 2088 Post(s)
Liked: 2521
I've noticed that in the last week the "info" display does not go away unless you press "exit." Very annoying.
darthrsg is offline
post #516 of 650 Old 05-21-2010, 12:45 PM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
I've seen that before. I haven't seen it in a while, but I am no longer using OTA, so perhaps that is why. My 722 is 2 years old now, so I doubt it is an indication of anything other than buggy software.
Ted
ncted is offline
post #517 of 650 Old 05-21-2010, 12:46 PM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
When are you using info? In the guide, while you are watching something (paused or otherwise), or some other scenario. I have not seen this, but I will test when I get home.
Ted
ncted is offline
post #518 of 650 Old 05-21-2010, 01:52 PM
TheKrell's Avatar
Precisely my situation and observations too. Except I still use OTA extensively due to the HD or subchannels not yet on satellite.
TheKrell is offline
post #519 of 650 Old 05-21-2010, 02:42 PM
lsilvest's Avatar
I've seen that before. I haven't seen it in a while, but I am no longer using OTA, so perhaps that is why. My 722 is 2 years old now, so I doubt it is an indication of anything other than buggy software. Ted
Thanks. Just wanted to know if it was a brief anomaly or more serious. Only reason I mentioned OTA was to indicate that it didn't seem to be related to satellite reception.
I only use the OTA to record when my HTPC tuners run out, but I'll take the OTA PQ and reliability any day (and it's free).
lsilvest is offline
post #520 of 650 Old 05-21-2010, 02:59 PM
darthrsg's Avatar
Liked: 2521
Ted
Never really "use" it but if you come out of the guide to a channel the channel banner stays on the screen, it used to time out after a few seconds. Weird.
darthrsg is offline
post #521 of 650 Old 05-21-2010, 04:38 PM
lsilvest's Avatar
You're right, it should be going off in just a couple of seconds. Tried resetting the receiver? I wonder if some of these quirks don't pop up just after their updates.
lsilvest is offline
post #522 of 650 Old 05-21-2010, 06:02 PM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
Ah, mine stays around for about 3-4 seconds.
ncted is offline
post #523 of 650 Old 06-17-2010, 02:09 AM
HomeAppraiser's Avatar
When I push any forward, back, pause or play buttons during live TV or playback of a recorded show, I see the blue arrows on the screen that used to go away after 5 seconds. Now it stays there unless I hit Info then select to clear it. Is this a hardware or software problem and is there a fix?
Also, I have now had three incidences of a show recording in 30 one minute sections instead of one 30 minute. Any help?
HomeAppraiser is offline
post #524 of 650 Old 06-17-2010, 07:09 AM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
I haven't seen this behavior. Have you reset your DVR? That can sometimes clear out software bugs. If so, then I recommend getting on a chat with Dish Tech Support.
Ted
ncted is offline
post #525 of 650 Old 06-18-2010, 06:20 PM
Looks like I'm not the only one getting shows in 30 one minute recordings http://www.satelliteguys.us/dish-net...ent-1-min.html
post #526 of 650 Old 06-18-2010, 07:32 PM
KRUZNBY's Avatar
I had that happen a few times. I did nothing specific to correct it.
KRUZNBY is offline
post #527 of 650 Old 06-21-2010, 04:03 AM
Ted
Powering on and off cleared the stinking blue arrows. No new one minute recordings, but that has only happened 3-4 times over seven weeks so I'd have to go a month without seeing short recordings before I call that problem solved.
post #528 of 650 Old 06-24-2010, 06:45 PM
Now Closed Captioning stopped working.
post #529 of 650 Old 06-25-2010, 02:23 PM
darthrsg's Avatar
Liked: 2521
Mine has really started sucking lately. Searching for signal, updates in the middle of the day, short recordings. I'm going to call it in this weekend.
darthrsg is offline
post #530 of 650 Old 06-27-2010, 05:40 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
I was looking at the Dish web site & have a few questions.
Free DVR and free HD, as long as you go with their direct billing. It looks like the ViP 722 DVR might be the way to go. I called Dish and to record OTA it appears an additional module needs to be installed which they said was no charge. It appears the only additional charge would be a $6.00/month DVR fee.
Are there any local taxes or franchise fees like Comcast has?
Can programs be transferred to a PC in order to save them and/or burn a disc?
How many days out does the electronic program guide extend?
I did read through the forum & did some searching which raised a couple questions. One is about a warranty. My Comcast DVR has been replaced several times within a year & it never cost me anything because I don't own it. I thought the Dish DVRs were also leased/rented, but it appears some are purchased because people talk about a warranty. They are offering a free DVR, but is this considered a purchase, even though I have to pay a monthly fee?
The Dish rep I spoke with did say model 722K but I took the K to mean the DVR was black since other consumer electronics use this designation. And there was no 722K on their web site. According to the forum it appears the 722K is a slightly different model & the OTA module includes 2 tuners and costs $40. Has anyone got the module for free as the rep told me? Or could he possibly be implying that it would be a single tuner module for free in the 722K?
Any comments or suggestions would be appreciated.
Thanks in advance.
Mike99 is offline
post #531 of 650 Old 06-28-2010, 07:11 AM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
Depends on where you live. Dish should be able to tell you this when you call to order.
Not in any easy way that we've been able to determine
In my experience, a little over a week
Most people don't purchase since it is several hundred dollars up front and difficult to get repaired out of warranty. If it is free it is leased. If you get the Protection Plan, it will cost $15 for a tech to come out to your house to fix problems. Not sure what the fee would be to replace a failed DVR, if any.
The 722k is an updated version of the 622/722 series of DVRs from Dish. Only the marketing minds within Dish know what the K stands for as the original 722 is black. It has an optional OTA module that allows you to record 2 OTA recordings in addition to the 2 Satellite tuners. It is not uncommon for Dish to include the OTA tuner module for free.
Thanks in advance.
ncted is offline
post #532 of 650 Old 06-28-2010, 07:43 AM
lsilvest's Avatar
You can record using a Hauppage HD PVR (about $190), or an Avermedia HD DVR card ($89). The Hauppage is widely in use and I believe works with Win7. By using an IR blaster you can switch channels to record, or just do manual recordings live or from previous recordings. I use the Avermedia card which only works manually. It has HDMI inputs, but the software is really flaky and only records 2 channel audio even through the HDMI. You can also use component, s-video, or composite inputs. There's another high-end card similar to the Avermedia but costs as much as the Hauppage.
lsilvest is offline
post #533 of 650 Old 06-28-2010, 03:37 PM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
ncted,
Thanks for all the information.
Dish's Protection Plan seems strange to me in that I would have to pay for a plan to cover something I do not own. Plus have to pay for a tech to come out to the house to fix their property. I'm certainly not sticking up for Comcast and am looking to drop them, but they have never charged me to fix or replace their leased equipment. I guess the providers get your money one way or the other.
Thanks again.
Mike99 is offline
post #534 of 650 Old 06-28-2010, 06:23 PM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
ncted,
Thanks again.
Yes, these are the sorts of fees that people complain about with Dish. I've only had to pay for a tech once when I got a new Dish installed. If I had gone through Dish initially instead of a local reseller, I would have gotten the right dish to begin with. Ah well, I am still way ahead of where I would be if I still had TWC.
Ted
ncted is offline
post #535 of 650 Old 07-05-2010, 01:03 PM
MojaveRon's Avatar
Any one know if the Logitech Harmony 550 Advanced Universal Infrared Remote Control supports the Dish Network ViP 722K DVR I am trying to find out before purchasing it.
and have not been able to find any Info on it.
MojaveRon is offline
post #536 of 650 Old 07-05-2010, 01:17 PM
bobby94928's Avatar
Liked: 369
Yes, all the Harmonys will support the 722K.....
Bobby
bobby94928 is offline
post #537 of 650 Old 07-05-2010, 01:41 PM
Sundance's Avatar
Ted
It gets even better. Dish is now charging you to return their equipment if you cancel or at the end of your contract you don't renew. To me Dish is taking over the spot of scum of the TV providers, beating out Cable by a long shot. If cable just didn't have such junk equipment I would go back to them in a sec.
Maybe there is hope with fiber, are people happy with Verizon's FIOS?
Sundance is offline
post #538 of 650 Old 07-05-2010, 02:15 PM
MojaveRon's Avatar
Thanks for the reply.
post #539 of 650 Old 07-05-2010, 02:25 PM
ncted's Avatar
Quoted: 83 Post(s)
Liked: 38
While that sucks, I am neither surprised nor upset. Dish is still cheaper than cable, and, as you pointed out, offers a much better equipment. If you want a good experience, FIOS with Tivo is about the best out there from what I hear. If only Verizon hadn't sold my market to Frontier!
Ted
ncted is offline
post #540 of 650 Old 07-07-2010, 05:22 PM
Send it "Media Mail". What Ted said, they are cheaper monthly, but the nuisance fees add up quickly.
The 722k seems to be like a gas gauge on an old American car, it drops very slowly the closer you get to E. I have been waiting for an excuse to spend $39.99 for the privilege of hooking up my own 1TB expansion drive, but the lowest I have gotten down to is 15 hours of HD remaining. I am even stockpiling movies for when we drop the $24/month HBO-Showtime at the end of this month. In doing that I have run across another one of the 722k limitations:
It is limited to 40 timers. We have 5 people who want to record shows for 2 TVs and some shows are only on occasionally so we are maxed out on timers. Should I switch to Dish Pass instead?
Reply HDTV Recorders
