HD 1000 and 720p question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-09-2001, 08:26 AM - Thread Starter
artur's Avatar
Hi, I would like to know if you can record and play back 720p in its native format to display device via tuner?
Artur.
artur is offline
post #2 of 4 Old 11-09-2001, 01:37 PM
gridleak's Avatar
If you are referring to the Panny combo (PV-HD1000 and TU-DST50/51), yes, they will record, play back, and output 720p for display. A switch on the back of the DST50/51 can be set to allow 720p to be output without being converted to 1080i.
-Roger
gridleak is offline
post #3 of 4 Old 11-12-2001, 11:17 AM - Thread Starter
artur's Avatar
Hi, Thanks for respond, I also would like to know where I can locate some demo material in 720p on D-VHS that can be used for image quality test of TV's.
best regards Artur.
artur is offline
post #4 of 4 Old 11-12-2001, 12:01 PM
gridleak's Avatar
ABC HDTV is broadcast as 720p. Check on titantv.com to see if there's an ABC DTV station close enough so you could make your own demo using the Panny combo.
-Roger
gridleak is offline
Closed Thread HDTV Recorders
