16X9 or 4X3 picture.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-19-2001, 10:42 AM - Thread Starter
slimoli's Avatar
Quoted: 497 Post(s)
Liked: 233
When we record a true HD program , does the HD recorder (JVC,Mits) also records in 16X9 ?
I was so happy without HDR...
slimoli is offline
post #2 of 3 Old 11-19-2001, 11:36 AM
michaeltscott's Avatar
Quoted: 2711 Post(s)
Liked: 1436
They record the bitstream that comes from the broadcast, and regurgitate them to be converted to display by the same thing that you'd used to decode them to watch the broadcast in realtime (except for the JVC, which can decode recordings and output the HD analog itself, with some restrictions for copy-protected content). Playback of recordings should be indistinguishable from watching the original broadcast. (Well, if you used the JVC's analog outputs for playback, there could be some difference between the quality of its decoding and your STB's or internal tuner's).
The JVC will also allow you to watch downconversions of HD recordings through its S-video and composite analog outputs. If you had an STB with FireWire HD output and no DTV monitor yet, you could buy the JVC and use it to start archiving HD and watch the tapes in analog until you bought a monitor (which would be strange, but possible :)).
-- Mike Scott
Mike Scott (XBL: MikeHellion, PSN: MarcHellion)
"Think of the cable company as a group of terrorist (sic)." -- hookbill
michaeltscott is offline
post #3 of 3 Old 11-19-2001, 11:31 PM
HiDefGuy's Avatar
Yes.
HiDefGuy is offline
Closed Thread HDTV Recorders
