Pace TDC778X (aka Tahoe CableCARD) Release Notes Thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-12-2007, 08:46 AM - Thread Starter
lindend's Avatar
This thread will only contain release notes for Pace TDC778X (a.k.a. Tahoe CableCARD) firmware releases. Please don't ask questions on this thread as it is strictly for release notes. General Tahoe CableCARD questions, or specific questions about releases can be posted on the Tahoe CableCARD thread.
Linden
Pace Americas, Inc. (note the views expressed here are my own and not necessarily those of Pace).
lindend is offline
post #2 of 5 Old 11-12-2007, 08:53 AM - Thread Starter
lindend's Avatar
9.62-9.66 AVS Release Highlights
These releases are all the same but VOD support differs.
Disclaimer: These are highlights from the release notes with issues that are relevant to AVS users.
1. The highest trick mode speed may be faster for some content.
2. Time bar jumps around during trick operations.
3. Captions aren't temporarily disabled if you do a trick operation.
4. Faster swaps to Music Choice channels.
5. Unplayable recordings after reboot.
Linden
lindend is offline
post #3 of 5 Old 04-29-2008, 08:28 AM - Thread Starter
lindend's Avatar
Disclaimer: These are highlights from the release notes with issues that are relevant to AVS users since 9.62. Please don't ask (or PM me) if/when your local cable company is going to roll out this release.
1. Fix for E3106 error when using VOD.
Note: This release is initially only for Tandberg VOD sites. It is not currently available for sites running other VOD applications.
Linden
lindend is offline
post #4 of 5 Old 05-15-2008, 07:06 AM - Thread Starter
lindend's Avatar
10.62-10.66 AVS Release Highlights
  1. Improved display of closed captions.
  2. Error handling for CableCARD validation state (9) scenarios.
  3. Info banner pops up when using Arris VOD.
  4. Recordings don't start automatically after a warm reset.
  5. Improved error handling when using Arris VOD.
  6. Tandberg VOD client displays error 3106.
  7. Concurrent HD VOD works.
  8. Increased volume levels audio on HDMI connections.
  9. Add diagnostics dashboard.
  10. Dolby Digital now works over HDMI.
  11. Diagnostics now reports CRC errors from the HDD.
Linden
lindend is offline
post #5 of 5 Old 04-28-2009, 05:35 AM - Thread Starter
lindend's Avatar
Disclaimer: Please don't ask (or PM me) if/when your local cable company is going to roll out this release or if/when your cable provider will deploy Aspen boxes.
  • DVR functionality lost and requires a reboot to recover
  • Ch. 1 on the front panel when coming out of standby
  • Time drift causes recordings to start late
  • TVG messages show up after being deleted.
  • TVG messages re-appear in standby after they expire.
  • A/V dropouts on HDMI after a hot plug.
  • Seachange VOD client shows One Moment Please (OMP) during navigation.
  • 1 TB and larger drives are now supported.
Linden
lindend is offline
Reply HDTV Recorders
