Victor HM-DH35000 does no longer downrez - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-30-2001, 08:00 AM - Thread Starter
robena's Avatar
Quoted: 36 Post(s)
Liked: 24
I have a tape which systematically triggers the downrez "feature" of the Japanese Victor HM-DH30000.
It's very obvious on credits, where one can see that the vertical part of a letter is ghosted on the right. Rather than seeing a sharp:
you see:
where the second | is dimmer than the first. That's a crude but very effective way to mess the image. Using a Japanese BS tape first brings back the full resolution.
Well, I just tried the new 35000 with the same tape (HBO BoB), and this does no longer happen.
Robert
robena is online now
post #2 of 6 Old 11-30-2001, 08:40 AM
tmitchmd's Avatar
How is audio on the 35000 using ATSC (USA HD system). Does it have the dropout problem as on the Japanese 30000?
Will the 35000 record from the TU-DST50/51 STBs?
Will the 35000 playback the demo tape that comes with the 30000U?
"Dammit Jim, I'm a doctor not an engineer."
tmitchmd is offline
post #3 of 6 Old 11-30-2001, 09:13 AM - Thread Starter
robena's Avatar
Quoted: 36 Post(s)
Liked: 24
tmitchmd,
I live in France, so no recording for me <sigh>.
I just got the 35000, and did not yet had the opportunity to test it completely. I don't have a 30000U demo tape either.
I'll post about audio dropouts after viewing a few tapes.
I'm still trying to connect the 30000 and the 35000, but so far no luck. I'll have to try a different cable next week. If you have any idea why 2 units do not see each other, besides a bad cable, I'd appreciate any tip.
Robert
post #4 of 6 Old 11-30-2001, 09:53 AM
Glimmie's Avatar
Quoted: 753 Post(s)
Liked: 622
This is consistant with what I learned from JVC. The initial releases will not be image constrained. Reasons:
1) There is presently no way outside of spending $150K to record fromt eh analog outputs.
2) There are very few 1394 equipped HDTVs. Analog is the only way to debut the format.
As it is being marketed as the highest quality HDTV for the consumer, any image constaint would ruin this marketing advantage.
Glimmie is offline
post #5 of 6 Old 11-30-2001, 11:06 PM - Thread Starter
robena's Avatar
Quoted: 36 Post(s)
Liked: 24
tmitchmd,
I did a quick listening, and I had one dropout in 15 minutes. When going back over the same passage, the dropout did not repeat, so the recording itself was not faulty.
Robert
post #6 of 6 Old 12-01-2001, 06:59 AM
bb1987's Avatar
That is the same dropout problem that plagues all the JVC/Victor Vcr's including the new 30000U.
I had them occur only with HBO/Showtime movies, not OTA or the demo tape.
The dropouts are intermittend and do not repeat, so they must be caused by the JVC/Victor.
This dropout thing drives me crazy. I had to put my Panny combo back into my theater for playback since I find the dropouts unacceptable.
Does anyone have additional info on these audio dropouts and if they occur only with certain decoders and not with others. These dropouts are obviously different than the audio dropouts that occur with the Panny 5x and non-crystal decoders.
Bernhard
bb1987 is offline
Closed Thread HDTV Recorders
