Various test with JVC-DH35000 D-VHS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-30-2001, 06:06 PM - Thread Starter
Jaehong Lee's Avatar
I will conduct various test tonight with JVC-DH35000 D-VHS tonight.
One of my friend will bring this D-VHS to my home.
I have Panny set(Updated TU-D50 and HD1000) and Japanese BS digital STB
( Toshiba DTT-2000) and Panasonic NV-DH1 ( Japanese Version BS D-VHS)
I can receive 5 ATSC HDTV stations ( Korea) along with 7 Japanese BS HDTV signal ( with 1.8 Parabola Antenna)
For the time being, Seoul, Korea would be perfect and only place for conducting this HDTV compatibility test.
Anyway I am very happy to receive 12 HDTV stations in my home.
Would you suggest any test item in mind?
Jaehong Lee is offline
post #2 of 5 Old 11-30-2001, 06:32 PM
tmitchmd's Avatar
Greetings Jaehong Lee,
Hope you and family are all doing well.
Please test:
-Playback of ATSC tapes. Audio dropout problem still present as with the 30000? Any video problems, dropouts or downrezing?
-Dubbing to and from PV-HD1000 using both BS and ATSC tapes.
-Comptibility with and recording from Pansonic TU-DST50.
-Can 35000 play back through the TU-DST50 component output?
-If you have access to it can you determine if the 35000 can play back the JVC demo tape that is shipping with the USA 30000?
The Japanese 30000 will not display playback from this tape, nor will the Panasonic duo.
Thank you!
"Dammit Jim, I'm a doctor not an engineer."
tmitchmd is offline
post #3 of 5 Old 11-30-2001, 10:47 PM
robena's Avatar
Quoted: 34 Post(s)
Liked: 24
Hi Jaehong Lee,
I just got my 35000, and I have trouble connecting it to a 30000. I suspect that my IEEE 1394 cable is defective.
Can you confirm that all I have to do normally is use a 4 pins i.link cable between the 2 decks, and select a I-N input to make copies? Is there a specific menu which might not be set correctly from factory? My cable was bought from a computer shop, is there a specific cable for video which might be different?
Thanks for any help.
Robert
robena is online now
post #4 of 5 Old 12-01-2001, 08:00 AM - Thread Starter
I think you have defected I-Link cable.
Try Sony I-link cable for digital handy Camcorder.
post #5 of 5 Old 12-01-2001, 08:37 AM
robena's Avatar
Quoted: 34 Post(s)
Liked: 24
Hi,
I finally got it working: the problem was a cable too long (3m). IEEE 1394 allows in theory for 5m cables, but the Victor seems to have lazy drivers. With a 1.8m cable, it works fine.
Thanks for your answer.
Robert
Closed Thread HDTV Recorders
