Official AVS Motorola DCX series HD DVR Topic! - Page 161 - AVS Forum | Home Theater Discussions And Reviews
 58Likes
Old 09-05-2014, 10:11 AM
phildaant's Avatar
Quoted: 819 Post(s)
Liked: 301
Originally Posted by phildaant View Post
Hmm, cable DVR RC's OK/Select button doesn't do anything when I hold it down. I do see DVR's LED status show "IR" text when I hold it down. Am I doing it wrong or did TWC remove it?
Ah, it worked if the DVR is already powered on and see its blinking mail icon in the DVR's status screen, and then its up/down button.
I see D13's page 2 showing:
120F 49.0C
No Over Temp
Max: 127F 53.0C
Nice, SMART sensors. Too bad we can't export these easily to a text file.
phildaant is offline
Old 09-05-2014, 01:16 PM
blackcap93's Avatar
Quoted: 42 Post(s)
Liked: 29
120F 49.0C
No Over Temp
Max: 127F 53.0C
That sounds about right for the 3510.
phildaant likes this.
blackcap93 is offline
Old 09-05-2014, 01:28 PM
phildaant's Avatar
Quoted: 819 Post(s)
Liked: 301
Cool. I hope this DVR was designed to handle that hot. It will be mid 90s degrees this weekend.
Old 09-09-2014, 09:59 AM
Super Moderator
teachsac's Avatar
Quoted: 582 Post(s)
Liked: 776
spambot post and corresponding quote removed. Sorry Phil.
S~
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Samsung UBD-K8500, Panasonic DMP-UB900 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
Old 09-15-2014, 12:11 AM
phildaant's Avatar
Quoted: 819 Post(s)
Liked: 301
Tonight, my Arris DVR (Navigator) needed a power cycle because:
1. Its on demand kept saying unavailable and to retry later when I scroll down its TV shows even though I can see stuff. However, I wasn't able to play anything.
2. DVR wouldn't play of my recordings (tonight's and a few days ago).
I last used it was a couple nights ago to watch my recordings. I had to powercycle it and wait about five/5 minutes. Regular power off and on didn't fix the issues I ran into earlier.
I remember Motorola cable boxes, with their iGuide, had problems too that needed to power cycle (didn't have to wait long).
What about the rest of you guys? Thank you in advance.
Old 09-16-2014, 09:07 AM
phildaant's Avatar
Quoted: 819 Post(s)
Liked: 301
Hello.
Can Arris DCX3510 DVR's rear firewire, USB, and network be used for
anything?
Old 09-16-2014, 10:31 AM
vando45's Avatar
Missed the first half of Masterchef last night. Didn't record due to a "fatal hardware error". Caught it halfway through and hit the record button and it recorded the rest of the show. Other recordings worked fine. Time for a new DVR?
vando45 is offline
Old 09-16-2014, 12:33 PM
phildaant's Avatar
Quoted: 819 Post(s)
Liked: 301
Question
Check its logs? I think RC's menu button -> Apps -> DVR -> Manage ...
Old 09-16-2014, 12:48 PM
phildaant's Avatar
Quoted: 819 Post(s)
Liked: 301
Lightbulb
Old 09-16-2014, 12:58 PM
DSperber's Avatar
Quoted: 222 Post(s)
Liked: 179
anything?
I don't have one, so I can't speak firsthand.
But throughout Motorola/Arris history the USB and network ports have been non-functional as implemented by US cable systems using the hardware.
However the firewire port has ALWAYS been functional and active, intended for connection to an external DVHS VCR for offload/archiving of content from the DVR to DVHS tape. (With the correct drivers and OS on your PC, you could also offload/archive copy-freely content from DVR to PC.)
This DVHS VCR and firewire mechanism is usable for both copy-freely and copy-once content, so you can make a digitally 100% bit-perfect DVHS tape copy of any program you can watch/record on your DVR (thus excluding any pay-per-view or OnDemand, which is marked copy-never and cannot even be recorded on the DVR itself). Of course you cannot make a 2nd-generation DVHS tape copy of a DVHS tape copy of copy-once content (say if you had a second DVHS VCR which can connect to the first DVHS VCR by firewire) as the content is marked "copy-once". You can only have that first-generation DVHS tape copy made from DVR-to-VCR.
That said, ever since the initial early days of the DCX family of products the firewire recording mechanism has been "truly broken" or "iffy". Rumor had it that Motorola/Arris had finally fixed the firmware to get this working again to the essentially glitch-free 100% reliability of the earlier generation DCT* and DCH* boxes, both of which had TWO firewire ports on those units and also used a different manufacturer internal firewire chip on the motherboard.
With the introduction of the current generation DCX* equipment, they went to a single firewire port and a new manufacturer internal firewire chip, and that's what most likely conspired to "break" this previously usable firewire recording mechanism. Rumor has it that these early problems have finally been fixed with more recent firmware/software upgrades to the DCX* units, but I cannot confirm that since I don't use one.
DSperber is online now
Old 09-16-2014, 01:21 PM
phildaant's Avatar
Quoted: 819 Post(s)
Liked: 301
Unhappy
Interesting. TWC said they are not used for anything. Why have them then? Sheesh.
Old 09-16-2014, 03:03 PM
DSperber's Avatar
Quoted: 222 Post(s)
Liked: 179
Well, very few people actually have DVHS VCR's these days (although I still have four of them, though they've gotten near-zero use ever since I went to HTPC for the whole-house). JVC stopped manufacturing them many years ago, and tape recorder technology is considered from yesteryear.
So TWC CSR's may just not really know about their use or purpose. But the firewire port is at least not disabled by TWC as far as I know (as the USB and network ports are), so if you did have a DVHS VCR you at least would be able to try to successfully offload glitch-free to blank DVHS tape (which again, they don't make anymore and which is very hard to find nowadays). If the DCX* firmware truly has been finally fixed, it probably would work fine.
Old 09-16-2014, 03:14 PM
phildaant's Avatar
Quoted: 819 Post(s)
Liked: 301
I have a regular Toshiba W627 VCR, from dotcom days, that used VHS tapes. I don't use it anymore. I know it doesn't come with a firewire port so that won't do.
I do have computers with firewire ports, but I never used them before.
Old 09-18-2014, 08:36 AM
phildaant's Avatar
Quoted: 819 Post(s)
Liked: 301
A few days ago, my Arris DVR (Navigator) needed a power cycle because:
I last used it was a couple nights before it to watch my recordings. I had to powercycle it and wait over five/5 minutes (takes forever!). Regular RC power off and on didn't fix the issues I ran into earlier.
This morning, I had to power cycle a non-DVR Arris DCX3200M cable TV box because it only showed the video/picture for one/1 second and then nothing (no signal according to Samsung HDTV).
I remember the older Motorola, before Arris took over, cable boxes, with their iGuide, had problems too that needed to power cycle (didn't have to wait long).
Old 09-18-2014, 12:05 PM
qz3fwd's Avatar
Quoted: 317 Post(s)
Liked: 135
I still have numerous DVHS decks, andeven have several brand new in box never opened JVC 30K, 40K, and 100/110U's!
I have pretty much every US consumer DVHS deck offered as well as the JVC-SR-VDA400 commerical deck, as well as other AVHDD recorder/players.
Firewire / AVC was such a wonderfull system it is a shame it was priced too high and feared by the content owners.
qz3fwd is offline
Old 09-23-2014, 11:24 AM
Liked: 7
I'm new to the forum, if you couldn't tell
Anyway, I guess I am a ready-shoot-aim type.
I just bought a used Motorola DCX3400 that came with a comcast RNG110 STB.
I do not have cable tv service, but I do get all the major network channels via my antenna (my home internet is provided via comcast cable, however).
I am hoping to use the Motorola DCX3400 to record OTA channels and programming. I assume this will be possible with this device. Is that true?
As for the RNG110, I assume that's going to be a paperweight. Is that true?
HenryBowman is offline
Old 09-23-2014, 11:38 AM
crossbeaux's Avatar
The DCX3400 is a cable device, not OTA. And, at least in the USA, you must rent it from the cable company. You can't hook up your own. So, sorry, but I think you just bought a boat anchor.
phildaant and HenryBowman like this.
crossbeaux is offline
Old 09-23-2014, 11:55 AM
Liked: 7
Thanks. Appreciate your help. Fortunately, I'm not out much on this.
Old 09-23-2014, 12:11 PM
phildaant's Avatar
Quoted: 819 Post(s)
Liked: 301
Yeah, cable companies would have to authorize the boxes too.
HenryBowman likes this.
Old 09-23-2014, 12:24 PM
Liked: 7
Ok. I thought I had read that it had the ATSC tuner built in, but apparently not. Guess I will try to flip it. Anyone want to recommend a device to get in its place?
Old 09-23-2014, 12:44 PM
phildaant's Avatar
Quoted: 819 Post(s)
Liked: 301
Question
Was that online somewhere?
Old 09-23-2014, 12:57 PM
Liked: 7
I thought so. I must have been reading about another device and confused it with this one, cause I can't find that source now.
Old 09-23-2014, 02:49 PM
Liked: 7
Ok, I found where I saw that online but apparently I don't have a high enough post count to post the link.
it was Endgadget dot com ... says it has an ATSC tuner.
Old 09-23-2014, 02:54 PM
phildaant's Avatar
Quoted: 819 Post(s)
Liked: 301
Message me?
Old 09-23-2014, 02:58 PM
Liked: 7
Message me?
Says I can't send a message until I have 15 posts. Urgh. but we will try this again, since it says I only need 5 to post a link.
http://www.engadget.com/products/mot...dcx3400/specs/
Old 09-23-2014, 03:06 PM
phildaant's Avatar
Quoted: 819 Post(s)
Liked: 301
Post
Interesting. http://www.timewarnercable.com/conte..._userguide.pdf doesn't even say anything about ATSC.
Old 09-23-2014, 03:14 PM
Liked: 7
Well, at least now I know where I got the idea this would be a viable solution. What device would you recommend?
Old 09-23-2014, 03:15 PM
crossbeaux's Avatar
I think this is the page you might be referring to. http://www.engadget.com/products/mot...dcx3400/specs/
Curious, it claims only 160GB hard drive, yet says it supports ATSC input and 1080p output. Mine has a larger hard drive and I don't believe supports either of the other two.
Old 09-23-2014, 03:17 PM
phildaant's Avatar
Quoted: 819 Post(s)
Liked: 301
IIRC, TiVo has both ATSC and cable support.
Old 09-23-2014, 03:20 PM
Liked: 7
From what I can tell, 1080p is available thru HDMI (and all the other listed resolutions are available through the component video outputs). Mainly, I am not interested in a subscription service DVR, but I may be stuck with that.
