d-vhs recording help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-08-2001, 09:29 PM - Thread Starter
CLOWNBOY's Avatar
I have a Panasonic tu-dst51 and a hughes dss system and a hughes d-vhs. The Hughes system works great but cannot get the Panasonic to work with the Hughes D-VHS. I want to know if I have to buy the Panasonic pv-hd1000 or are there other other options. Any help would be appreciated.
CLOWNBOY is offline
post #2 of 3 Old 12-09-2001, 03:59 AM
Don Landis's Avatar
Quoted: 1232 Post(s)
Liked: 335
I have not heard of the Hughes DVHS HDTV recorder. This is a section for HDTV Recorders so I assumed you have a HDTV DVHS recorder. The Panasonic DST50/51 accepts only an 8VSB RF signal on it's input. Your DSS Hughes tuner would neet to output an 8VSB RF signal to feed the DST5x tuner. This tuner is designed to output a 1394 firewire signal that carries an MPEG2 video digital signal. This is not the same as the firewire signal used by minidv camcorders which is a "native DV" video signal. Therefore, you cannot simply connect a firewire between just any i-link connector and the Panasonic tuner or Panasonic DVHS VCR. Not all 1394 I/O's are compatible.
You have two, possibly 3 options.
1. Locate what is called the "Panny combo" which consists of a
-DST-5x tuner (you already have)
-PVHD1000
-DishNetwork5000 with HDTV modulator
-Depending on your current dolby decoder you may need a Techniques SAHC500 dolby decoder for full dolby compatibility.
-subscribe to DishNetwork HDTV channels
(This is the only currently reliable way to record and playback the HDTV movie channels and OTA HDTV sources)
2. Contact 169Time and inquire about getting a DTC-100 modification to record to your particular DVHS recorder. Their product is still under development but they are reported to be shipping partially working retrofits now.
3. If your Hughes dvhs recorder has a channel 3 output you could connect it to the channel 3 input of the DST5x but I don't see what purpose this would serve for you.
My 3D videos and more
Don Landis HT System: Projector Sony VPL VW665ES Players: Samsung UBD K8500 OPPO BD93 Sony BDP S6200 All Regions Player Denon AVR 4311ci, 7.1 JBL Professional series and Klipsch PS3, XBOX360, Dish VIP722K
Don Landis is offline
post #3 of 3 Old 12-09-2001, 09:14 AM
jerndl's Avatar
Quoted: 32 Post(s)
I believe that clownboy is referring to the (now discontinued) non-HDTV D-VHS system for recording regular SD DirecTV and digital audio (5.1 if available). Although this system uses a firewire connection it is not HDTV compatible and will not work with the Panasonic HDTV tuner.
Jay
jerndl is offline
Closed Thread HDTV Recorders
