Record Directly to USB Flash Drive? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-24-2008, 09:23 AM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
I have a HDTV capture card (USB actually) and I'm wondering if I can record directly to a USB flash drive (just saw a 8GB SDHC CLASS 6 on sale).
In this way I can transport it w/o having to transfer files from HDD to portable media.
Is the flash drive fast enough for this?
cgott42 is offline
post #2 of 6 Old 01-24-2008, 01:45 PM
11001011's Avatar
As long as flash drive is USB 2.0 and so are your USB ports it should work.
A 'phile and his money are soon parted...
11001011 is offline
post #3 of 6 Old 01-24-2008, 01:48 PM
NetworkTV's Avatar
Quoted: 776 Post(s)
Liked: 1234
I would think the flash drive wouldn't be nearly fast enough, epecially once the interface starts bogging down. Flash drives are way slow compared to hard drives. Even laptop drives blow them away in speed.
NetworkTV is offline
post #4 of 6 Old 01-24-2008, 01:55 PM - Thread Starter
cgott42's Avatar
Quoted: 133 Post(s)
So re: whether it'll be fast enough: 1 yes vote and 1 no vote.
Does anyone have a USB flash drive that they can use to test it?
cgott42 is offline
post #5 of 6 Old 01-24-2008, 03:12 PM
demonfoo's Avatar
Quoted: 49 Post(s)
Liked: 36
I'd be surprised if you couldn't; yes, flash isn't as fast as DRAM, but I'd say it would most likely compare favorably write-speed wise to magnetic disk (what with the lack of moving parts and all). Also, keep in mind that ATSC's peak bitrate is about 19.2 Mbps; that's just shy of 2.5 MB/second. A fair amount, but for modern systems, not that bad; as mentioned above, as long as (a) the port and USB flash device both do USB 2.0 (and any intervening hubs, if any), and (b) you have enough capacity, it should "just work"...
demonfoo is offline
post #6 of 6 Old 01-24-2008, 10:03 PM
11001011's Avatar
I just did a quick test transferring a large file (iso CD image) to my flash drive.
Average transfer rate 7.6 Megabytes per second.
Using a Lexar Sport USB 2.0 flash drive, and USB 2.0 ports on my PC.
11001011 is offline
Reply HDTV Recorders
