How do change the subchannel on JVC 30000? - AVS Forum | Home Theater Discussions And Reviews
Old 12-14-2001, 10:11 PM - Thread Starter
spham17's Avatar
My local PBS is running a HD demo loop. They also multicast regular SD program on the subchannel. I taped the HD program with my PV-HD1000. The tape played back fine with the Panny combo and I can press the "channel button" on the DST51 to switch between the HD/SD channels. However, when I put the tape in my Japanese version JVC 30K, it displayed the SD channel. The same SD channel is displayed when I try to dub the tape regardless which recorder is the source.
How do you change the subchannel on the JVC ?
spham17 is offline
Old 12-15-2001, 05:40 PM
gridleak's Avatar
While the tape is playing, up/down on the big purple oval button at bottom of the controller changes subchannels.
-Roger
gridleak is offline
Old 12-16-2001, 11:33 AM - Thread Starter
spham17's Avatar
Roger,
Thank you for your help. It worked.
Steve
spham17 is offline
