"Widescreen" DVD vs DVD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-16-2012, 08:45 AM - Thread Starter
spiff123's Avatar
Amazon sells two DVDs of Jesus Christ Superstar:
1. Here are the details of one DVD, which does not say "Widescreen" in the title:
Anamorphic, Widescreen, 2.35:1
2. Then, they sell another DVD with "Widescreen" in the title, which is about $10 more expensive. Here are the details for that DVD:
Anamorphic, Widescreen, 1.78:1
Which is better to purchase for playing on a 1920x1080 HD TV? 1.78:1 is 16:9, but doesn't that have less horizontal content than 2.35:1 ? In other words, the cheaper DVD with an aspect ratio of 2.35:1 will display black bars on the top and bottom of my 16:9 HDTV, but will also show more of the film's original content?
spiff123 is offline
post #2 of 3 Old 04-16-2012, 09:17 AM
Tulpa's Avatar
Liked: 61
Well, the original 35mm print of Jesus Christ Superstar in theaters was the 2.35:1 ratio, so I'd go with that one.
edit: Do you mean these two?
http://www.amazon.com/Jesus-Christ-S...4593296&sr=8-3
vs.
http://www.amazon.com/Jesus-Christ-S...4593085&sr=8-7
They're not the same film.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #3 of 3 Old 04-16-2012, 09:56 AM - Thread Starter
spiff123's Avatar
Haha, you're right: these are two different films. Thanks.
spiff123 is offline
