"Anamorphic" format - Mississippi Burning DVD - AVS | Home Theater Discussions And Reviews
post #1 of 3 Old 05-25-2012, 02:33 PM - Thread Starter
TODDAVS's Avatar
I hope this is the right forum for this question.
If a DVD is described to be in the "Anamorphic" format instead of just calling it "widescreen" does this mean it is really written in a 4:3 format, but has the black bars so the picture is 16:9 (or similar)?
I have a couple DVD's that when played on a wide format HDTV, show as if you are zoomed out. IE there are substantial black bars on all 4 sides.
I was looking at buying the old movie Mississippi Burning on Ebay. I am pretty sure this is out of print as they are $30 on Amazon or any other big retailer. It's $87 on Movie Mars (go figure). You can find them used on Ebay now and then, but I noticed the format label and thought I'd ask. I hate the reduced picture. If you zoom in the resolution is not so hot.
Thanks for any help.
TODDAVS is offline
post #2 of 3 Old 05-25-2012, 04:26 PM
Josh Z's Avatar
Quoted: 842 Post(s)
Liked: 640
"Anamorphic" = Optimized for a 16:9 screen.
"Non-anamorphic" = Not optimized for a 16:9 screen.
Note that this has nothing to do with a movie's photographic aspect ratio. An anamorphic disc can still have letterbox bars if the movie's native aspect ratio is wider than 16:9. However, the picture will have increased resolution and detail.
Here's an old primer on the subject:
http://www.thedigitalbits.com/articl...c/welcome.html
Those would be non-anamorphic DVDs. You need to zoom in to fill the width of the screen, but doing so usually results in crummy picture quality due to the low resolution.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #3 of 3 Old 05-25-2012, 05:35 PM - Thread Starter
TODDAVS's Avatar
Thanks, great link.
All I needed to know and then some!
TODDAVS is offline
