The METAL-HEADS thread - Page 50 - AVS Forum
 38Likes
post #1471 of 1477 Old 01-20-2015, 10:42 AM - Thread Starter
carp's Avatar
Quoted: 842 Post(s)
Liked: 665
Originally Posted by vulgartrendkill View Post
Nice thread.
I`ve been listening to a lot of technical\prog stuff of late.
Periphery, Plini, SiKtH and Destiny Potato.
Great bands all
Hey nice screen name! Of those I've only heard Periphery, I'll check the others out. Haha, Destiny Potato - must have been pretty high when they named the band.
carp is online now
post #1472 of 1477 Old 01-20-2015, 11:18 AM
SmittyJS's Avatar
Quoted: 23 Post(s)
Liked: 63
Originally Posted by carp View Post
I'll be checking out all these for sure, starting with Contradictions Collapse since you say it sounds like Justice. I've tried a few times to get into Meshuggah but I just end up getting bored and moving on.
What kind of system do you think you will have or will you use your current system? What do you have now?
I feel the same way about Meshuggah, but that album is different. I'm not saying it's anywhere near as good as Justice, but it definitely has the closest sound I've ever heard.
System-wise, I don't know what the future will hold. I've gotta design the house before I worry about that. It won't have a theater, but it will have an "entertainment" room in the basement (bar, 70" TV, etc.) - possibly soundproof, or close to it, so I can let loose with the metal. And even though I can afford more, I'm pretty cheap. My hobby is investing money moreso than consuming it. I figure I'll blow it all after I retire . I'd probably never spend more than a couple grand for L/R speakers. But I'd consider something like the KRK 10-3 (I read the GTG and lots of reviews). I have a set of JBL LSR2325 and like the idea of studio monitors - especially midfields. However, I do most of my listening now through Phase Tech 7.5 VDT towers with two Sunfire True Super Jr. subwoofers and could live happily with them. I've been in blind tests and have never heard any difference in electronics, so the cheaper, the better (I do understand the ohms, wattage and other issues when selecting the right amp). I do like the idea of an equalizer though. I read a little about the Behringer equalizer. Currently I have a couple of JVC D-class low profile receivers and a Marantz SR4600. Not sure that I'd change those, unless new technology forces my hand. I've read a little about that MiniDSP, but don't quite understand how it works. I figured I'd research it more when I was serious about a change.
On a related note, I was just searching for in-ear monitors that sound good on death metal. A lot of IEMs sound thin on death metal. I have Sennheisers now that are a little muddy. After a lot of reading (mostly at head-fi.org and its offshoots) I decided to give the Monster Turbines a try. They should arrive tomorrow.
SmittyJS is online now
post #1473 of 1477 Old 01-20-2015, 03:05 PM - Thread Starter
carp's Avatar
Quoted: 842 Post(s)
Liked: 665
Sounds like you'll have (already do with the JBL's) a very capable setup! Let me know what you think of the in ear's, I have a few pairs of headphones but nothing in ear.
Oh, I have also done a blind amp comparison and I 100% agree with you. An amp is an amp and will sound like all others unless it's clipping or broken.
One product you may want to try: a Crowson transducer. If you have tried transducers before you may think of them as gimicky, fake, etc. and I used to think that too before getting the Crowson. It works differently than the others. It's so fast and accurate and really tricks you into thinking everything you are feeling is coming from the speakers/subs. I currently have mine crossed all the way up to 200 hz for music and it's fantastic. It also saves my hearing and from annoying everyone in the house all the time because you can keep the volume lower and still get that feel. I also recently put in a near field 18" sub right behind my seat. It's great too, and the combination of that and the Crowson is awesome. If I had to pick one though I'd take the Crowson. It's expensive, but worth it.
carp is online now
post #1474 of 1477 Old 01-20-2015, 10:25 PM
vulgartrendkill's Avatar
Liked: 4
Yeah its pretty weird as band names go, but they are brilliant. SiKtH= one of the best Technical bands out there (recently reformed). Also check out the guitarist, Pin`s other band Aliases.
And thanks!! I took my two favourite Pantera albums, squished the names together and voila!!
Tannoy mercury v4 fronts, Dali Zensor 1 rears, Kef IQ2c centre with a Maudaunt Short Alumni 6 sub. Philips 47pfl6007 with 2 sided ambilight and modded firmware motion -pixel precise to pixel perfect.
Sony s760 bluray player, fat PS3, Virgin TIVO and OpenELEC 4.1.5 HTPC on a HP Microserver N54L with 4tb storage and 6gb RAM.
vulgartrendkill is online now
post #1475 of 1477 Old 01-21-2015, 06:38 AM - Thread Starter
carp's Avatar
Quoted: 842 Post(s)
Liked: 665
Destiny Potato Indifferent
Will do, I bet they are all on google play music.
My favorite Pantera album is sandwiched right in between those 2 albums, Far Beyond Driven.
carp is online now
post #1476 of 1477 Old 01-21-2015, 05:09 PM - Thread Starter
carp's Avatar
Quoted: 842 Post(s)
Liked: 665
Smitty, I'm on song 2 called Erroneous Manipulation. Me likey. I've never heard Meshuggah like this. I'm a sucker for *junt junt junt junt* rythym guitar.
carp is online now
post #1477 of 1477 Unread Today, 12:18 PM
PAVLITOS's Avatar
My best friend's band from Alexandroupolis,Greece...
PAVLITOS is online now
