Do Most DVDs Pause/Skip? - AVS Forum | Home Theater Discussions And Reviews
Old 01-01-2004, 08:45 AM - Thread Starter
Boba Debt's Avatar
I have noticed that 95% of my DVDs have a single moment where they stop for a second and then resume.
Does anyone else have this problem?
Can it be fixed?
Boba Debt is offline
Old 01-01-2004, 09:01 AM
|TF|Megatron's Avatar
Thats when it is switching layers. Can't really stop it.
|TF|Megatron is offline
Old 01-01-2004, 09:05 AM
FoxyMulder's Avatar
But u can buy certain dvd players which have a buffer built in which means u won't notice it pausing, home computers have this buffer and u never notice a pause on a home computer.
FoxyMulder is offline
Old 01-01-2004, 09:12 AM
Bionic Manaus's Avatar
If it skips more than once and you played it before, more than likely it has static electricity built up, take it out do a lite rub startng from the middle and work outwards then put back, it should work okay until you next static buildup.
Bionic Manaus is offline
Old 01-01-2004, 09:36 AM
kal
kal's Avatar
Quoted: 17 Post(s)
Liked: 76
Static electricity? This is the first time I hear of this. Should not be a problem in any home with average (45-55%) humidity levels.
Boba Debt: Slight pauses at layer change is normal. Everything else is not. Layer changes are (usually) about 1/2 way through the movie on average. The DVD reviews at www.thedigitalbits.com usually list the layer change position so you can check it out on a specific disc and see if it corresponds to what you see.
Kal
kal is offline
