Crouching Tiger R1 wont play on my ATI 7.1 player. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-05-2001, 09:22 PM - Thread Starter
Alan Gouger's Avatar
Quoted: 31 Post(s)
Liked: 57
Anyone else having this problem.
It plays fine on my windvd.
It wont even start. I cant get to the menu..
Whats this world coming to!
Ahh I sound like a mad man http://www.avsforum.com/ubb/smile.gif
Alan Gouger
Thanks for supporting AV Science.
www.avscience.com
Alan Gouger is offline
post #2 of 9 Old 06-06-2001, 03:25 AM
Frode's Avatar
Nice double post Alan..and wouldn't this be easier to get answered in the HTPC forum? http://www.avsforum.com/ubb/biggrin.gif
Anyway. Does the ATI player work for other DVDs? If not try unregistering the WinDVD filters using DVDGenie. Also see if there's a setting to choose the correct driver letter for you dvd-rom. Since I don't have access to ATI here at work though I can't exactly check. Maybe when I get home. Also try waiting. I had to wait several minutes for the R2 PAL Lethal Weapon 4 to load past a black screen for some reason, so there might be something there. If no one else has a problem with CTHD, you may just have a bad disc instead.
/frode
/frode
Frode is offline
post #3 of 9 Old 06-06-2001, 09:52 PM
robhicks's Avatar
Yep, Crouching Tigers are totally hidden here when using the ATI player as well. WinDVD to the rescue!
Rob.
[This message has been edited by robhicks (edited 06-06-2001).]
robhicks is offline
post #4 of 9 Old 06-06-2001, 10:14 PM
Larry Davis's Avatar
Alan,
It doesn't work for me either. http://www.avsforum.com/ubb/frown.gif I had to use WinDVD, instead.
Larry Davis is offline
post #5 of 9 Old 06-06-2001, 10:18 PM
MikeM's Avatar
Alan: I had the same exact problem with the ATI player on CTHD and yet it played in WinDVD. There must be some sort of flag problem on this disk that ATI has trouble reading.
Hell, I can get you a toe by 3 o'clock this afternoon...with nail polish.
MikeM is offline
post #6 of 9 Old 06-07-2001, 07:03 AM
Matt_Stevens's Avatar
Liked: 48
Strange. My CTHD plays fine on my SD1600, but not on my Toshiba DVDROM, it won't play at all. It locks up. I have the ATI AIW. Should I download this Win thingamajig? I know nothing about it.
If I install it, will it force itself as the default player?
Vimeo is the home of the Super8 Shooter...
http://vimeo.com/super8shooter
Matt_Stevens is offline
post #7 of 9 Old 06-08-2001, 05:34 PM
RobertR's Avatar
Quoted: 403 Post(s)
Liked: 563
ATI has posted about this on their web site. They say the issue is being looked into.
RobertR is online now
post #8 of 9 Old 06-09-2001, 06:30 AM
KBK
KBK's Avatar
I managed to watch it on my ATI player. This is what you do:
Go into the menu system on the ATI player when the disc is in the tray,and the ATI player is trying to load it up.(you should have a blank screen at this point).
Right click on the desktop, nd then go to title number 2, which is the preview/trailer title. Let it play, and this will then dump you into the menu that you should have been able to see in the first place.
I have never had any problems with the ATI player before, but this simple trick solved this singlular problem for me.
I suspect it will work well on all other problem discs, but hey.. I could be wrong.
goosystems.com
Ken Hotte
kbk@cyberfreak.dhs.org
[This message has been edited by KBK (edited 06-09-2001).]
Ken Hotte
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
KBK is offline
post #9 of 9 Old 06-09-2001, 12:05 PM
Ken,
I tried your fix and I couldn't get it to work. However, by right clicking on the blank window and selecting "play at specific part" and selecting "title 2", I was able to watch CTHD on the ATI player. I hope one of these fixes works for everyone.
Closed Thread Movies, Concerts, and Music Discussion
