Gladiator... DVD ROT?!?! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-15-2001, 04:49 PM - Thread Starter
minpin's Avatar
I thought something was wrong with my projector but I've determined it's my Gladiator disc. Throughout the entire movie the picture is sort of "lost". It gets kind of jiggly and flickers and then returns to normal. This happens on both layers of the disc, during loud and quiet scenes, dark and light scenes, etc. I've tested several other discs and don't see anything which resembles this behavior. I looked at the surface of the disc but can't see anything. I don't think it's a WAMO disc, but I can't tell.
Anyone else have this problem with the Gladiator disc?
Good..... Bad..... I'm the guy with the gun.
"Theater in the Thicket" dedicated build thread
minpin is offline
post #2 of 4 Old 06-15-2001, 07:25 PM
DevoX's Avatar
If there was a problem with the disc then it would exhibit MPEG bit loss... as in chunks/squarish areas scattering about in a seemingly arbitrary fashion. Thought it's not arbitrary, it's simply having problems reading portions of the image that have not changed since the last keyframe.
At any rate, if it's jiggling around or something that looks like video interference, then it's not your DVD.
-- Robert
Robert
DevoX is offline
post #3 of 4 Old 06-16-2001, 06:55 PM - Thread Starter
minpin's Avatar
Hmmm... It's a fairly new player, a Toshiba SD2150. I've watched 15 or 20 different movies without any problems so far... it only behaves like this on Gladiator. I'm going to borrow my brother's copy and see if it does the same thing.
minpin is offline
post #4 of 4 Old 06-18-2001, 08:18 AM
GMancusa's Avatar
This also happens with my original Gladiator DVD and the exchanged DVD and on two different DVD players. I don't know what it is about this DVD.
Regards
GMan
Regards
GMan
GMancusa is offline
Closed Thread Movies, Concerts, and Music Discussion
