Anyone else have this problem with The Insider? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-10-2001, 06:44 AM - Thread Starter
jafo's Avatar
Recently I purchased The Insider on DVD. Since it has an aspect ratio of 2.35, It will not fill my widescreen tv.
What is wierd is that this is the only DVD in my collection where the top and bottom bars are of unequal size. There is a huge bar on the bottom, and a much, smaller one on the top. All other DVDs in my collection with the same aspect ratio look like they should. I have a Interlaced Sony DVD player (can't remember model number) connected via component cable to a Mits WS-65807. Vertical and horizontal overscan have been set correctly.
James
jafo is offline
post #2 of 5 Old 07-10-2001, 07:14 AM
DMan's Avatar
Jafo,
Everything your doing is correct. The Insider's 2.35:1 image is just shifted higher within the 1.78:1 frame.
Enjoy,
DMan
The Academy Home Theater
DMan is offline
post #3 of 5 Old 07-11-2001, 01:19 PM - Thread Starter
jafo's Avatar
Thanks, I didn't think that I was doing anything wrong.
James
James
jafo is offline
post #4 of 5 Old 07-12-2001, 06:07 PM
cpc
cpc's Avatar
Have that DVD. Well worth the cost. Hollywood, but really good. Played ok on my Home Theatre PC. I should view it again on my Panasonic DVD player now.
cpc is offline
post #5 of 5 Old 07-12-2001, 09:30 PM
Jim Ferguson's Avatar
This is the director's preference for some reason. The Last of the Mohicans is the same way.
Jim Ferguson is offline
Closed Thread Movies, Concerts, and Music Discussion
