SW Episode 1 - Letterbox? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-08-2002, 08:12 PM - Thread Starter
vectorzsigma's Avatar
When I play Star Wars Episode I DVD on my HDTV, it gets letterboxed. I realize some movies have their format different from others, but just wondering if anyone else is having the same issue, or is it my setup?
vectorzsigma is offline
post #2 of 3 Old 01-08-2002, 09:05 PM
Mattman's Avatar
Even though your HDTV is a widescreen monitor, movies come in a variety of shapes. The black bars that you are seeing would be much larger on a 4:3 set. Star Wars (and many other blockbusters) has an aspect ratio of 2.35:1 while a 16:9 set translates to an aspect ratio of approximately 1.78:1. DVD preserves the original shape of a movie which will not always be the same shape as your tv. The more DVD's you watch, the more you'll see of this.
Hope that makes sense.
Mattman is offline
post #3 of 3 Old 01-09-2002, 09:44 AM
Homer J's Avatar
Presuming you have a widescreen TV, you should have small black bars on the top & bottom due the aspect ratio. If you are saying you have black bars on the sides also, then one of your settings somewhere, probably on the DVD player, is screwed up.
Homer J is offline
Closed Thread Local HDTV Info and Reception
