Please clarify - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-15-2002, 03:30 PM - Thread Starter
Ernie Smith's Avatar
Could one of you gurus perhaps explain this to me:
I have a front projector displaying to a 80x60 4:3 screen.
I am watching the Discovery channel and I notice the people seem to be distorted and for the heck of it, I switch to my 16:9 mode on my screen and voila!! incredible resolution-simply astounding, albeit with black bars at the top and bottom.
I do not have an HDTV STB, at least for now.
Am I not correct in that Discovery broadcasts some of their programs in the HDTV format? What am I getting then? I know it is not true HDTV because I don't have the capability yet.
I'm a no unnahstand... :confused:
Ernie Smith is offline
post #2 of 4 Old 01-16-2002, 07:55 PM
Ken H's Avatar
Discovery does not have an HDTV channel, so you're not looking at HDTV.
What is your programming source? Cable or DBS?
If DBS, what is your stb mfg. & model.
What is the mfg. & model of front projector?
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #3 of 4 Old 01-17-2002, 10:48 AM
davidmin's Avatar
What show were you watching? I have sometimes seen shows on SD channels that appear streched on a 4:3 TV, but look normal on a 16:9 TV. Cirque du Soleil for one. They're not HD , just anamorphicly stretched like a DVD.
David
davidmin is offline
post #4 of 4 Old 01-17-2002, 05:17 PM - Thread Starter
1. What is your programming source? Cable or DBS?
answer: my programming source is cable
2. What is the mfg. & model of front projector?
answer: Runco 900A
Thanks guys...I didn't think I was going to get a response
David: maybe that is the case.
Closed Thread Local HDTV Info and Reception
