West Palm Beach, FL - HDTV - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 9319 Old 12-16-2002, 10:10 AM
debsman's Avatar
Getting a full 96% signal. I live north of Okeechobee Blvd off of Military Trail, aprox 11.2 miles from towers.
I am so psyched for CSI and all my fav CBS shows in HD...and being a weather buff I love the .2 Doppler radar channel.
Kudos Guys..
debsman is offline
post #632 of 9319 Old 12-16-2002, 10:10 AM
james_h's Avatar
Hi Dave,
12:06, no signal coming through up here in South Stuart. Are you at full power?
james_h is offline
post #633 of 9319 Old 12-16-2002, 10:35 AM
Venkat's Avatar
Originally posted by ANSEK
Venkat,
What STB do you have? I have the same antenna with a Sony HD200 in Bonyton Beach (Piper's Glenn and El Clair Ranch Rd) and I can't get WPB, WFOR or UPN33.
I had Zenith 420 for a couple of weks and returned it for SIRT151. Both Zenith and the SIRT151 picked up both the stations. Zenith had problems with captioning and disabiling 480i outputs when 1080i was being used. I for got to mention that I also get the two Spanish channels (I believe 47 and 51).
Venkat is offline
post #634 of 9319 Old 12-16-2002, 10:39 AM - Thread Starter
David McRoy's Avatar
We are on at full-power now. We have been adjusting lip sync...how does it look?
We anticipate making some more adjustments to eliminate the freezing and pixelation. We sent a 10 second sample of our data stream to be analyzed by Trevini Systems and haven't heard back from them yet.
HiDefDave
WPTV/WFLX West Palm Beach, FL
David McRoy is offline
post #635 of 9319 Old 12-16-2002, 10:44 AM
ANSEK's Avatar
Dave,
The audio sync is off just a liitle. You don't notice it unless you look hard for it. The picture looks great, no pixelation. The signal strength is also very strong here is West Boynton Beach using small indoor antenna and Sony HD200.
anseK®
My DVD Collection
Format War Neutral
Panasonic DMP-BD55K
Samsung BD-P1200
Toshiba HD-A2
ANSEK is offline
post #636 of 9319 Old 12-16-2002, 10:48 AM
ElectricPickle's Avatar
Y & R looks good. It's funny that I now notice how cheesy the set looks. When they were at the airport I could tell that the arrival/departure monitors were actually photographs.
ElectricPickle is offline
post #637 of 9319 Old 12-16-2002, 11:35 AM - Thread Starter
We're still tweaking the lip sync.
HiDefDave
post #638 of 9319 Old 12-16-2002, 12:58 PM
james_h's Avatar
2:55 Just checked again - still nothing up here in Stuart.
james_h is offline
post #639 of 9319 Old 12-16-2002, 01:54 PM - Thread Starter
james_h,
Are you using a VHF/UHF antenna or just UHF? (We're on VHF channel 13.)
To All,
I continued to experience some freezing, pixelation and lip sync errors after the engineers had made some corrections. It was only after I tuned to a different channel (4-1 in this case) and then back to 12-1 that I saw the fixes. Go figure...
HiDefDave
post #640 of 9319 Old 12-16-2002, 03:02 PM
lmfgh's Avatar
Does anyone know if the silver sensor is vhf as well as uhf??
Lynne
lmfgh is offline
post #641 of 9319 Old 12-16-2002, 03:03 PM
james_h's Avatar
David,
Thanks for the hint. Of course I am using an RS double bow-tie, which does not pull in VHF.
I've tried a few VHF set top antenna's I have laying around, but the best I can do is just a trace of signal.
Guess I have to commit to the outdoor antenna now...
james_h is offline
post #642 of 9319 Old 12-16-2002, 03:05 PM
lmfgh's Avatar
I have another question which is completely unrelated.
Right now on the east coast it is 5:04 pm. Why does the time of post show 5 hours later??
Lynne
lmfgh is offline
post #643 of 9319 Old 12-16-2002, 03:26 PM - Thread Starter
You're looking at Greenwich Mean Time (GMT.) That's the time in Greenwich, England. You can go into "User CP," then "Edit Options" then "Time Offset" to select your own time zone.
HiDefDave
post #644 of 9319 Old 12-16-2002, 03:30 PM - Thread Starter
Lynne,
The Silver Sensor, pictured here: http://www.antiference.co.uk/sensor/?KeohiHDTV , is for UHF-only.
HiDefDave
post #645 of 9319 Old 12-16-2002, 03:36 PM - Thread Starter
To All,
We are discovering that the receiver at the studio is decoding fine now but that my Mitsubishi SR-HD5 ATSC receiver is still getting occasional freezes and pixelation. This is something that might be correctable via adjustments at the station, if that should prove to be neccesary.
I say "if that should prove to be neccesary" because I'm debating whether the problem might be on my end. Since I'm using a very large roof-mounted, high-gain VHF/UHF antenna (the reportedly now-discontinued Radio Shack VU-210XR, which I installed in order to get reliable reception of Miami DTV stations), allbeit with no preamp, and since I am only about 11 miles from the WPEC-DT transmitter, I'll experiment with a variable attenuator (which will allow me to selectively reduce the signal level from the antenna reaching the receiver) in an effort to determine whether my problems may be due to receiver overload. It has been documented that excessive signal level can cause poor DTV reception. A high-gain antenna close to a high-power transmitter might conceivably overload a receiver.
Over the next day or so I will test reception of WPEC-DT with my Zenith IQB64W10W ATSC receiver and my RCA DTC100 ATSC receiver in addition to my Mitsubishi SR-HD5. If I note any reception anomalies amongst these I will report them to our engineers and to all of you here.
Audio Issues: I'm still getting variable lip sync performance. We'll have to look into that, too. Also, if you are finding that your Dolby Digital decoder won't let you use Dolby Surround ProLogic and that you can only get the main front left and right channels, we are aware of it and will address this, too.
Please continue sharing your observations with us. Thanks!
HiDefDave
post #646 of 9319 Old 12-16-2002, 07:30 PM
debsman's Avatar
Update from zip code 33409:
I'm experiencing solid signal, good video but intermittent lip sync issues during Everybody Loves Raymond on WPEC. ABC 16 does the same however, but FLX 28 is fine in the sound area.
Can anybody else confirm the ABC 16.1 sound issue? I have never have the syncing right on that channel.
TIA,
GT Smith
debsman is offline
post #647 of 9319 Old 12-16-2002, 07:35 PM - Thread Starter
Well, they're running Monday Night Football right now and you seldom actually see anyone speaking in TV coverage of a football game, but I'll give it a gander. (FatVision sucks! )
HiDefDave
post #648 of 9319 Old 12-16-2002, 07:53 PM
debsman's Avatar
i totally agree. With football the syncing is not _that_ crucial :-)
I do see it during the commercials though.
debsman is offline
post #649 of 9319 Old 12-16-2002, 08:59 PM
aviators99's Avatar
Just FYI, I checked at about 7:30pm, and I was getting 73 signal strength on WFLX-DT but only 5 on WPEC-DT.
aviators99 is offline
post #650 of 9319 Old 12-16-2002, 09:06 PM
jluzbet's Avatar
Aviator,
I was getting 94 from WFLX but 0 from chanell 13
ÂNothing attempted, nothing achievedÂ
jluzbet is offline
post #651 of 9319 Old 12-17-2002, 07:08 AM
FLORA66's Avatar
I am having large freezing problems with 12-1 / 12-2. Decided last night before the football to check them out since they went live, took me a half hour to get unfroze. I finally had to switch channels from the guide. I have also had problems like this but not as bad from 39-1. My stb is a samsung t150 set at 720p. This also turns my fp xg852 into a light show, loses sync. Any ideas?
JASON
FLORA66 is offline
post #652 of 9319 Old 12-17-2002, 09:30 AM - Thread Starter
Jason,
We're still making some adjustments in an attempt to fix this. Most decoders now seem to be getting some pixelation or a very brief freeze once every few minutes or so. We'll continue to try and fix the problem.
HiDefDave
post #653 of 9319 Old 12-17-2002, 11:29 AM
lmfgh's Avatar
Since the silver sensor is only uhf can anyone recommend a vhf/uhf indoor antenna??
Lynne
lmfgh is offline
post #654 of 9319 Old 12-17-2002, 11:37 AM
ANSEK's Avatar
Lynne,
I can't recommend a VHF/UHF indoor antenna but, I have one question. Why do you want VHF? The only stations in our area broadcasting VHF would be WPLG (ABC) in Ft Lauderdale and WSVN (FOX) also in Ft Lauderdale. I am fairly confident that you would not be able to receive either station with an indoor antenna. The great this is WPBF (ABC) and WFLX (FOX) both broadcast UHF and are currently up and running.
anseK®
My DVD Collection
Format War Neutral
Panasonic DMP-BD55K
Samsung BD-P1200
Toshiba HD-A2
ANSEK is offline
post #655 of 9319 Old 12-17-2002, 11:49 AM
pogo's Avatar
...I still can't get WPBT PBS 2.1 but with all of the others who cares.
Ouch, you are missing some of the best demo loop programming for showing off your HDTV! Although I have watched every minute of WPBT 2-1 HDTV programming at least five times, I have not grown tired of seeing it. I tend to watch a few minutes, (and sometimes much more), every evening that I turn the set on. The shot on HD video is specifically designed to show the color improvement of digital and to show the resolution improvement of High Definition.
When I have folks over, the "wow" factor is definitely with the PBS demo.
(I put a $25 RS in the attic pointed 185 degrees true from west Boynton.)
I don't have sat, but I would guess that HDNet would put me in the "who cares" category for WPBT. Since I don't have it, WPBT is really the best.
pogo is offline
post #656 of 9319 Old 12-17-2002, 12:05 PM
ANSEK's Avatar
Pogo,
I have been conducting a few experiments with the location of my antenna and a small RS VHF/UHF/FM amplifier. The weird thing is I can get 2.1 at night but I can't get it during the day. At night the signal strength is in well into the "Good" range on my HD200 but during the day I can't get enough signal to receive an image. I wonder why that is? I do agree with you that the PBS demo loops are some of the best HD content around. It certainly rivals what I watch on HDNet.
anseK®
My DVD Collection
Format War Neutral
Panasonic DMP-BD55K
Samsung BD-P1200
Toshiba HD-A2
ANSEK is offline
post #657 of 9319 Old 12-17-2002, 12:20 PM
Roger Clark's Avatar
Quoted: 14 Post(s)
After reading this thread yesterday, I went home last night and scanned for new OTA stations, sure enough I now have CBS.
Dave, I am seeing the radar picture on .2 (you asked).
This is great!
BTW, I have a Sony HD100 if that matters.
Roger
System: Denon AVR-4520CI, Polk RT2000P Mains, CS350 Center, LS F/X Surrounds, SVS PC13 Ultra Subwoofer
Oppo BDP-105 Blu Ray, Toshiba HD-XA1 HD-DVD, Phase Linear 8000 Turntable, UVerse DVR.
Roger Clark is offline
post #658 of 9319 Old 12-17-2002, 01:55 PM
pogo's Avatar
I, (and a few other Boynton area folk), had to add a VHF-Lo filter to reliably get all the Miami stations. The filter eliminates the overload from the channel 5 antenna at Lantana and 441.
BTW I don't use an amp. Bought it but since I got all the stations without it, I don't use it. I have been thinking of trying it back in the line because I seem to be the only one complaining about occasional retrace lines on channel 4 Miami. I'm thinking that a marginal signal might be choking the bandwidth, but only visible at image changes with maximum data transfer.
If you need the filter specifics, start here:
http://www.avsforum.com/avs-vb/showt...236#post910318
and note the different part numbers in my post a few messages down:
For anyone contemplating building the filter, the combiner/splitter RS Cat.# 930-0061 David listed may be an online order number only, but the store has a 15-1237 ($9.99) which exactly fits the spacing of the VHF-Hi and UHF ouputs of the three band splitter, and the 75-Ohm Coax "F"-Type Terminator needed is Cat. # 15-1144.
pogo is offline
post #659 of 9319 Old 12-17-2002, 02:47 PM - Thread Starter
ANSEK,
We (WPEC-DT) are broadcasting on VHF channel 13, remapped to 12-1 and 12-2.
HiDefDave
post #660 of 9319 Old 12-17-2002, 04:47 PM
George33027's Avatar
What is the range for ch. 13 ?
George33027 is offline
