Thank You - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-23-2002, 05:20 PM - Thread Starter
jtm1471's Avatar
Just wanted to thank everyone for all of the great information and advice. I just had a Winegard 7020 antenna and Samsung SIR-T150 connected to my Mits. 55857. I just finished programing my Pronto remote and I am all set for a night of digital tv viewing.
FYI, I am in Chicago about 25 miles from the transmitters and seem to get all digital stations broadcasting at about 50%, including CBS. I have not been in front of the set long enough to notice any audio or video drop outs, or audio synch problems, but I am keeping my fingers crossed.
Now it is just a matter of getting Jim Burns out here to calibrate the set.
Thanks again.
JT
jtm1471 is offline
post #2 of 5 Old 01-24-2002, 09:41 PM
tmmdp's Avatar
Hello JT, I am in Bartlett IL aand I was thinking of getting the Stealthtenna by channelmaster. I was wondering how you liked your winegaurd antenna? Thanks.
tmmdp is offline
post #3 of 5 Old 01-25-2002, 07:56 AM
Jim Burns's Avatar
Give me a call. I am ready! 773-467-0640
Jim Burns
cheap does not mean value
Jim Burns is offline
post #4 of 5 Old 01-25-2002, 09:14 AM - Thread Starter
jtm1471's Avatar
tmmdp,
I think the antenna is good, I am just not so sure about the installers. It just went up Wednesday and I have not gotten any signal strength greater then 50%. I do not have drop outs or pixelation to speak of on any station so I can't complain.
If the weather is as good as they say this weekend, I may venture up to the roof to take a look at if the antenna is aimed properly and how they are gounding it.
Like I say though, the combo of the Winegard antenna and the Samsung T150 are so far working great.
jtm1471 is offline
post #5 of 5 Old 01-28-2002, 11:06 AM
tmmdp's Avatar
Thank you JTM.
tmmdp is offline
Closed Thread Local HDTV Info and Reception
