Cleveland, OH - HDTV - Page 140 - AVS Forum | Home Theater Discussions And Reviews
 332Likes
Old 08-16-2014, 02:46 PM
JJkizak's Avatar
Quoted: 107 Post(s)
Originally Posted by CleCakYngMfd View Post
I just checked. Ah, there it is, with a signal from WUAB of 90 on my converter box. (Just saw the WUAB ID at about 10:03pm)
GritTV Coming Soon
It also says 480i 16 x 9.
JJK
JJkizak is offline
Old 08-16-2014, 10:43 PM
Liked: 0
Sorry I didn't let you all know sooner, but I got an antenna from Monoprice and now I not only get 61-3 but about a dozen others!! They had an offer of $5 off first purchase of $25 so I got a VGA splitter which I needed - exceptional quality. Very cool - I am glad I didn't pay TOO much attention to the reviews on this antenna:
ellym is offline
Old 08-17-2014, 07:05 AM
JJkizak's Avatar
Quoted: 107 Post(s)
Remember this: We used to use coat hangers.
JJK
JJkizak is offline
Old 08-17-2014, 10:09 AM
Commodore 64's Avatar
What's the deal with Channel 8, Fox (21 UHF). I can't seem to get it. I get all of the other stations from that azimuth, but not Fox 8. Is their power weak? I picked up 45 stations with the wineguard box: http://www.amazon.com/Winegard-FL655...=cm_cr_pr_pb_t
I also have a 2-bay UHF flyswatter, that I could try as well. Anyone else having trouble picking up Channel 8? (UHF 21).
Commodore 64 is offline
Old 08-17-2014, 10:39 AM
snowdog 88's Avatar
Quoted: 622 Post(s)
Liked: 69
That's a repeater for WJW's full power signal, serving the Alliance area. However, 21 along with 46 (serving the Lake Milton area) are not yet built. Both have been listed on the FCC's site with a construction permit for ~3 years now. The reason WJW hasn't installed the repeaters is probably due to the uncertainty of moving back to RF 31, which would provide better coverage in the area served by the repeaters.
Newer is not always better.
snowdog 88 is offline
Old 08-17-2014, 11:52 AM
So is 8 still VHF then (from Cleveland)? Crap, I thought everyone had to go UHF. I just put my big old VHF antenna out on the treelawn and someone already came and got it!
I can't get wjw at all, and it's coming up on football season.
Question. Which should be better, a UHF 2 bay flyswatter or the Wineguard box linked above?
Also, I have a few splices in my RG6, I repurposed the cable from a satellite dish. If I make 1 long continuous run will that materially affect signal strength. In other wards, is there insertion loss for one of those inline connectiors?
Hmm. I tried the 2 bay flyswatter, it's about the same. I get no RF 8 with it. I'm about 23 miles from the transmitters in Cleveland according to antennaweb. The wineguard is supposed to be VHF/UHF: http://www.winegard.com/get-free-tv/.../flatwave-air/
Old 08-17-2014, 01:55 PM
snowdog 88's Avatar
Quoted: 622 Post(s)
Liked: 69
You may want to take a look at this antenna. It is capable of hi-VHF (7-13) and UHF. It's compact and has plenty of good reviews...
http://www.amazon.com/RCA-ANT751-Dur.../dp/B0024R4B5C
It's also important to position the antenna away from nearby trees and other buildings if possible. They can degrade reception and create multi-path issues, especially with VHF.
Inline couplers shouldn't affect signal strength. Use of cable splitters will, especially cheap ones found at dollar stores. If you installed new connectors on your cabling, make sure they are clean and the shielding isn't making contact with the center wire.
Old 08-17-2014, 03:24 PM
I have this: http://www.solidsignal.com/pview.asp...uctInformation
About the same as the wineguard. No WJW .
(I just ran new cable from the roof, too, no inline connections)
I have a lot of trees, and am a little bit in a valley, antenna is on the roof of my two story house on a 12 foot pole. Multipathing is an issue, I reckon, but I get like, 0 signal on WJW.
Old 08-17-2014, 08:52 PM
CleCakYngMfd's Avatar
Quoted: 807 Post(s)
Liked: 250
I have this (antenna) : http://www.solidsignal.com/pview.asp...uctInformation
Pay real close attention when you come upon consumer antenna reviews. A high-average rating can be misleading. Each person's setup is quite variable, ranging from being next to the tower to the deepest fringe - let alone non line-of-site objects. Hey, a paper clip or coat hanger can get great reviews - but not at 23 miles out downhill.
Forget about the small, squarish 'Flatwave' antennas or anything of the like if you are 15+ miles out, IMO. That 60+ mile range is clear, line of site. Maybe this works in Oklahoma or Texas, but not around here. With antennas, size matters. Better to have a larger signal capture surface for all-weather signal stability (wet or snow or ice on the antenna can be a problem for borderline signals). IOW, you want more than just enough signal. You want 'reserve capacity' signals levels to overcome objects and weather changes.
That antenna from Solid Signal lists the VHF at 15 miles (UNOBSTRUCTED). Meaning, at your valley-tree location, this '15-Mile' antenna for VHF is now less than that.
I have reservations about that RCA antenna. How wide is the beam width? It might work getting RF8 and RF10, but would you get all the UHF stations satisfactorily in a one-direction aim? Maybe this antenna will work with a preamp.
I would suggest one of the Antennas Direct Long Range models (myself, I would add a preamp), like the ClearStream 2V. Most of these ClearStream antennas have wider beam widths (less critical aiming, especially with a preamp).
Community Reviews Search Result of 'VHF' with the Winegard FL6550A FlatWave Outdoor Antenna:
http://www.amazon.com/gp/community-c...sin=B00E5Z3R6A
Community Reviews Search Result of 'VHF' with the RCA ANT751 Compact Outdoor Antenna:
http://www.amazon.com/gp/community-c...5C&sort=rating
Note: I am not an expert - I know just enough to be dangerous.
Last edited by CleCakYngMfd; 08-29-2014 at 07:37 AM. Reason: Changed Quoted Text Color
CleCakYngMfd is offline
Old 08-18-2014, 08:04 AM
Sigh...
I'll give it a shot. You think that antenna is better than that solid signal for VHF? I get UHF pretty well with it, grabbing channels from 40+ miles away, just can't get the darned FOX affiliate from anywhere!
Also, years ago when everything was VHF, I used a HDHomerun. This time around I'm just using the built in rtuner on my LG 50" inch plasma. It's an older TV (great picture), but definitely was a budget item. Any feel for how much the ATSC tuner affects? Back in the day, multipath was such an issue that Vbox and HDHomerun were the only tuners that would work with my rig, they seemed to have good multipath rejection.
Also, do you think I could just use the preamp from the Wineguard box? It's a powered 5v inline connector.
Where are preamps best mounted? My antenna is outdoors, on the roof, so I hooked the preamp up (as instructed by wineguard) near the TV, indoors.
Looking at this preamp, https://www.antennasdirect.com/cmss_...structions.pdf, I'd need to put it indoors, right?
Old 08-18-2014, 09:27 AM
Quoted: 807 Post(s)
Liked: 250
Where are preamps best mounted? My antenna is outdoors, on the roof, so I hooked the preamp up (as instructed by Winegard) near the TV, indoors.
Yes, the ClearStream2V should easily outdo the Solid Signal for Hi-VHF - because the Solid Signal antenna is a UHF-only antenna. Some manufacturers will advertise that their UHF-only antennas will pick up Hi-VHF. This is true, provided that you are close enough that the VHF signal is quite strong. No doubt this why Solid Signal listed the VHF range for that antenna at ONLY 15 miles. That would be line-of-site 15 miles - - - no hills, no trees, nothing in the way except the atmosphere.
Given your situation and your described location, I would pull out the heavy artillery and get a Long-Range, High Gain VHF antenna:
http://www.amazon.com/Antennas-Direc.../dp/B002E1UNWS
That baby will suck in Channel 8 for ya. This antenna will get UHF at 35+ miles. Then later, if needed, you can add a preamp.
Speaking of a preamp... If needed, you want to mount it AT THE ANTENNA. Not at the TV. Remember, amps are at the TV, PREamps are at the antenna (and its power supply would be near the TV, of coarse).
If Winegard said to place it at the TV, are you sure it was not an amp? I'd be surprised if they would say mount a PREamp at the TV.
Your antenna coax is of a quality shielded RG6 type, yes?
Some research would be needed to see what quality and sensitivity ratings for today's digital tuners, however, it's pretty much a moot issue when having a good to strong signal reaching the tuner.
Amazon Search - Long Range VHF Antenna 4-Stars and up.
Name:	ClearStream5 - Large.jpg
Last edited by CleCakYngMfd; 08-29-2014 at 07:35 AM. Reason: Added Photo / Changed Quoted Text Color
Old 08-18-2014, 10:15 AM
snowdog 88's Avatar
Quoted: 622 Post(s)
Liked: 69
Grit is up on 43.3 as well as Escape on 61.4. Both networks seem to have occasional pixelization/shuddering. 43.3 is transmitting Grit in 16x9. Will 61.4 do the same for Escape? (4x3 letterbox)
Does anyone know if WTOL lit up their .3 for Grit? I caught WTOL last night but there was no .3, can't get them as of now. Did they wait for the last second to light it up?
EDIT: Audio encoding needs to be looked at on 43.3. My main HDTV has no audio but the Zenith DTV converter box is fine.
Old 08-18-2014, 10:39 AM
Bismarck440's Avatar
Quoted: 756 Post(s)
Liked: 143
Strange, as 43.3 was showing the blank picture over the weekend, my Zenith 901 allowed me to adjust the Zoom on the sub something you really cannot do on the subs.
http://www.amazon.com/Antennas-Direct-C5-ClearStream-Digital/dp/B002E1UNWS
If you read the reviews one is from Texas (gee no wonder it works) & they claim this is a VHF only antenna. Reason why I detest online purchases, the link first took me to Wal*Mart.com, when I copied it took me to Amazon ???????
23 Miles, no Fox affilate in Ytown? I'm 29 miles although I still have issues with 8, but no repeater up here, my problems due to the ridge with 8 & from CFPL with 19 (RF10)
Wonder how well that thing works in an attic?
Edit the Wal*Mart Link claims it's UHF/VHF & Amazon & the Manual says VHF... ahh the wonders of the internet & buying dot com!
Bismarck440 is offline
Old 08-18-2014, 11:42 AM
Michael P 2341's Avatar
Quoted: 173 Post(s)
Liked: 24
Yes there is a FOX in Youngstown and there are 2 ways to get it. In HD on WYFX-LD Rf Ch 19 (low power digital) or in SD on WKBN 27.2 (Rf Ch 41). I get Rf 41 here in Parma with an indoor Silver Sensor most days. Being on high ground plus WKBN-DT's phenomenal coverage area makes it possible. I call my reception of WKBN-DT a "poor man's Sunday Ticket" as there are times when WKBN/WYFX show different games than the Cleveland stations. Also WKBN is a good substitute for WOIO for CBS if you are having issues with their Rf Ch 10 signal.
Michael P 2341 is offline
Old 08-18-2014, 03:59 PM
https://www.antennasdirect.com/store...V-antenna.html
Try that link. I'm about to pull the trigger as a last ditch effort.
Old 08-18-2014, 07:01 PM
Quoted: 807 Post(s)
Liked: 250
What the Crap? These two new channels had all this time to be ready and we get this crap? AssCape is squishing the image. What?
Grunt's 'shuddering' is ugly. Is this 43's problem?
I hafta use the Anamorphic setting to get the image to look right on Grunt.
Last edited by CleCakYngMfd; 08-29-2014 at 07:34 AM. Reason: Changed Quoted Text Color
Old 08-18-2014, 07:19 PM
snowdog 88's Avatar
Quoted: 622 Post(s)
Liked: 69
HAHAHA!!! Your post made me laugh!!! I noticed that too. What's the point of presenting in widescreen when all they're going do is stretch a full frame picture? Would have been better off to transmit the picture in 4x3. Clearly the network is doing this and not the affiliates.
43.3 apparently has an encoding issue to work out. My main HDTV can't decode the audio at all. I notice some light shuddering in the picture too. Sounds like your TV can't handle it correctly and is throwing fits.
Old 08-19-2014, 12:38 AM
Quoted: 807 Post(s)
Liked: 250
Thumbs down GripeTV and AssCape - You have Got to be Kidding!
Well that's nice. See - I did something right.
Now let's see if AssKew and Get-a-GripTV can get something right.
I get GruntTV's audio alright from my DigitalStream CB, but not via my HD DVR! The 4x3 John Wayne movie fits the main TV ok, via the screen setup in the DVR. I did not have to change anything there.
I'll check later this morning and see, and maybe 'hear' what's going on then.
Old 08-19-2014, 07:34 AM
Quoted: 807 Post(s)
Liked: 250
I noticed that when I first tune to GruntTV with my DigitalStream converter box, the audio does not appear until about 10 seconds later.
Old 08-19-2014, 08:49 AM
Quoted: 756 Post(s)
Liked: 143
Now, now.... not like we are paying for these like Pay TV & Cable.... be nice or free TV will go away!
I find on my 4:3 set I have to use the Squeezed setting on the Zenith 901 to get a good ratio (the Grit Logo then appears squeezed .. np), on Escape I have to use the sets setting to a 4:3 Expand (which removes some of the black bars).... Strange though I can't change ANY Ratios on the Subs on the Zenith 901 except for Grit. Note there is a few second delay when tuning to Grit & Get
I have yet to see either of these on my Widescreen, theough the Westinghouse labeled Grit as 'Bounce 43.3), had to manually change it.
Old 08-19-2014, 09:00 AM
Quoted: 807 Post(s)
Liked: 250
Well, it is first and foremost a VHF antenna with UHF capabilities. See the attached images with descriptions from Amazon, Antennas Direct, and WalMart.
Hmm. The 'Amazon' link should have taken you to Amazon. I have no idea how it would take anyone to another site.
(A) Works great in the attic.
(B) Works terrible in the attic.
Person (B) lives much further away from tower(s).
Edit: the WalMart Link claims it's UHF/VHF & Amazon & the Manual says VHF... ahh the wonders of the internet & buying dot com!
See the attached images with descriptions.
Name:	ClearStream5 - Site Descriptions 1-of-3.png
ID:	219154   Click image for larger version
Name:	ClearStream5 - Site Descriptions 2-of-3.png
ID:	219162   Click image for larger version
Name:	ClearStream5 - Site Descriptions 3-of-3.png
Last edited by CleCakYngMfd; 08-29-2014 at 07:32 AM. Reason: Changed Quoted Text Color
Old 08-19-2014, 09:26 AM
Quoted: 807 Post(s)
Liked: 250
Hey, Crap is Crap - whether it is paid for or free.
During a break on GruntTV, I noticed some properly formatted images when I had my CB set to 16x9, yet when Get-a-GripTV goes back the movie, it is vertically squeezed.
Yes, this is the first time I was able to change the format on a sub-channel. They all should do that.
Last edited by CleCakYngMfd; 08-29-2014 at 07:31 AM. Reason: Changed Quoted Text Color
Old 08-19-2014, 10:01 AM
Quoted: 756 Post(s)
Liked: 143
I'm removing the HTTP, disabling the link, I think it's 'adchoices' playing tricks here... I see Wal*Mart Within, but one time on Here it was an Amazon link??
viglink.pgpartner.com/rd.php?r=814&m=799168095&q=n&rdgt=1408293651&it=14 08725651&et=1408898451&priceret=139.99&pg=~~3&k=72 224d0f324f6e5a5d81ab31a5aadbc3&source=feed&url=htt p%3A%2F%2Fc%2Eaffil%2Ewalmart%2Ecom%2Ft%2Fcsepg01% 3Fl%3Dhttp%253A%252F%252Fwww%2Ewalmart%2Ecom%252Fi p%252FAntennas%2DDirect%2DC5%2DClearStream%2D5%2DE xtreme%2DRange%2DUHF%2DVHF%2DDTV%2DAntenna%2Dwith% 2DSignal%2DCombiner%252F26964144%253Fwmlspartner%2 53Dpricegrabber%2Ecom%2526affcmpid%253D268830291%2 526tmode%253D0000%2526veh%253Dcse&st=feed&mt=~~~~~ ~~~n~~~
I find this less offensive & annoying than some of the content piped in by Crime Warner 70 channel package cable on Widescreen TV's.... & people actually pay for this ... & They are WILLING to pay even more!
Agree, I thought the not being able to adjust subs was a limitation of the Zenith 901... guess not.
Old 08-19-2014, 10:43 AM
snowdog 88's Avatar
Quoted: 622 Post(s)
Liked: 69
43.3 is transmitting in 16x9. That's why you are able to change the aspect ratio on your Zenith converter box. Bring up the info screen and it will say 16x9.
Old 08-19-2014, 07:18 PM
Quoted: 807 Post(s)
Liked: 250
Oh my! Link hijacking! That dreaded 'VigLink'! I had navigation difficulties with that stinking VIGLINK crap!
All I put up was a direct link to Amazon. How that gets 'hijacked' into taking you to Walmart is cRaZy!
Just one more reason why I switched to FireFox and installed the Add-On, "AdBlock Plus" program.
I wonder if it is just at your end or what may be here on the forum. I think it could be at your end.
I downloaded a video capture program (FreeCorder) some time back, and it put that VigSTINK link redirection program on my system. It really slowed down my Internet navigation.
I think Avast AntiVirus lists Viggy as maleware or something.
I'm not sure, but maybe AVSforum has a tie-in to VigSTINK? "Vig" as in 'Vigorous'. Indeed. It is very aggressive.
This is the Amazon Link I posted:
Last edited by CleCakYngMfd; 08-29-2014 at 07:28 AM. Reason: Changed Quoted Text Color
Old 08-19-2014, 09:06 PM
Quoted: 807 Post(s)
Liked: 250
Ok, a John Wayne movie just ended on GrimeTV and it looked fine in 16x9. I guess movies that are not widescreen are being forced (stretched) into the 16x9 format, like the now running B&W movie that just started as I'm typing this. At least I have some control on how to view it: The Anamorphic setting seems to look ok. The 14x9 setting chops off some of the left and right image.
The 'Grit' logo/ID should be translucent. I do not like in-your-face, solid, bold and/or colored 'bugs' sitting on the picture. It has gotten worse over the years. Some of them are quite large, too.
GruntTV still is doing the Shudder-Stutter dance.
Last edited by CleCakYngMfd; 08-19-2014 at 09:08 PM. Reason: Because I wanted to, that's why.
Old 08-20-2014, 03:49 AM
toby10's Avatar
Quoted: 29 Post(s)
Liked: 24
These the links in question?
Both links correctly take me to Amazon, not Walmart.
toby10 is offline
Old 08-20-2014, 05:20 AM
wd8kct's Avatar
Quoted: 78 Post(s)
Work OK here... Ed
wd8kct is offline
Old 08-20-2014, 07:30 AM
Quoted: 807 Post(s)
Liked: 250
These the links in question? Both links correctly take me to Amazon, not Walmart.
Originally Posted by wd8kct View Post
Works OK here... Ed
I just checked this page with ABP disabled on the AVSforum site and checked the links in 'Page Info' (with FireFox 31).
I did not see any VigLink links at this point, so perhaps he may have it from a software install like I did at one time.
Last edited by CleCakYngMfd; 08-29-2014 at 07:27 AM. Reason: Changed Quoted Text Color
Old 08-20-2014, 07:40 AM
nsa1062's Avatar
Quoted: 126 Post(s)
Liked: 26
On my Sony, the audio on "Grit" is at least 1/2 second out of sync with the video.
nsa1062 is offline
