Cleveland, OH - HDTV - Page 151 - AVS Forum
 26Likes
post #4501 of 4516 Unread 12-19-2014, 10:34 AM
Bismarck440's Avatar
Quoted: 122 Post(s)
Liked: 25
Originally Posted by Dexterryu View Post
He basically determined that it was interference and not signal strength. Beyond that he couldn't tell. He suggested I contact the FCC (which I have) to report the interference. He suggested that it could be anything from someone broadcasting via a ham radio to a business using handheld radios. Both of which the FCC would shut down if they were indeed the cause of the interference.
Joel was reluctant to recommend getting a rotor or a filter. He basically said that both were a crapshoot unless we knew exactly what the cause was. He said the filter was more of a sure thing, but those have to be made to filter out the specific interference.
I asked him about an amplifier, but he also said that wouldn't help since the signal strength wasn't the issue.
Was curious what type of antenna Joel set you up with, & are you close to Rt 2? (from your description would place you a bit north of 2 between 306 & LN), possibly interference from traffic? My friend in Chesterland gets a lot of Truck/Semi Traffic that sees to knock the signal around when they pass her house (of course she is also using an indoor at road level), was going to suggest she call the Antenna Man II.
So this is constant? My issues with 19 seems to come & go..
I'm using a small Amp for my attic antenna, & was really unsure what kind of amp was on the Outdoor Antenna (when it was still functional)? I used to get better results out this way with the Amp.
Still think it's a nominal signal coupled with CFPL interference.
Correct, I can't see throwing too much $$ after this either especially when I'm suppose to have access to a common antenna maintained by my HOA, that pay for anyway. - & me thinks the HOA will have an installed antenna (by me or otherwise) to be removed & destroyed when the place is reroofed in a couple years.
Bismarck440 is offline
post #4502 of 4516 Unread 12-19-2014, 10:47 AM
snowdog 88's Avatar
Quoted: 77 Post(s)
The lines are not 100% of the time. They appear about 1-2 seconds at a time, then are gone for 5-10. Sometimes it's 1-2 lines, other times it's much more significant.
CFPL from London, Ontario is likely causing the interference since they and WOIO share the same RF channel. The lake allows CFPL's signal to travel farther due to the flat terrain. WOIO also transmits less power towards that area in order to protect CFPL, making the problem worse. Viewers who live on the east side near the lake typically experience problems receiving WOIO due to CFPL's interference.
You mentioned that the "lines" disappeared when the installer was by the antenna. He was probably absorbing the CFPL interference, effectively nulling out the station.
HD Radio: An Audiophile's Worst Nightmare.
snowdog 88 is online now
post #4503 of 4516 Unread 12-19-2014, 10:51 AM
Dexterryu's Avatar
Quoted: 18 Post(s)
You have the location almost exactly. Yes, just north of Rt 2 and between 306 & Lost Nation.
The issue come and goes. Yesterday morning before I left for work (6am) it was perfect for 20 minutes or so I watched it. By the time I got home, it was pretty bad. By 9pm, it was tolerable. Sometimes it's a line here and there which is tolerable. Others it's all over the place. It's weird in that the parts picture that don't get lines are still clear.
Mine is probably close to 25-30' in the air since my house is pretty tall. One of the things we did was we actually switched to a smaller, less powerful antenna and that did seem to help. Joel's theory was that it might be less sensitive and pick up less interference. This did help significantly, but at the times when the interference is more persistent it's still bad.
Dexterryu is online now
post #4504 of 4516 Unread 12-19-2014, 10:59 AM
snowdog 88's Avatar
Quoted: 77 Post(s)
Originally Posted by nsa1062 View Post
And don't forget lightning - when WKYC was on RF2, if there was a thunderstorm within 50 or 100 miles, the reception would always be a constantly freezing and pixelating mess.
Also summertime E-Skip would frequently wipe out reception completely.
I was one of the lucky ones that was able to receive WKYC's digital RF 2. The signal was solid most of the time, but flipping on a light switch or turning on an appliance often made the picture go bananas. Every time the dryer beeped, the picture would lightly break up. I found it funny how an alarm could screw up the reception.
For me, WOIO and WJW break up during a thunderstorm, but the lightning has to be very close to my house.
post #4505 of 4516 Unread 12-19-2014, 11:00 AM
Dexterryu's Avatar
Quoted: 18 Post(s)
I have a feeling my wife is going to think I'm crazy now. I'm going to have to go home tonight and try watching with various lights/electronics on now.
post #4506 of 4516 Unread 12-19-2014, 11:11 AM
Quoted: 122 Post(s)
Liked: 25
My antenna was installed on a 2 story unit, & believe Joel had installed it &/or at least serviced it at some point. It was suggested by a few in other fourms here I "take control" of this antenna for my own since they don't want to upkeep it, but they don't believe OTA exists anymore.
Did Joel even remotely suggest what Snowdog & I are saying? this interferences seem to peak during the solstice times (mid June/December), but I note it more here in the summer/early fall.
Kind of wonder if the FCC could help on my issue if my feed line was indeed cut, the HOA cleverly changed some of the bylaws to have Building Television Cable listed as a "utility" & no longer a part of common/limited common, as they basically invited the Cable company in to do as they please with building wiring.
Snowdog, Lightning/rain also effiects 25 & 55 here too.
post #4507 of 4516 Unread 12-19-2014, 12:09 PM
Dexterryu's Avatar
Quoted: 18 Post(s)
Joel did not mention anything regarding time of year. He did say that the possibility of having less interference during the spring/summer/fall months due to leaves on the trees potentially weakening whatever it is that is interfering.
I'm not sure if the FCC can\will help you. There is quite list of things they can help with. It's an online form that you can fill out. Here is the link: http://www.fcc.gov/complaints
post #4508 of 4516 Unread 12-19-2014, 12:40 PM
Quoted: 122 Post(s)
Liked: 25
Nothing about refusal to allow antennas, that would be covered by OTARD. yours would fall under signal issues/DTV issues...
Broadcast (TV and Radio), Cable, and Satellite Issues Details
  • Obscene or indecent programs
  • Unlawful or illegal advertising
  • Disability access
  • Emergency alerts
  • Unauthorized/unfair/biased/illegal broadcasts
  • Cable modem or signal issues
  • DTV issues
  • CableCARD issues
  • Loud Commercials
Joel is down from the Medina area, I thought the Antenna Man might be more aware of the reception issues to the east.
Would think he (Joel) would be familiar with it, the reception with the common antenna here was actually great for the most part, too bad they did not want to upkeep the system.
You wouldn't think that interference would be coming over the freeway either from Machinery over on Industrial Park on the south side of 2?
post #4509 of 4516 Unread 12-19-2014, 12:44 PM
Andrew K's Avatar
Quoted: 43 Post(s)
There is a good chance that it could be interference from CFPL across the lake. I remember back in the analog days, it didn't take much for CFPL to make it into Lake and Cuyahoga Counties like it was local. I know that communities that surround Lake Erie are more prone to tropospheric ducting than inland locations like Akron. I just remember driving back from Lorain one night when I was receiving 102.5 from Buffalo just like it was local, but yet there was almost no trace of tropo activity when I got back to Akron. If it's CFPL, then I don't think there's anything you can do to completely get rid of it. You can try to minimize it by reaiming the antenna with a rotator to null out CFPL.
Andrew K is online now
post #4510 of 4516 Unread 12-20-2014, 06:03 AM
greenpjs's Avatar
Don't get your hopes up regarding the FCC shutting anybody down. That would be true if the ham or business was transmitting illegally (i.e., outside their licensed frequencies or will higher power than allowed) but that is almost never the case. Usually the problem is with the TV being overloaded by legal signals that it receives even though they are not on the TV channel being watched. When that is the case, the FCC can't help. If the source of the signal can be found, a filter can be used to keep the TV from being overloaded, but doing so is never easy. Good luck.
Pat
greenpjs is offline
post #4511 of 4516 Unread 12-20-2014, 08:55 AM
nsa1062's Avatar
Maybe check the signal-strength meter on your TV when you are having issues with WOIO.
If the interference is caused by CFPL, then the signal strength (actually a bit-error reading) of WOIO will just appear lower than it should, but it should be steady over an hour or so.
If it is caused by a ham or other sporadic interference, then you should see the signal strength changing suddenly as the interference comes and goes.
Hey guys, I recently cut the cord and went with an over the air HD antenna. I had it professionally installed by Cleveland Antenna. Overall, I'm very happy with the service provided and effort. That said, WOIO is giving me problems. All other channels are crystal clear.
WOIO (19.1 on my tuner) comes in clear, but frequently gets lines and garble. Sound is always fine. This issue comes and goes. Sometimes it's perfect and other times it's nearly unwatchable. Cleveland Antenna spent about 2 hours troubleshooting the issue with that channel.
I live in Willoughby, and I know that there is well documented issues with WOIO in this area. That said, the installation guy, Joel, said that signal strength was not the problem. He stated that his readings where showing sporadic interference, however he wasn't able to determine what or how to fix it.
His suggestions on a long term fix were to either get a rotor so the antenna could potentially be turned away from the interference or potentially had a filter made. He said that because he couldn't determine the source of the interference, that both options were far from a guarantee.
I'm hoping someone here has had similar issues and could provide more information and/or a solution.
nsa1062 is offline
post #4512 of 4516 Unread 12-20-2014, 10:11 AM
Dexterryu's Avatar
Quoted: 18 Post(s)
I have, and it's very interesting.
3, 5, 8, 25, etc... all sit at 100%. Some of the Akron stations are at like 65% and perfectly watchable.
19.1 (WOIO) and 19.2 the number is eratic. It's flapping between 100% and 80%. So it will go 100, then 84, then back to 100, then to 80... etc...
I spoke with my dad on this too, and he's been an Antenna guy since the 80's. He has a friend that lives within a 1/4 mile of me, is closer to the lake & airport and is NOT having the issue. So our theory right now is that there is someone very nearby messing around with some sort of radio.
post #4513 of 4516 Unread 12-20-2014, 04:47 PM
Commodore 64's Avatar
Originally Posted by Commodore 64 View Post
The wineguard is supposed to be VHF/UHF: http://www.winegard.com/get-free-tv/.../flatwave-air/
Parts-express has a $35 UHF-VHF antenna: http://www.parts-express.com/antop-v...tenna--210-512
So I took a flyer on it because I can't get Fox or CBS from Cleveland with the wineguard above or UHF flyswatter. I'm happy to say that the antenna linked above gets every Cleveland station for me. 23/25/49/27 (youngstown) all come in to. Can't beat the price.
Signal strength is "good" according to my TV for ALL of them.
Signal is split once (runs to two TVs). No preamp/amps of any kind.
Commodore 64 is offline
post #4514 of 4516 Unread Today, 07:22 AM
Quoted: 122 Post(s)
Liked: 25
$34, (Online only??), & you're how far from the farm?.. & this includes 8 & 19?
post #4515 of 4516 Unread Today, 09:03 AM
Dexterryu's Avatar
Quoted: 18 Post(s)
So I got an update from Joel (my installer).
Here is the email he sent regarding Channel 19 issues:
We ended up using a modified UHF/VHF combination antenna. Antennacraft manufacture's our antennas for our channels. It has high rear rejection so it concentrates more on what it is looking at instead of whats behind it.
Ch 10 is shared with a Canadian station, but that is not what is causing the issue. It would be constant not intermittent. Again my meter shows interference, but not from the same station.
So... I guess the question is since it's not a signal strength issue and not the Canadian channel 10. Does anyone have any suggestions on how to fix this or minimize it?
post #4516 of 4516 Unread Today, 10:31 AM
snowdog 88's Avatar
Quoted: 77 Post(s)
The rear rejection may only apply to UHF since that part of the antenna needs to point towards the towers for a solid signal. WOIO broadcasts digitally on VHF channel 10. A VHF antenna is typically less directional and turning your antenna around would result in similar reception of WOIO. I can receive WMFD/68 (VHF 12) from Mansfield at times, and my outdoor antenna is not even pointed in that direction.
I'm pretty sure the problem is with CPFL. Compare the coverage maps of WOIO and CPFL. Even through you may not be in CPFL's coverage area by the shore, all it takes is a slight change in the weather for their coverage to amplify and interfere with WOIO.
