Cleveland, OH - HDTV - Page 180 - AVS | Home Theater Discussions And Reviews
 119Likes
post #5371 of 5394 Old 05-04-2015, 08:57 PM
CleCakYngMfd's Avatar
Quoted: 138 Post(s)
Liked: 36
Originally Posted by Trip in VA View Post
a) TV stations can't enable or disable aspect ratio adjustments.
b) ...the transmission is flagged as 4:3 ... thus the box has disabled it.
c) WEWS flags the transmission as 16:9, you now can adjust it ...
d) Again, this is in the box and not the station.
- Trip
All I know, is when I add a+b+c+d and mix it in a blender, it comes out to someone/something controls the BOX to say I CAN adjust the ratio or I CANNOT. 'c' tells me the station or nutwork is doing the flagging to my box thus, indeed something upstream is the controller, not strictly the box, yes/no?
- Pj
Vizio P-Series - 2014 P502ui-B1E (50") TV, Firmware: 1.1.19. Win7 Pro and FireFox 37.0.1, Desktop.
Other Equipment: ClearStream-4 connected to dying DTX9950 to Composite-In of Philips 3576H; local CableTV to RF-In - connected to 2nd-time boards-replaced Philips 19PFL3403D (See www.BadCaps.Net - Poorly made caps).
CleCakYngMfd is offline
post #5372 of 5394 Old 05-04-2015, 09:05 PM
Quoted: 138 Post(s)
Liked: 36
Originally Posted by snowdog 88 View Post
I don't think using a DC power adapter in place of the power supply would work since the main board likely requires more then one voltage, or rail, much like a motherboard inside a desktop computer.
You would have to use resistors to drop the voltage down to the correct value for each of the rails. Otherwise you can fry the unit and render it inoperable by providing the lower powered rails too much voltage.
How precise must the voltages be?
I see printed on the main board are 5.5v and 3.3v.
- Pj
post #5373 of 5394 Old Yesterday, 02:36 AM
Trip in VA's Avatar
Quoted: 209 Post(s)
Liked: 85
Send a message via AIM to Trip in VA Send a message via Yahoo to Trip in VA
Originally Posted by wd8kct View Post
Notice PBS "Create" has switched to widescreen.
I had been told this was coming for a long time. Just looked at the satellite feed and I see it has, indeed, finally happened.
The station flags whether its broadcast is 4:3 or 16:9. If COZI TV is being provided in 16:9, then WEWS will flag it in 16:9. You would not want them to flag it 4:3 because then it would be squeezed on a 4:3 TV. Similarly, if Me-TV is being provided in 4:3, then WOIO will flag it 4:3. If it was flagged 16:9, it would be stretched on a 16:9 TV.
The station flags the stream with its aspect ratio, just like it flags whether it's 480i, 720p, or 1080i, whether it's stereo or surround, etc. If your set then locks functionality assuming that the flag is correct (not an unreasonable assumption), that's the set's problem and not the station. The station is doing what it's supposed to do, and changing what it does would break every other TV set in existence. The box is arguably doing what it's supposed to do, though if it was me manufacturing the box, I would make the box able to tinker with the aspect ratio on 4:3 programming regardless.
- Trip
N4MJC
Comments are my own and not that of the FCC (my employer) or anyone else.
RabbitEars
"Ignorance and prejudice and fear walk hand in hand..." - Rush "Witch Hunt"
Trip in VA is online now
post #5374 of 5394 Old Yesterday, 04:06 AM
JJkizak's Avatar
Quoted: 39 Post(s)
- Trip
That's all well and good but why do they use four different systems? 3.2 does it one way, 5.2 and.3 does it another, 43.3 another, 49.3 another. I am wearing out the remote compensating.
JJK
JJkizak is online now
post #5375 of 5394 Old Yesterday, 05:19 AM
Andrew K's Avatar
Quoted: 219 Post(s)
Liked: 39
Someone in another forum claims to have spotted channel 31 testing last night. I checked and saw nothing last night. If anyone else spots this highly elusive signal, then let us know.
Andrew K is online now
post #5376 of 5394 Old Yesterday, 06:06 AM
wd8kct's Avatar
Quoted: 28 Post(s)
31 is up right now with full frame color bars WI9XJY.
Extended Channel Name: GatesAir ATSC 3.0 Test Transmission
Andrew K likes this.
wd8kct is offline
post #5377 of 5394 Old Yesterday, 07:03 AM
Andrew K's Avatar
Quoted: 219 Post(s)
Liked: 39
Nice, thanks for the photo. Can you post a photo of the signal bar from the menu at your location in North Canton? I'll check when I have a chance in a couple hours from now. Hopefully they stay on-the-air for a while.
post #5378 of 5394 Old Yesterday, 08:07 AM
Bismarck440's Avatar
Quoted: 272 Post(s)
Liked: 55
Movies! always appears squeezed on my 4:3 with no way to correct.
Bismarck440 is online now
post #5379 of 5394 Old Yesterday, 08:12 AM
Quoted: 272 Post(s)
Liked: 55
We can safely assume this is ATSC 1, & WI9XJY is the call from where (thought they would use a call with 31 in the body)?
The clock coming from the box?
post #5380 of 5394 Old Yesterday, 08:36 AM
wd8kct's Avatar
Quoted: 28 Post(s)
Their signal level is slightly better than WBNX at 30. Currently the Zenith, HD Homerun and TSReader indicate no signal lock but there's a good signal on the spectrum analyzer so I guess they've switched to ATSC 3.
wd8kct is offline
post #5381 of 5394 Old Yesterday, 08:38 AM
wd8kct's Avatar
Quoted: 28 Post(s)
The clock syncs to the datastream, their clock was a few hours fast.
wd8kct is offline
post #5382 of 5394 Old Yesterday, 10:09 AM
Andrew K's Avatar
Quoted: 219 Post(s)
Liked: 39
I checked channel 31 in the 12:00 hour and didn't see anything.
post #5383 of 5394 Old Yesterday, 12:21 PM
Andrew K's Avatar
Quoted: 219 Post(s)
Liked: 39
Here is channel 31 on my 3.5" portable. The signal is great down in the Bath/Fairlawn area.
post #5384 of 5394 Old Yesterday, 03:12 PM
Quoted: 138 Post(s)
Liked: 36
I saw late this afternoon that TV 47 was having 'freezing' image problems. At 5:30pm, the signal went zero. Minutes later, 47 came back.
I'm picking up 16.1 right now, right near the make/break threshold of 30 on this box. I have a signal 31.
- Pj
post #5385 of 5394 Old Yesterday, 03:26 PM
Quoted: 138 Post(s)
Liked: 36
I'm wearing out 2 remotes.
I have my DVR AR set for 16x9. Then, I use my DTX9950 remote and my Philips 19" TV remote to adjust as needed. I could leave the TV's AR at 'Automatic', but I've seen it resize during programming long ago, so usually I leave it at 'Wide' when not reAdjusting.
- Pj
post #5386 of 5394 Old Yesterday, 03:39 PM
Quoted: 138 Post(s)
Liked: 36
Movies! always appears squeezed on my on my 4:3 with no way to correct.
Yeah, "Movies!" is 'LOCKED' on 'Anamorphic' on my DTX9950.
With "Cozi", I have a choice of...
Anamorphic
Wide 16x9
Wide 14x9
Zoom
Example - With "Here's Lucy" on right now:
The Zoom setting fits the image pretty good on my 19" TV 16x10 screen with its 'Super Zoom' AR.
- Pj
post #5387 of 5394 Old Yesterday, 05:13 PM
snowdog 88's Avatar
Quoted: 196 Post(s)
Liked: 37
You obviously don't want to go past the marked voltages, unless you want to fry the unit. You also want to make sure that the power supply can supply enough amperage to power the unit. Otherwise, it will have trouble powering on, mimicking the effects of the bad capacitors on the original power supply.
You should try to replace the capacitors on the original power supply first. Save the homemade power supply for plan B.
Newer is not always better.
HDTVs: RCA L37WD12, Vizio E371VL, Samsung UN46H5203
DTV Converter Boxes: Zenith DTT900 & DTT901, Magnavox TB100MW9
snowdog 88 is offline
post #5388 of 5394 Old Yesterday, 05:20 PM
snowdog 88's Avatar
Quoted: 196 Post(s)
Liked: 37
Anyone have success in contacting TitanTV and having a listing corrected?
I hope so, I just sent them info on WGGN to correct 42.1 to 52.1 and add 52.2 to the 'Broadcast' (OTA) listing.
The wait is on. The longer it takes, it'll probably not happen, eh?
I've contacted TitanTV on several occasions. Though it takes a few days, they've been very good at updating the guide. The last time I contacted them was about W16DO. A few days later, W35AX was gone and WAOH was back on the guide, but no W16DO.
post #5389 of 5394 Old Yesterday, 05:27 PM
Quoted: 138 Post(s)
Liked: 36
Yeah, caps to be replaced first.
Then the tuner box tear-down to find that goofy intermittent signal drop.
- Pj
post #5390 of 5394 Old Yesterday, 05:39 PM
snowdog 88's Avatar
Quoted: 196 Post(s)
Liked: 37
Notice PBS "Create" has switched to widescreen. WIVM had the studio camera in widescreen mode for "Really Spooky Movies" last week. GetTV seems to switch between 4:3 and 16:9. The aspect ratio button on the remote is getting a real workout.
All of WVIZ's subs were in 16x9 this morning. Sometime this afternoon 25-2 reverted back to 4:3, maybe because the majority of programs on that channel are in fullscreen. Other then the 'VIZ bugs being stretched out, it seems that the WVIZ staff gets the aspect ratio right.
By the time I got the news, the station had already signed off for the time being. I was away from the computer all last night and earlier today.
As I stated before, they should do their testing on VHF if stations are going to be shoved into that band.
post #5391 of 5394 Old Yesterday, 05:57 PM
Andrew K's Avatar
Quoted: 219 Post(s)
Liked: 39
I left the Insignia tuner on while I was away from home, and it decoded channel 31 and left the call letters stored in the display. Channel 31 has been very elusive. It only seems to appear for short periods of time on ATSC 1.0.
post #5392 of 5394 Unread Today, 02:53 AM
Trip in VA's Avatar
Quoted: 209 Post(s)
Liked: 85
JJK
Since I'm not local, I can't see what those local stations are doing exactly. As someone else noted, though, Movies! is provided to stations in 16:9 but is apparently being flagged as 4:3, thus the squeeze and inability to correct on 4:3 TVs. WBNX has it wrong in that case.
Regarding WVIZ, sounds like they've correctly handled Create and World going to 16:9 on the satellite.
- Trip
N4MJC
RabbitEars
post #5393 of 5394 Unread Today, 09:32 AM
Quoted: 272 Post(s)
Liked: 55
Anamorphic
Wide 16x9
Wide 14x9
Zoom
Per yesterdays posts I note Movies! is flagged 4:3 still non adjustable & "appears" to be fixed for the 4:3 .. something happen in the last couple of days? (I seldom watch the channel though).
I normally watch the main channels on the 4:3 in Zoom mode, though note now on 8's news the graphics are more 16:9 friendlier Like channel 3's news, therefore I miss the first & last day of the 7 day forecasts.
No signal reported on 31 on my Zenith 901, yet dad's Sony reports a very high signal bar, but reports no signal, I imagine this is on ATSC 3 at this point.
Any idea what tower is 31 testing on & how much power are they using? Signal strength reported on the Sony seems very strong.
post #5394 of 5394 Unread Today, 10:14 AM
Andrew K's Avatar
Quoted: 219 Post(s)
Liked: 39
What tower is 31 testing on & how much power are they using? Signal strength reported on the Sony seems very strong.
I noticed 31 was on briefly this morning, but it's off again. It seems like it's always off when I'm at home, but comes back on when I'm away. The only time I've ever caught them is on my portable 3.5" TV. The signal is strong and comes from the WJW tower. I would imagine that they're using the same power as WJW used back when they were using 31 before the digital transition, which if I remember right, was around 600 kW. So basically it's a full-power signal.
