Cleveland, OH - HDTV - Page 185 - AVS | Home Theater Discussions And Reviews
 127Likes
post #5521 of 5523 Unread Yesterday, 05:19 AM
Andrew K's Avatar
Quoted: 239 Post(s)
Liked: 41
Originally Posted by snowdog 88 View Post
Why am I never by my TV when e-skip happens?! I use to catch it a lot in previous years!
The E-skip season is really just beginning. June and July are the peak months, so you can still try to spot anything. I use a Winegard YA-6260 mounted about 15' above ground on my roof. The antenna has several trees around it and a taller house next door, but e-skip is usually powerful enough to decode with just a simple dipole antenna. And I even heard that it's not always necessary to have the antenna pointed in the right direction, since the signals are usually strong. Last night, I picked up something from Mexico on analog channel 2, but it was too indistinct to get an ID. But based on the map at that time, the E-clouds were aligned to allow for Mexico TV to be received here. This is the map that will clue you in on an e-skip opening... http://www.dxmaps.com/spots/map.php?...XC=N&HF=N&GL=N
Here is my decode of KNOP on Saturday morning...
Andrew K is online now
post #5522 of 5523 Unread Today, 09:40 AM
Bismarck440's Avatar
Quoted: 293 Post(s)
Liked: 61
Originally Posted by Andrew K View Post
Today is an e-skip day!! KNOP received here in Akron...
Cuz ALL signals lead to Akron! , I see 19 was on & off too for me (my tropo), but no skip or good tropo here.
Is 19 using a partially updated graphic package (name/story banner) for breaking news and Cavs related stories? Perhaps they're getting ready to drop the "19 Action News" brand and switch to a new graphic/sound package.
Yes the new graphics roll off the first & last days of the forecast now in zoom.
Bismarck440 is offline
post #5523 of 5523 Unread Today, 02:56 PM
wd8kct's Avatar
Quoted: 29 Post(s)
Behind-the-scene pictures from the Indy 500. Look at those patch bays!
http://imgur.com/a/fFDYI/all
wd8kct is online now
