Cleveland, OH - HDTV - Page 192 - AVS Forum | Home Theater Discussions And Reviews
 136Likes
post #5731 of 5756 Unread 06-29-2015, 03:26 PM
Inundated's Avatar
Quoted: 45 Post(s)
Liked: 24
I once saw CKCO-42 right next to WUAB/43 in its analog days.
Inundated is online now
post #5732 of 5756 Unread 06-29-2015, 03:29 PM
Inundated's Avatar
Quoted: 45 Post(s)
Liked: 24
Originally Posted by Andrew K View Post
That's interesting. I remember seeing channel 42 back in the analog days, and I think it was a repeater for CKCO in the Sarnia/Chatham Ontario area. I haven't checked that channel in a long time. I'm not sure what the status of that is, but there's a good chance it could still be on analog 42. Many rural analogs have remained on the air in Canada. I'll keep an eye out for it.
Sarnia would most likely not be in a "mandatory" digital conversion market.
I believe their primary station in Chatham/Kent would be.
post #5733 of 5756 Unread 06-29-2015, 03:47 PM
snowdog 88's Avatar
Quoted: 244 Post(s)
Liked: 38
It's worth a try. However, e-skip occurs more commonly in the daytime and up until around sunset and just a bit after. It hardly ever occurs at night.
Daytime? I have the best results with e-skip at night. It's like AM radio. However, Thanksgiving 2006 was when e-skip was taking over almost every local channel during the day. WRAP was like a scrambled cable channel as it was fighting with CICO-32. Position the antenna just right and CICO would null out WRAP.
I'm in the process of replacing that RS VU-190XR with something smaller. The VU-190XR is overkill for where I'm at, though it has done a good job with analog signals and digital signals like WKYC's pre-transition RF2. The tree next to the antenna has grown so much that the downward-growing branches have grabbed the VHF elements on windy days and snapped the fragile plastic tabs holding them in place. (Nice job with the cost-cutting RS. These antennas use to have aluminum-locking tabs). After re-positioning them back in place so many times, the elements break off completely from the insulator. Since it's really not necessary to have a low-VHF antenna in this area, I am leaning towards something like the Channel Master 100 mile digital advantage 2020, which has 3 pairs of hi-VHF elements and a long UHF boom for 100 mile reception. (Hopefully that will help with problem channels like 5 and 43). I'm not sure if it will improve reception of WCDN's RF 7, as the hi-VHF elements will be in the vicinity as the VU-190XR. No big deal I guess.
RS has Antennacraft antennas for an incredible price, but the nearby location doesn't have any in stock, or online.
Newer is not always better.
HDTVs: RCA L37WD12, Vizio E371VL, Samsung UN46H5203
DTV Converter Boxes: Zenith DTT900 & DTT901, Magnavox TB100MW9
snowdog 88 is offline
post #5734 of 5756 Unread 06-29-2015, 04:16 PM
Andrew K's Avatar
Quoted: 285 Post(s)
Liked: 43
There is a huge difference between e-skip propagation and tropospheric propagation. Tropospheric ducting generally improves at night when a temperature inversion forms (cooler air below warmer air), and allows signals to bend around the earth's curvature. Tropo can affect all TV and FM signals, even UHF TV. It's common to see signals propagated by tropo around 100 to 200 miles around here, sometimes even further.
E-skip only affects TV channels 2-6, extremely rare on the high-VHF channels, and never UHF. There are layers in the ionosphere which cause these frequencies to bounce back to earth typically 600 to 1400 miles beyond the transmitter. This e-layer is around 60 miles above the earth, and when it reaches a certain charge is when the signals are mirrored back to earth. That's why you can watch Nebraska, South Dakota, Maine, Cuba, and Mexico on the low-VHF channels. And yes, e-skip DOES occur nearly all during the daytime. Here is a map with the current e-skip conditions... http://www.dxmaps.com/spots/map.php?...XC=N&HF=N&GL=N
Whenever I see an antenna manufacturer claim that an antenna can get UHF channels at 100 miles, I don't trust them. First of all, no UHF signal can be received normally at 100 miles unless it's being bent around the earth's curvature via tropo. The tower height would have to be unfeasible to accomplish that, and no antenna can penetrate the earth's curvature. Pay close attention to the antenna's gain number. That will tell you how well it performs.
Andrew K is online now
post #5735 of 5756 Unread 06-29-2015, 04:31 PM
snowdog 88's Avatar
Quoted: 244 Post(s)
Liked: 38
...And all this time I thought e-skip and tropo were the same. (AVS apparently doesn't have a smack head smiley).
The ones I don't trust are those ugly Chinese antennas with the built-in amp and rotor...
post #5736 of 5756 Unread 06-29-2015, 06:19 PM
Andrew K's Avatar
Quoted: 285 Post(s)
Liked: 43
E-skip just going insane right now. WMTX Tampa is beating out WMMS on 100.7, and in full HD. And WDBO Orlando beat out 96.5 Kiss FM Cleveland!!
post #5737 of 5756 Unread 06-29-2015, 07:19 PM
snowdog 88's Avatar
Quoted: 244 Post(s)
Liked: 38
Not getting any degradation on those channels, but I finally got a quick grab of something on RF 2. It was very brief, but left behind 3.3 KOTA3. The signal disappeared within a matter of minutes!
EDIT: KNOP 2.1 just briefly appeared on my TV. Only lasted for a few seconds and quickly disappeared.
post #5738 of 5756 Unread 06-29-2015, 07:56 PM
Andrew K's Avatar
Quoted: 285 Post(s)
Liked: 43
NICE!!! That's classic e-skip!! The signal on channel 2 is still dancing here, but not decoding. I got both KNOP and KOTA today as well.
It seemed like every radio station from Florida was invading Ohio tonight, but unfortunately there aren't any low-VHFs in Florida to catch on DTV.
post #5739 of 5756 Unread 06-30-2015, 09:47 AM
Bismarck440's Avatar
Quoted: 333 Post(s)
Liked: 62
"... and a couple sub-decodes from CKCO 13 and CITY 31. You're much closer than I am.
CITY, isnt that testing still going on, on 31 here?
I'm not hearing or seeing anything, & anything from a great distance was always afternoon to very early evening.
Bismarck440 is offline
post #5740 of 5756 Unread 06-30-2015, 09:49 AM
Quoted: 333 Post(s)
Liked: 62
Hey now... the "Great 58"! , what time of day are you getting this? The AVS time stamps are all messed up.
post #5741 of 5756 Unread 06-30-2015, 12:26 PM
Andrew K's Avatar
Quoted: 285 Post(s)
Liked: 43
That photo of 96.5 was yesterday at 9:16 PM. WDBO is in Orlando. It's a news-talk format. It was obliterating Kiss FM in Cleveland.
31 must not be testing in Cleveland. Someone else reported that it wasn't even appearing on the spectrum analyzer. And a few nights ago, 31 CITY was just below the decode threshold with the antenna aimed north. That wouldn't of happened if the ATSC 3.0 tests were using 31.
post #5742 of 5756 Unread 06-30-2015, 04:49 PM
Inundated's Avatar
Quoted: 45 Post(s)
Liked: 24
WDBO's talk format moved exclusively to 96.5 FM years ago.
580 AM is now Orlando's ESPN Radio affiliate.
post #5743 of 5756 Unread 06-30-2015, 04:58 PM
CleCakYngMfd's Avatar
Quoted: 199 Post(s)
Liked: 45
LoL.
How about this:
- Pj
Awaiting delivery of CalMAN Kit. Vizio P-Series - 2014 P502ui-B1E (50") TV - Firmware: 1.1.19 - Awaiting 1.2.23-UHD. Win7Pro & FireFox 39.0.0, Desktop Computer. ClearStream-4 Antenna, a dying DTX9950 Converter Box (See www.BadCaps.Net and Capacitor Plague), dying Philips 19PFL3403D TV. My brother: Android-driven Sony 75X850C TV & now has M401i-A3.
CleCakYngMfd is online now
post #5744 of 5756 Unread 07-01-2015, 09:38 AM
snowdog 88's Avatar
Quoted: 244 Post(s)
Liked: 38
The RF 31 ATSC 3.0 test station is back up right now.
post #5745 of 5756 Unread 07-01-2015, 09:55 AM
Quoted: 333 Post(s)
Liked: 62
Haven't returned there in years, but the calls were also on Channel 6, pretty sure that was CBS at the time.
Been a while since I caught Florida DX I remember a Miami Classical station on 93.1 knocking WZAK off for a bit & them 102.7 out of Tampa ... years ago, & always in June.
Are they in ATSC 2 mode?
post #5746 of 5756 Unread 07-01-2015, 10:18 AM
Quoted: 199 Post(s)
Liked: 45
Yeah, just checked with inputting ". 31" (Dot 31). That's RF channel selecting. Does the Zenith/Insignia do RF channel entry?
I got a peak 83 signal level with 31. Mostly sitting in the low-to-mid 70s. I swung the C4 to the NNW. N and NNE had lower signal levels.
Pics coming momentarily.
- Pj
post #5747 of 5756 Unread 07-01-2015, 10:33 AM
Quoted: 199 Post(s)
Liked: 45
The first pic is of 3.3 Wx the other day.
The second one is the signal level of 31.1 (RF 31) moments ago. I turned my indoor C4 from the usual WNW to the NNW to get 31.1.
RF 8 with the antenna pointed NNW: Signal Level of 4.
Name:	2015 06 30 TV3.3 Wx.jpg
ID:	806986   Click image for larger version
Name:	2015 07 01 TV 31.1 Testing - Signal Level from my Indoor C4.jpg
- Pj
post #5748 of 5756 Unread 07-01-2015, 11:53 AM
Andrew K's Avatar
Quoted: 285 Post(s)
Liked: 43
The signal is good here too on the portable TV. Afterall, it is a full-powered signal at the Parma antenna farm, so it should be good here.
post #5749 of 5756 Unread 07-01-2015, 11:59 AM
Andrew K's Avatar
Quoted: 285 Post(s)
Liked: 43
Yes, the Zenith/Insignia has it too. You can manually enter the RF channel number... for example, enter 31, and it goes directly to RF 31. But if you enter 19, it doesn't go directly to RF 19, it goes to virtual 19 WOIO. That is why I prefer going into the menu and manually flipping through the actual RF channel numbers.
By the way, get a Zenith/Insignia tuner on Ebay. They're far superior than any other tuner.
Inundated likes this.
post #5750 of 5756 Unread 07-01-2015, 01:49 PM
snowdog 88's Avatar
Quoted: 244 Post(s)
Liked: 38
That's a new one.
Rewind to April 8, 2014...
post #5751 of 5756 Unread 07-01-2015, 04:03 PM
Inundated's Avatar
Quoted: 45 Post(s)
Liked: 24
I believe they still are, though I think the calls are WKMG now.
post #5752 of 5756 Unread 07-01-2015, 07:31 PM
Quoted: 199 Post(s)
Liked: 45
Hmm. I push "." (Dot) and "RF" pops-up in the upper-right corner. Any number I enter goes to an RF channel, EXCEPT if it is an active digital channel, it then switches to that virtual channel number.
Is there something with the Zenith/Insignia boxes to do before entering a number for RF or is that the default mode?
- Pj
post #5753 of 5756 Unread 07-02-2015, 06:21 AM
Andrew K's Avatar
Quoted: 285 Post(s)
Liked: 43
No, just enter the number. That's it.
And if you're too impatient like me, you can hit OK and it will go to the channel so you don't have to wait.
post #5754 of 5756 Unread 07-02-2015, 06:42 AM
wd8kct's Avatar
Quoted: 36 Post(s)
I usually go to setup > manual tuning when I want to campout on a channel with the Zenith.
The Haier is a little tricky because there's a physical and virtual 49 (and 17) in the area, usually enter the RF channel.
wd8kct is offline
post #5755 of 5756 Unread 07-02-2015, 07:13 PM
Quoted: 199 Post(s)
Liked: 45
...Just enter the number. That's it.
That's strange. To me. The numbers entered on the Digital Stream's remote takes you virtual channels by default. I need to enter 'Dot+Number' for RF channels. I just assumed virtual channels are the default on all the boxes. Isn't that why virtual channels were implemented in the first place when DTV rolled-out - sticking with the 'familiar' channels for the public?
- Pj
post #5756 of 5756 Unread Today, 01:40 AM
Andrew K's Avatar
Quoted: 285 Post(s)
Liked: 43
TROPO... The signal levels on all Pittsburgh stations are higher than I've ever seen them. Anyone else seeing Pittsburgh?? I even got a new low power station from that area... WOSC RF 31 virtual 61.
