Cleveland, OH - HDTV - Page 199 - AVS Forum | Home Theater Discussions And Reviews
 147Likes
post #5941 of 5963 Unread 08-25-2015, 09:26 AM
Bismarck440's Avatar
Quoted: 383 Post(s)
Liked: 64
Originally Posted by snowdog 88
I don't have mine hooked up at the moment (I use it as a spare/temporary use). Last time I used it was about 3 months ago and the mapping was correct for WBNX. Did you rescan your box? I wonder if the recent upgrades (new encoder?) at WBNX had something to do with the RF channel appearing as the virtual.
I no longer have them, but vthey were part of my "test" in Spring of 2008 I believe both the Magnavox & Philco mapped 55 to 30 (it's native physical channel). That was my thought on actual station improvements, but the LG at the same time was mapping the box to 55, so another encoder miscommunicstion.
Originally Posted by Andrew K
I remember sneaking an FM radio on a plane many years ago, and once the plane was about 1,000 feet above ground (in Cleveland)........, .
Yeah, I used to take a Walkman on flights without issue, gave me a idea where about I was flying over, though you could pick up stations 3-400 miles apart simultaniously... a fun activity to pass the time on a flight, see how may stations could be logged in. Back in the day when I used to fly & take vacachies.
Bismarck440 is offline
post #5942 of 5963 Unread 08-25-2015, 06:35 PM
snowdog 88's Avatar
Quoted: 271 Post(s)
Liked: 40
I just did a rescan on my Magnavox converter box and WBNX still maps to 55, so maybe it was a configuration error that was messing up the "Fungi" boxes. That was apparently fixed a long time ago as I have never had problems with 55 since acquiring the Magnavox box 4-5 years ago. The only time I get RF mapped channels is on my Zenith DTT-900 with WEAO & WCDN when the signal is just below the decoding threshold. Once the signal is strong enough to get the PSIP data, the RF channel is replaced with the virtual channel.
WBNX definitely did do something with their encoder. As I stated before, my RCA L37WD12 no longer has audio decoding issues with WBNX since the aspect ratio on 55.3 was corrected. Now if only WEWS (.1 .2 .3) and WJW (.2) could do the same.
Newer is not always better.
snowdog 88 is online now
post #5943 of 5963 Unread 08-26-2015, 07:38 AM
snowdog 88's Avatar
Quoted: 271 Post(s)
Liked: 40
Exclamation Ohio Media Watch
Ohio Media Watch is closing up shop.
http://ohiomediawatch.com/2015/08/24/ten-years-and-out/
post #5944 of 5963 Unread 08-26-2015, 09:13 AM
Quoted: 383 Post(s)
Liked: 64
That would be the Black box with the Yellow Standby/Green On LED? I get plenty of the unmapped channels too on low signal level, 17 & 19 .. speaking of which is still off the air for me.
post #5945 of 5963 Unread 08-26-2015, 09:36 AM
snowdog 88's Avatar
Quoted: 271 Post(s)
Liked: 40
Yes. Model number TB100MW9
The TB110MW9, I believe, is a revised model that doesn't have the yellow standby light or the line ON/OFF switch. I think it also has the analog pass-through feature.
post #5946 of 5963 Unread 08-26-2015, 09:54 AM
Quoted: 383 Post(s)
Liked: 64
I must of had the TB100MW9, no on off switch?
post #5947 of 5963 Unread 08-27-2015, 04:46 PM
Michael P 2341's Avatar
Quoted: 78 Post(s)
. I receive CJBX 92.7 from London every day here in Akron (not strong, but it's there), yet Cleveland has an Air1 translator on 92.7. And Erie now has a full-power station on 92.7, even though CJBX used to be strong enough within the city of Erie, to basically be local, but it has no protection here on US soil.
That explains why that Air1 signal get beat-up in Parma. So you get that Canadian 92.7 every day?!?
Michael P 2341 is online now
post #5948 of 5963 Unread 08-27-2015, 05:27 PM
Andrew K's Avatar
Quoted: 320 Post(s)
Liked: 50
Yes, every day!! CJBX is weak, but if I tune my car radio to 92.7, I can hear it. I am even listening to it now, and I'm just sitting in a Giant Eagle parking lot in Wadsworth. The 92.7 Air1 translator never makes it down here to Akron, not even one bit of signal!!
Andrew K is online now
post #5949 of 5963 Unread 08-27-2015, 07:07 PM
snowdog 88's Avatar
Quoted: 271 Post(s)
Liked: 40
The digital static on 19 is getting worse. This is week 3 and it still hasn't been fixed. The strange thing is that anything local on 19 (news, commercials, etc.) is free of static. Is this a problem with WOIO or CBS?
post #5950 of 5963 Unread 08-28-2015, 09:15 AM
Quoted: 383 Post(s)
Liked: 64
What is this Air1 thing... a pay service? I really no longer scan aside of my presets anymore.
This is week 3 (or longer) of no 19, so they are still on the air then?
post #5951 of 5963 Unread 08-28-2015, 11:20 AM
Andrew K's Avatar
Quoted: 320 Post(s)
Liked: 50
Air1 is a contemporary Christian music station which has signals all over northeast Ohio (and the country). The company which owns Air1 also owns K-Love stations, which also can be heard in northeast Ohio on various frequencies.
Yes, WOIO is still on-the-air. Both RF 10 and 24 are as strong as ever here in Akron (where all the signals lead to). Maybe you should either move to Akron, or pay for cable .
By the way, here is a link to what my tuner is currently receiving... http://m.rabbitears.info/index.php?r...1038781D&tno=0
Whenever you have issues with a channel, check to see if I'm receiving it at the link!! Look at the far-right column... if there is a number, then a signal has decoded. As I write this, the antenna is aimed northwest. If I aim east to southeast, I can add WFMJ, WYTV, WAOH and WIVM. WKBN and WNEO are typically strong enough that I don't have to aim at them to receive them.
WOIO on RF 10 usually only shows the signal strength and signal-to-noise ratio on the right, no call letters are displayed for RF 10 because I can get RF 24 simultaneously, and the PSIP is identical. As you can see, the signal strength for RF 24 is within "blowtorch" strength... 100%, with a 90% signal-to-noise ratio (signal quality), with antenna aimed away from the tower.
post #5952 of 5963 Unread 08-28-2015, 12:57 PM
Quoted: 383 Post(s)
Liked: 64
Heck with cable (you sound like my HOA!) , I want to let WOIO know of their sloppy transmissions (or my reception which isn't limited to myself), I have to explain this to my dad every so often he calls & says no 19.
Air1... probably not in Lake County, remember we are nuthin but a bunch of heathens up here!
We really don't have any religous channels avail except for 55.2.
post #5953 of 5963 Unread 08-28-2015, 05:25 PM
Andrew K's Avatar
Quoted: 320 Post(s)
Liked: 50
I decided to park my car in the Chapel Hill Mall parking lot and see if there was any tropospheric ducting going on, and sure enough I picked up KWWR 95.7 from Mexico Missouri!! That's 580 miles to the transmitter!! That wasn't e-skip, that was just plain-old tropo .
Video here...
post #5954 of 5963 Unread 08-28-2015, 07:23 PM
kc9hzn's Avatar
As a general rule, Air1 and K-LOVE both tend to run on lower power stations in the non-commercial band. Since the religious stations in my neck of the woods tend to be Moody, Air1 and K-LOVE are a sure sign of DX coming in, usually weak tropo.
kc9hzn is offline
post #5955 of 5963 Unread 08-29-2015, 07:18 AM
Quoted: 78 Post(s)
Wink
They can be confused as being "DX" simply by being repeaters of 2 California stations with repeaters all over the country. Here in Ohio they have "anchor" full power stations that technically are the stations being repeated. One is at 90.9 in Jefferson, OH, the other is the HD2 signal of WKDD.
73's
post #5956 of 5963 Unread 08-31-2015, 09:30 AM
Quoted: 383 Post(s)
Liked: 64
I did a check of 92.7 coming home overnight in Willoughby, sounded like pop/folk music & certainly not Christian.
Strange looking radio in your car Andrew, I hope you don't take vids while driving!
No 19 WOIO all weekend... thinking of hiding it, becoming annoying being no signal ALL the time now.,
post #5957 of 5963 Unread Yesterday, 12:12 PM
Quoted: 78 Post(s)
"Contemporary" Christian music is pop/folk and even rock (Air 1 skews to a younger audience than K Love). If you are looking for organs and quartets singing in harmony you won't find them on Air 1 or K Love.
post #5958 of 5963 Unread Today, 09:17 AM
Quoted: 383 Post(s)
Liked: 64
I get you, but I still think it was from Canada... they gave an ID but it was hard to dicern.
Enough is enough, I finally hid WOIO on my set, still not coming in, last night on 19.1 (no signal) it went over to 10.2 (no ID) I got a brief frozen picture with a CW bug in the corner (though not WBNX, & I had just come over from 61.4 Escape.
Wasn't there someone from WOIO that used to hang out in this forum or was it someone from 8?
post #5959 of 5963 Unread Today, 11:26 AM
snowdog 88's Avatar
Quoted: 271 Post(s)
Liked: 40
I think an engineer from WKBN use to post on the Youngstown thread, but I'm not 100% sure. That is from what I heard somewhere here or on the Youngstown thread. It would be nice if someone from each of the major Cleveland stations (3, 5, 8, 19/43, & 55) would climb on board here so we could discuss technical issues with them rather then contacting them directly via email.
Speaking of WOIO, I see the digital static issue during CBS programming has been resolved.
post #5960 of 5963 Unread Today, 11:53 AM
Andrew K's Avatar
Quoted: 320 Post(s)
Liked: 50
Maybe you should rotate your antenna towards London. You'd probably get CFPL better than WOIO.
By the way, if you're receiving that country station on 92.7, (BX 93) which is CJBX, then you're probably getting interference from the channel 10 in London too.
post #5961 of 5963 Unread Today, 03:03 PM
Quoted: 383 Post(s)
Liked: 64
What was that CW Bug?? ( the box mapped to 10.2 briefly during that... then back to 19.1 & no signal.), & I went over to check it was the CW Bug without the WBNX.. CFPL associated with CW? there was no PISP.
Speaking of which, 61 lost their PISP again.
post #5962 of 5963 Unread Today, 05:16 PM
snowdog 88's Avatar
Quoted: 271 Post(s)
Liked: 40
Sometimes when you tune into a station that has a weak/no signal, you might see artifacts of the last frame of the previous station that you were on. I believe this happens because the memory buffer doesn't get cleared when arriving on a weak or undecodable signal. When the TV attempts to decode a weak station, that last frame in the buffer gets displayed on the screen, which slowly gets overwritten by the weak station as reception improves. So if you were on WBNX and headed over to WOIO, what you saw was the last decoded frame of WBNX when your TV detected a strong enough (brief) signal from WOIO. I don't think this had anything to do with CFPL.
post #5963 of 5963 Unread Today, 05:27 PM
Andrew K's Avatar
Quoted: 320 Post(s)
Liked: 50
Bismarck, your problem is with CFPL. I'm sure it's interfering with WOIO. Today, the rain moved through and cooled off the temperatures by 20 degrees, and I noticed once it moved through, it created some tropospheric enhancement. Here I'm getting all the the usual Pittsburgh UHFs... WTAE, WPXI, WPNT, WPGH, KDKA, and WINP. I also noticed while driving around Akron today, that London's 103.1 Fresh Radio was coming in just like a local with RDS showing.
